0.5-1-2045-3 (PK10)
0.5-1-2045-3 (PK10)
    TAPECASE
    2045-3 GRAY SUPER SLICK TAPE MAD
0.5-1-2045-3 (PK10) 数据手册
TapeCase Ltd. 150 Gaylord St, Elk Grove Village, IL 60007 phone: (847) 299-7880 fax: (847) 299-7804 www.tape case.com sale s@t apeca se.com Super Slick Tape Made with Teflon PTFE 2045-3 Product Description 2045-3 is manufactured from skived PTFE (polytetraflouroethylene) film coated with hightemperature silicone adhesive. Application Information 2045-3 is often used as an excellent release surface on packaging equipment and heat sealing machines, roll coverings on plastic extenders, guide rails, and angle bars in the graphic arts industry. Technical Properties Property Characteristic Backing Material Film-PTFE Adhesive Type Silicone Total Thickness (in.) 0.0045 Backing Thickness (in) 0.0030 Adhesive Thickness (in.) 0.0015 Adhesion to Steel (oz/in) 35 Tensile Strength (lbs/in) 20 Dielectric Strength (volts) 9500 Elongation (% at break) 350 Operating Temperature (F) -100 to 500 Color Gray Features/ Benefits One side of 2045-3 has a silicone pressure sensitive adhesive and the other side offers a low coefficient of friction PTFE film, which is thin and conformable. PTFE backing offers excellent high temperature resistance and is chemically inert. 2042-3’s tape construction is stable and nontoxic. NOTE: 1. When applying pressure sensitive adhesive films to any surface, be sure that the surface is free from oil or other surface contaminates such as powder, dust, or release agents. Adhesive performance should be carefully checked when used on substrates containing plasticizers. 2. The above values are “Typical Values” which have a nominal range about them and are not intended for specification purposes 9/22/16
0.5-1-2045-3 (PK10)
物料型号:2045-3
器件简介:2045-3是由刮削聚四氟乙烯(PTFE)薄膜涂覆高温硅酮胶制成的。
引脚分配:文档中没有提及引脚分配,因为这是关于胶带而非电子元件。
参数特性:包括基材材料(PTFE薄膜)、胶粘剂类型(硅酮)、总厚度(0.0045英寸)、基材厚度(0.0030英寸)、胶粘剂厚度(0.0015英寸)、对钢的粘附力(35盎司/英寸)、拉伸强度(20磅/英寸)、介电强度(9500伏特)、伸长率(350%)、工作温度范围(-100至500华氏度)、颜色(灰色)。
功能详解:2045-3胶带的一面涂有硅酮压敏胶,另一面提供低摩擦系数的PTFE薄膜,该薄膜薄且可塑。PTFE基材提供优异的高温抗性和化学惰性。2045-3的胶带结构稳定且无毒。
应用信息:2045-3通常用作包装设备和热封机上的优良释放表面,塑料延长器上的卷材覆盖,以及在图文艺术行业中的导向轨和角铁。
封装信息:文档中没有提供封装信息,因为这是关于胶带而非电子元件。
0.5-1-2045-3 (PK10) 价格&库存
很抱歉,暂时无法提供与“0.5-1-2045-3 (PK10)”相匹配的价格&库存,您可以联系我们找货
