TapeCase Ltd.
1982 Lunt Ave, Elk Grove Village, IL 60007
phone: (847) 299-7880
fax: (847) 299-7804
www.tape case.com
sale s@t apeca se.com
Antistatic UHMW Polyethylene Tape
403-5 BNC
Product Description
This product is a pressure sensitive tape using a black, non-conductive ultra high molecular
weight (UHMW) polyethylene film with an aggressive elastomeric adhesive. The UHMW film
provides an excellent low friction, non-stick surface, in many ways similar to PTFE. The film
has a very high tensile strength and very tough and abrasion resistant.
Application Information
These tapes are used primarily in mechanical applications such as chute liners, wear pads and
guide rails. They are also used as guide surfaces or pads on such items as a computer mouse.
Technical Properties
Property
Backing Material
Backing Thickness (in)
Adhesive System
Adhesive Thickness (in)
Adhesion (oz/in)
Tensile Strength (lb/in)
Elongation (%)
Max Operating Temperature (F)
Test Method
ASTM-D-1000
ASTM-D-3759
ASTM-D-3759
Characteristic
Black UHMW Film
0.005
Elastomeric
0.005
90
30
300
200
NOTE:
1.
When applying pressure sensitive adhesive films to any surface, be sure that the surface is free from oil or other surface
contaminates such as powder, dust, or release agents. Adhesive performance should be carefully checked when used on
substrates containing plasticizers.
2.
The above values are “Typical Values” which have a nominal range about them and are not intended for specification purposes
5/15/12
很抱歉,暂时无法提供与“0.375-36-403-5BNC”相匹配的价格&库存,您可以联系我们找货
