12-18-2045-10
12-18-2045-10
    TAPECASE
    2045-10 GRAY SUPER SLICK TAPE MA
12-18-2045-10 数据手册
TapeCase Ltd. 150 Gaylord St, Elk Grove Village, IL 60007 phone: (847) 299-7880 fax: (847) 299-7804 www.tape case.com sale s@t apeca se.com Super Slick Tape Made with Teflon PTFE 2045-10 Product Description 2045-10 is manufactured from skived PTFE (polytetraflouroethylene) film coated with hightemperature silicone adhesive. Application Information 2045-10 is often used as an excellent release surface on packaging equipment and heat sealing machines, roll coverings on plastic extenders, guide rails, and angle bars in the graphic arts industry. Technical Properties Property Characteristic Backing Material Film-PTFE Adhesive Type Silicone Total Thickness (in.) 0.0115 Backing Thickness (in) 0.0100 Adhesive Thickness (in.) 0.0015 Adhesion to Steel (oz/in) 50 Tensile Strength (lbs/in) 60 Dielectric Strength (volts) 19500 Elongation (% at break) 450 Operating Temperature (F) -100 to 500 Color Gray Features/ Benefits One side of 2045-10 has a silicone pressure sensitive adhesive and the other side offers a low coefficient of friction PTFE film, which is thin and conformable. PTFE backing offers excellent high temperature resistance and is chemically inert. 2042-10’s tape construction is stable and non-toxic. NOTE: 1. When applying pressure sensitive adhesive films to any surface, be sure that the surface is free from oil or other surface contaminates such as powder, dust, or release agents. Adhesive performance should be carefully checked when used on substrates containing plasticizers. 2. The above values are “Typical Values” which have a nominal range about them and are not intended for specification purposes 9/2/16
12-18-2045-10
- 物料型号:2045-10 - 器件简介:2045-10是由PTFE(聚四氟乙烯)薄膜制成的,涂有耐高温硅酮胶。 - 应用信息:常用于包装设备和热封机的优良释放表面,塑料延长器的卷覆,图文行业导向轨和角铁的覆盖。 - 参数特性: - 基材:PTFE薄膜 - 胶粘剂类型:硅酮 - 总厚度:0.0115英寸 - 基材厚度:0.0100英寸 - 胶粘剂厚度:0.0015英寸 - 对钢的粘附力:50盎司/英寸 - 拉伸强度:60磅/英寸 - 介电强度:19500伏特 - 断裂伸长率:450% - 工作温度范围:-100至500℉ - 颜色:灰色 - 功能详解:2045-10的一侧有硅酮压敏胶,另一侧提供低摩擦系数的PTFE薄膜,该薄膜薄且可塑。PTFE基材提供出色的耐高温性能,并且化学性质稳定。2042-10的胶带结构稳定且无毒。 - 封装信息:文档中未提供封装信息
12-18-2045-10 价格&库存
很抱歉,暂时无法提供与“12-18-2045-10”相匹配的价格&库存,您可以联系我们找货
