1.125-36-403-5BNC
1.125-36-403-5BNC
    TAPECASE
    403-5BNC BLACK ANTISTATIC UHMW P
1.125-36-403-5BNC 数据手册
TapeCase Ltd. 1982 Lunt Ave, Elk Grove Village, IL 60007 phone: (847) 299-7880 fax: (847) 299-7804 www.tape case.com sale s@t apeca se.com Antistatic UHMW Polyethylene Tape 403-5 BNC Product Description This product is a pressure sensitive tape using a black, non-conductive ultra high molecular weight (UHMW) polyethylene film with an aggressive elastomeric adhesive. The UHMW film provides an excellent low friction, non-stick surface, in many ways similar to PTFE. The film has a very high tensile strength and very tough and abrasion resistant. Application Information These tapes are used primarily in mechanical applications such as chute liners, wear pads and guide rails. They are also used as guide surfaces or pads on such items as a computer mouse. Technical Properties Property Backing Material Backing Thickness (in) Adhesive System Adhesive Thickness (in) Adhesion (oz/in) Tensile Strength (lb/in) Elongation (%) Max Operating Temperature (F) Test Method ASTM-D-1000 ASTM-D-3759 ASTM-D-3759 Characteristic Black UHMW Film 0.005 Elastomeric 0.005 90 30 300 200 NOTE: 1. When applying pressure sensitive adhesive films to any surface, be sure that the surface is free from oil or other surface contaminates such as powder, dust, or release agents. Adhesive performance should be carefully checked when used on substrates containing plasticizers. 2. The above values are “Typical Values” which have a nominal range about them and are not intended for specification purposes 5/15/12
1.125-36-403-5BNC
1. 物料型号:防静电UHMW聚乙烯胶带403-5 BNC。 2. 器件简介:这是一种使用黑色、非导电的超高分子量聚乙烯(UHMW)薄膜制成的压敏胶带,具有强烈的弹性粘合剂。UHMW薄膜提供了优异的低摩擦、非粘表面,类似于PTFE。薄膜具有非常高的拉伸强度,非常坚韧且耐磨损。 3. 引脚分配:文档中未提及引脚分配信息。 4. 参数特性: - 基材:黑色UHMW薄膜。 - 基材厚度:0.005英寸。 - 粘合剂系统:弹性。 - 粘合剂厚度:0.005英寸。 - 粘合力:90盎司/英寸。 - 拉伸强度:30磅/英寸。 - 伸长率:300%。 - 最大工作温度:200°F。 5. 功能详解:胶带主要用于机械应用,如溜槽衬里、耐磨垫和导向轨。它们也用作计算机鼠标等物品的导向面或垫。 6. 应用信息:胶带主要用于机械应用,如溜槽衬里、耐磨垫和导向轨,也用作计算机鼠标的导向面或垫。 7. 封装信息:文档中未提供封装信息
1.125-36-403-5BNC 价格&库存
很抱歉,暂时无法提供与“1.125-36-403-5BNC”相匹配的价格&库存,您可以联系我们找货
