1.375-36-204-10
1.375-36-204-10
    TAPECASE
    204-10 GRAY CONFORMABLE TAPE MAD
1.375-36-204-10 数据手册
TapeCase Ltd. 1982 Lunt Ave, Elk Grove Village, IL 60007 phone: (847) 299-7880 fax: (847) 299-7804 www.tape case.com sale s@t apeca se.com Conformable Tape Made with Teflon PTFE 204-10 Product Description This product is a pressure sensitive tape using skived PTFE film with “high temperature” silicone adhesive. Application Information This tape is used in electrical applications such as coil wraps, separators, transformer, slot liners, and harness wrapping where good insulation and heat resistant properties are needed. They are also used in mechanical applications requiring high temperature resistance, a low friction surface or a non-stick surface. Technical Properties Property Test Method Backing Material Backing Thickness (in) Adhesive System Adhesive Thickness (in) Adhesion (oz/in) ASTM-D-1000 Tensile Strength (lb/in) ASTM-D-3759 Elongation (%) ASTM-D-3759 Dielectric Strength (volts) ASTM-D-149 Max Operating Temperature (F) Government Specification MIL-I-23594C, Type 1 Characteristic PTFE Film 0.010 Silicone 0.0015 55 60 300 20000 500 Pass NOTE: 1. When applying pressure sensitive adhesive films to any surface, be sure that the surface is free from oil or other surface contaminates such as powder, dust, or release agents. Adhesive performance should be carefully checked when used on substrates containing plasticizers. 2. The above values are “Typical Values” which have a nominal range about them and are not intended for specification purposes 5/15/12
1.375-36-204-10 价格&库存
很抱歉,暂时无法提供与“1.375-36-204-10”相匹配的价格&库存,您可以联系我们找货
