0.25-5-2045-5 (PK5)
0.25-5-2045-5 (PK5)
    TAPECASE
    2045-5 GRAY SUPER SLICK TAPE MAD
0.25-5-2045-5 (PK5) 数据手册
TapeCase Ltd. 1982 Lunt Ave, Elk Grove Village, IL 60007 phone: (847) 299-7880 fax: (847) 299-7804 www.tape case.com sale s@t apeca se.com Super Slick Tape Made with Teflon PTFE 2045-5 Product Description 2045-5 is manufactured from skived PTFE (polytetraflouroethylene) film coated with hightemperature silicone adhesive. Application Information 2045-5 is often used as an excellent release surface on packaging equipment and heat sealing machines, roll coverings on plastic extenders, guide rails, and angle bars in the graphic arts industry. Technical Properties Property Characteristic Backing Material Film-PTFE Adhesive Type Silicone Total Thickness (in.) 0.0065 Backing Thickness (in) 0.005 Adhesive Thickness (in.) 0.0015 Adhesion to Steel (oz/in) 40 Elongation (% at break) 400 Operating Temperature (F) -100 to 500 Color Gray Dielectric Strength (volts) 13000 Features/ Benefits One side of 2045-5 has a silicone pressure sensitive adhesive and the other side offers a low coefficient of friction PTFE film, which is thin and conformable. PTFE backing offers excellent high temperature resistance and is chemically inert. 2042-03’s tape construction is stable and non-toxic. NOTE: 1. When applying pressure sensitive adhesive films to any surface, be sure that the surface is free from oil or other surface contaminates such as powder, dust, or release agents. Adhesive performance should be carefully checked when used on substrates containing plasticizers. 2. The above values are “Typical Values” which have a nominal range about them and are not intended for specification purposes 5/15/12
0.25-5-2045-5 (PK5)
1. 物料型号:2045-5 2. 器件简介:Super Slick Tape 2045-5是由PTFE(聚四氟乙烯)薄膜制成的,涂有高温硅酮胶粘剂。 3. 应用信息:通常用作包装设备和热封机上的优良释放表面,塑料延长器上的卷材覆盖,以及在图形艺术行业中的导向轨和角铁。 4. 技术特性: - 基材:PTFE薄膜 - 胶粘剂类型:硅酮 - 总厚度:0.0065英寸 - 基材厚度:0.005英寸 - 胶粘剂厚度:0.0015英寸 - 对钢的粘附力:40盎司/英寸 - 伸长率:400% - 工作温度:-100至500摄氏度 - 颜色:灰色 - 介电强度:13000伏特 5. 特性/优势:2045-5的一面有硅酮压敏胶,另一面提供低摩擦系数的PTFE薄膜,该薄膜薄且可塑。PTFE基材提供出色的高温抵抗力,并且化学性质稳定。2045-5的胶带结构稳定且无毒。 6. 注意事项:在任何表面上应用压敏胶膜时,请确保表面无油或其他表面污染物,如粉末、灰尘或脱模剂。在使用含有增塑剂的基材时,应仔细检查胶粘性能。上述值是“典型值”,具有名义范围,不适用于规格目的。
0.25-5-2045-5 (PK5) 价格&库存
很抱歉,暂时无法提供与“0.25-5-2045-5 (PK5)”相匹配的价格&库存,您可以联系我们找货
