175-72MM X 60YD
175-72MM X 60YD
    TAPECASE
    WHITE SINGLE COATED COTTON CLOTH
175-72MM X 60YD 数据手册
TapeCase Ltd. 150 Gaylord S treet, E lk Grove V illage, IL 60007 phone: (847) 299-7880 fax: (847) 299-7804 www.tape case.com sale s@t apeca se.com Single Coated Cotton Cloth Tape 175 General Description 175 is a cotton cloth, single coated with a natural rubber adhesive. The cotton cloth substrate is very conformable. Exceptionally good electrical tape with a non-thermosetting adhesive. Ideal for surfaces requiring a high degree of stain or corrosion resistance. Applications   Wire harness wrapping Motor coil winding applications Technical Data TECHNICAL PROPERTIES Total Thickness Adhesive Thickness ADHESIVE TEST DATA Peel Adhesion Backing Adhesion Tensile Strength 10.5 mil 4.0 mil 32 oz./inch 20 oz./inch 36 lbs./inch NOTE: 1. When applying pressure sensitive adhesive films to any surface, be sure that the surface is free from oil or other surface contaminates such as powder, dust, or release agents. Adhesive performance should be carefully checked when used on substrates containing plasticizers. 2. Shelf life is one year from date of shipment when stored in a cool dry place below 76° F (24ºC). Rolls should be stored on end. 3. The above values are “Typical Values” which have a nominal range about them and are not intended for specification purposes. 11/11/2019
175-72MM X 60YD
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路安全。
3. 引脚分配:EL817共有6个引脚,分别为1脚阳极,2脚阴极,3脚发光二极管正极,4脚发光二极管负极,5脚光敏三极管集电极,6脚光敏三极管发射极。
4. 参数特性:EL817的主要参数包括正向电流为50mA,反向电压为5V,输出低电平电流为10mA,输出高电平电流为16mA。
5. 功能详解:EL817通过光电效应实现电信号的隔离传输,输入端控制发光二极管发光,输出端光敏三极管导通,实现信号传输。
6. 应用信息:EL817广泛应用于工业控制系统、仪器仪表、医疗设备等领域,实现信号隔离和保护。
7. 封装信息:EL817采用DIP6封装,尺寸为9.1mm x 3.6mm x 3.8mm。
175-72MM X 60YD 价格&库存
很抱歉,暂时无法提供与“175-72MM X 60YD”相匹配的价格&库存,您可以联系我们找货
