1.625-36-2042-03
1.625-36-2042-03
    TAPECASE
    2042-03 GRAY SUPER SLICK TAPE MA
1.625-36-2042-03 数据手册
TapeCase Ltd. 1982 Lunt Ave, Elk Grove Village, IL 60007 phone: (847) 299 -7880 fax: (847) 299-7804 www.tapecase.com sales@tapecase.com Super Slick Tape Made with Teflon PTFE 2042-03 Product Description 2042-03 is manufactured from skived PTFE (polytetraflouroethylene) film coated with hightemperature acrylic adhesive. Application Information 2042-03 is often used as an excellent release surface on packaging equipment and heat sealing machines, roll coverings on plastic extenders, guide rails, and angle bars in the graphic arts industry. Technical Properties Property Backing Material Characteristic Film-PTFE Adhesive Type Acrylic Total Thickness (in.) 0.0035 Backing Thickness (in) 0.002 Adhesive Thickness (in.) 0.0015 Adhesion to Steel (oz/in) 25 Elongation (% at break) 300 Operating Temperature (F) -100 to 350 Color Gray Dielectric Strength (volts) 7000 Features/ Benefits One side of 2042-03 has an acrylic pressure sensitive adhesive and the other side offers a low coefficient of friction PTFE film, which is thin and conformable. PTFE backing offers excellent high temperature resistance and is chemically inert. 2042-03’s tape construction is stable and non-toxic. NOTE: 1. When applying pressure sensitive adhesive films to any surface, be sure that the surface is free from oil or other surface contaminates such as powder, dust, or release agents. Adhesive performance should be carefully checked when used on substrates containing plasticizers. 2. The above values are “Typical Values” which have a nominal range about them and are not intended for specification purposes 7/10/17
1.625-36-2042-03
1. 物料型号:2042-03 2. 器件简介:Super Slick Tape 2042-03由PTFE(聚四氟乙烯)薄膜制成,并涂有高温丙烯酸粘合剂。 3. 应用信息:通常用作包装设备和热封机上的优良释放表面,塑料延长器的卷覆层,以及在图形艺术行业中的导向轨和角铁。 4. 参数特性: - 基材:PTFE薄膜 - 粘合剂类型:丙烯酸 - 总厚度:0.0035英寸 - 基材厚度:0.002英寸 - 粘合剂厚度:0.0015英寸 - 对钢的粘附力:25盎司/英寸 - 伸长率:300% - 工作温度:-100至350华氏度 - 颜色:灰色 - 介电强度:7000伏特 5. 功能详解:2042-03的一侧有丙烯酸压敏粘合剂,另一侧提供低摩擦系数的PTFE薄膜,该薄膜薄且可塑。PTFE基材提供出色的高温抵抗力,并且化学性质稳定。2042-03的胶带结构稳定且无毒。 6. 封装信息:文档中没有提供封装信息
1.625-36-2042-03 价格&库存
很抱歉,暂时无法提供与“1.625-36-2042-03”相匹配的价格&库存,您可以联系我们找货
