1.625-36-204-3
1.625-36-204-3
    TAPECASE
    204-3 GRAY SUPER SLICK TAPE MADE
1.625-36-204-3 数据手册
TapeCase Ltd. 1982 Lunt Ave, Elk Grove Village, IL 60007 phone: (847) 299-7880 fax: (847) 299-7804 www.tape case.com sale s@t apeca se.com Conformable Tape Made with Teflon PTFE 204-3 Product Description This product is a pressure sensitive tape using skived PTFE film with “high temperature” silicone adhesive. This is a UL recognized component (UL File no. E179854). Application Information This tape is used in electrical applications such as coil wraps, separators, transformer, slot liners, and harness wrapping where good insulation and heat resistant properties are needed. They are also used in mechanical applications requiring high temperature resistance, a low friction surface or a non-stick surface. Technical Properties Property Test Method Backing Material Backing Thickness (in) Adhesive System Adhesive Thickness (in) Adhesion (oz/in) ASTM-D-1000 Tensile Strength (lb/in) ASTM-D-3759 Elongation (%) ASTM-D-3759 Dielectric Strength (volts) ASTM-D-149 Max Operating Temperature (F) U.L. Approval File no. E17854 Government Specification MIL-I-23594C, Type 1 Characteristic PTFE Film 0.003 Silicone 0.003 40 18 300 11000 500 Approved- Flame Retardant/ Cold Resistant Pass NOTE: 1. When applying pressure sensitive adhesive films to any surface, be sure that the surface is free from oil or other surface contaminates such as powder, dust, or release agents. Adhesive performance should be carefully checked when used on substrates containing plasticizers. 2. The above values are “Typical Values” which have a nominal range about them and are not intended for specification purposes 5/15/12
1.625-36-204-3
1. 物料型号:204-3 2. 产品描述:这是一种使用刮削聚四氟乙烯(PTFE)薄膜和“高温”硅酮胶的压力敏感胶带。这是一个UL认可的组件(UL文件编号E179854)。 3. 应用信息:该胶带用于电气应用,如线圈包裹、分隔器、变压器、槽衬和束线包装,这些应用需要良好的绝缘和耐热性能。它们也用于需要高温抗性、低摩擦表面或不粘表面的机械应用。 4. 技术特性: - 基材:PTFE薄膜 - 基材厚度:0.003英寸 - 胶粘系统:硅酮 - 胶粘厚度:0.003英寸 - 粘附力:40盎司/英寸 - 拉伸强度:18磅/英寸 - 伸长率:300% - 介电强度:11000伏特 - 最大工作温度:500℉ - UL认证:文件编号E17854 - 阻燃/耐冷 - 政府规格:MIL-1-23594C, 类型1 - 通过 5. 注意事项: - 应用压敏胶膜到任何表面时,确保表面无油或其他表面污染物,如粉末、灰尘或脱模剂。在含有增塑剂的基材上使用时,应仔细检查胶粘性能。 - 上述值是“典型值”,具有名义范围,不适用于规格目的。
1.625-36-204-3 价格&库存
很抱歉,暂时无法提供与“1.625-36-204-3”相匹配的价格&库存,您可以联系我们找货
