3-5-2302-20
    TAPECASE
    2302-20 NATURAL STRONG & SLIPPER
3-5-2302-20 数据手册
TapeCase Ltd. 1982 Lunt Ave, Elk Grove Village, IL 60007 phone: (847) 299-7880 fax: (847) 299-7804 www.tape case.com sale s@t apeca se.com Strong & Slippery UHMW Polyethylene Tape with Super Bond Adhesive - 2302-20 Product Description 2302-20 is manufactured from UHMW (Ultra High Molecular Weight) polyolefin film coated with an acrylic adhesive. Application Information 2302-20 can be used to provide abrasion resistant, anti-stick, anti-friction surface at high temperatures up to 225°F. It is frequently used to line chutes and conveyors. The product is often applied to guide rails to reduce noise levels in glass bottling plants. This tape is also used to replace desk drawer bearings, and to provide silky smooth, friction free drawer movement. Technical Properties Property Backing Material Adhesive Type Total Thickness (in.) Backing Thickness (in) Adhesive Thickness (in.) Tensile Strength (lbs/in) Adhesion to Steel (oz/in) Elongation (% at break) Operating Temperature (F) Color Dielectric Strength (volts) Characteristic Film-UHMW Acrylic 0.0215 0.020 0.0015 145 50 500 -40 to 225 Natural N/A Features/ Benefits 2302-20 exhibits excellent abrasion resistance and a low coefficient of friction, making it an excellent protection for surfaces or bearings that experience heavy wear. It is more economical than PTFE tapes. The high-temperature, high-tack acrylic adhesive adheres readily to most dry, clean surfaces- firmly anchoring the product in place. NOTE: 1. When applying pressure sensitive adhesive films to any surface, be sure that the surface is free from oil or other surface contaminates such as powder, dust, or release agents. Adhesive performance should be carefully checked when used on substrates containing plasticizers. 2. The above values are “Typical Values” which have a nominal range about them and are not intended for specification purposes 5/15/12
3-5-2302-20
物料型号:2302-20
器件简介:2302-20是由超高分子量(UHMW)聚烯烃薄膜涂覆丙烯酸胶粘剂制成的胶带。
引脚分配:文档中未提及引脚分配,因为这是一个胶带产品,不是电子元件。
参数特性: - 基材:UHMW薄膜 - 胶粘剂类型:丙烯酸 - 总厚度:0.0215英寸 - 基材厚度:0.020英寸 - 胶粘剂厚度:0.0015英寸 - 拉伸强度:145磅/英寸 - 对钢的粘附力:50盎司/英寸 - 伸长率:500% - 工作温度范围:-40至225°F - 颜色:自然色 - 介电强度:不适用(N/A)
功能详解:2302-20胶带具有出色的耐磨性和低摩擦系数,适用于需要承受严重磨损的表面或轴承的保护。它比聚四氟乙烯(PTFE)胶带更经济。耐高温、高粘性的丙烯酸胶粘剂容易粘附在大多数干燥、清洁的表面上,牢固地固定产品。
应用信息:2302-20可用于提供高温下耐磨、抗粘、抗摩擦的表面,最高温度可达225°F。它经常用于衬里溜槽和传送带。该产品通常应用于导轨上,以降低玻璃瓶装工厂的噪音水平。这种胶带也用于替代书桌抽屉轴承,提供丝般光滑、无摩擦的抽屉运动。
3-5-2302-20 价格&库存
很抱歉,暂时无法提供与“3-5-2302-20”相匹配的价格&库存,您可以联系我们找货
