6-36-423-3
6-36-423-3
    TAPECASE
    423-3 WHITE STRONG & SLIPPERY UH
6-36-423-3 数据手册
TapeCase Ltd. 150 Gaylord Street, Elk Grove Village, IL 60007 phone: (847) 299-7880 fax: (847) 299-7804 www. tapecase. com sales@tapecase. com Strong & Slippery UHMW Polyethylene Tape 423-3 Product Description This product is a pressure sensitive tape using Ultra High Molecular Weight Polyethylene (UHMW) film with an aggressive permanent acrylic adhesive. The UHMW film provides an excellent low friction, non-stick surface in many ways similar to PTFE. The film has a very high tensile strength and is very tough and abrasion resistant. Application Information This tape has two primary applications in automotive and mechanical. The 423 series has passed a series of automotive tests for use by GM, Ford and Daimler-Chrysler. Mechanical applications include chute liners, wear pads and guide rails. Technical Properties Property Backing Material Backing Thickness (in) Adhesive System Adhesive Thickness (in) Adhesion (oz/in) Tensile Strength (lb/in) Elongation (%) Dielectric Strength (volts) Max Operating Temperature (F) Automotive Specification Automotive Specification Automotive Specification Test Method ASTM-D-1000 ASTM-D-3759 ASTM-D-3759 ASTM-D-149 Characteristic UHMW Film 0.003 Acrylic 0.002 50 18 300 3000 200 Chrysler MS-CH612 Ford ESB-M3G123B GM 6419M Pass Pass Pass NOTE: 1. When applying pressure sensitive adhesive films to any surface, be sure that the surface is free from oil or other surface contaminates such as powder, dust, or release agents. Adhesive performance should be carefully checked when used on substrates containing plasticizers. 2. The above values are “Typical Values” which have a nominal range about them and are not intended for specification purposes 5/15/12
6-36-423-3
1. 物料型号:UHMW聚乙烯胶带423-3 2. 器件简介:这是一种使用超高分子量聚乙烯(UHMW)薄膜和永久性丙烯酸粘合剂的压力敏感胶带。UHMW薄膜提供了一个低摩擦、非粘性的表面,类似于PTFE。 3. 引脚分配:文档中没有提及引脚分配,因为这是一种胶带产品,不是电子元件。 4. 参数特性: - 基材:UHMW薄膜 - 基材厚度:0.003英寸 - 粘合剂系统:丙烯酸 - 粘合剂厚度:0.002英寸 - 粘合力:50盎司/英寸 - 拉伸强度:18磅/英寸 - 伸长率:300% - 介电强度:3000伏特 - 最高工作温度:200°F 5. 功能详解:胶带在汽车和机械领域有两个主要应用。423系列已通过通用汽车、福特和戴姆勒-克莱斯勒的一系列汽车测试。 6. 应用信息:机械应用包括溜槽衬里、耐磨垫和导轨。 7. 封装信息:文档中没有提及封装信息,因为这是一种胶带产品。
6-36-423-3 价格&库存
很抱歉,暂时无法提供与“6-36-423-3”相匹配的价格&库存,您可以联系我们找货
    库存:60
