TapeCase Ltd.
1982 Lunt Ave, Elk Grove Village, IL 60007
phone: (847) 299-7880
fax: (847) 299-7804
www.tape case.com
sale s@t apeca se.com
Conformable Tape Made with Teflon PTFE
204-3
Product Description
This product is a pressure sensitive tape using skived PTFE film with “high temperature”
silicone adhesive. This is a UL recognized component (UL File no. E179854).
Application Information
This tape is used in electrical applications such as coil wraps, separators, transformer, slot liners,
and harness wrapping where good insulation and heat resistant properties are needed. They are
also used in mechanical applications requiring high temperature resistance, a low friction surface
or a non-stick surface.
Technical Properties
Property
Test Method
Backing Material
Backing Thickness (in)
Adhesive System
Adhesive Thickness (in)
Adhesion (oz/in)
ASTM-D-1000
Tensile Strength (lb/in)
ASTM-D-3759
Elongation (%)
ASTM-D-3759
Dielectric Strength (volts)
ASTM-D-149
Max Operating Temperature (F)
U.L. Approval
File no. E17854
Government Specification
MIL-I-23594C, Type 1
Characteristic
PTFE Film
0.003
Silicone
0.003
40
18
300
11000
500
Approved- Flame Retardant/ Cold Resistant
Pass
NOTE:
1.
When applying pressure sensitive adhesive films to any surface, be sure that the surface is free from oil or other surface
contaminates such as powder, dust, or release agents. Adhesive performance should be carefully checked when used on
substrates containing plasticizers.
2.
The above values are “Typical Values” which have a nominal range about them and are not intended for specification purposes
5/15/12
很抱歉,暂时无法提供与“0.25-5-204-3 (PK5)”相匹配的价格&库存,您可以联系我们找货
