0.125-36-2302-10 (PK2) 数据手册
TapeCase Ltd.
1982 Lunt Ave, Elk Grove Village, IL 60007
phone: (847) 299-7880
fax: (847) 299-7804
www.tape case.com
sale s@t apeca se.com
Strong & Slippery UHMW Polyethylene
Tape with Super Bond Adhesive
2302-10
Product Description
2302-10 is manufactured from UHMW (Ultra High Molecular Weight) polyolefin film coated
with an acrylic adhesive.
Application Information
2302-10 can be used to provide abrasion resistant, anti-stick, anti-friction surface at high
temperatures up to 225°F. It is frequently used to line chutes and conveyors. The product is often
applied to guide rails to reduce noise levels in glass bottling plants. This tape is also used to
replace desk drawer bearings, and to provide silky smooth, friction free drawer movement.
Technical Properties
Property
Backing Material
Adhesive Type
Total Thickness (in.)
Backing Thickness (in)
Adhesive Thickness (in.)
Tensile Strength (lbs/in)
Adhesion to Steel (oz/in)
Elongation (% at break)
Operating Temperature (F)
Color
Dielectric Strength (volts)
Characteristic
Film-UHMW
Acrylic
0.0115
0.01
0.0015
80
50
425
-40 to 225
Natural
N/A
Features/ Benefits
2302-10 exhibits excellent abrasion resistance and a low coefficient of friction, making it an
excellent protection for surfaces or bearings that experience heavy wear. It is more economical
than PTFE tapes. The high-temperature, high-tack acrylic adhesive adheres readily to most dry,
clean surfaces- firmly anchoring the product in place.
B – 01/13/2006
TapeCase Ltd.
fax: (847) 299-7804
www.tape case.com
Available Sizes
Width
1”
2”
6”
Length
Available Core Size: 1.5”
5 yd.
NOTE:
1.
When applying pressure sensitive adhesive films to any surface, be sure that the surface is free from oil or other surface
contaminates such as powder, dust, or release agents. Adhesive performance should be carefully checked when used on
substrates containing plasticizers.
2.
The above values are “Typical Values” which have a nominal range about them and are not intended for specification purposes
B – 01/13/2006
0.125-36-2302-10 (PK2) 价格&库存
很抱歉,暂时无法提供与“0.125-36-2302-10 (PK2)”相匹配的价格&库存,您可以联系我们找货
