0.125-5-CTAPE (PK5)
0.125-5-CTAPE (PK5)
    TAPECASE
    OPTICALLY CLEAR TAPE MADE WITH T
0.125-5-CTAPE (PK5) 数据手册
TapeCase Ltd. 1982 Lunt Ave, Elk Grove Village, IL 60007 phone: (847) 299-7880 fax: (847) 299-7804 www.tape case.com sale s@t apeca se.com Optically Clear Tape Made with Teflon FEP “C” Tape Product Description This product is manufactured from clear FEP (fluorinated ethylene propylene) with pressuresensitive, high-temperature silicone adhesive. Application Information This tape is often used for coil and transformer insulation. Due to its transparency, this tape is useful for “see thru” identification on wire harnesses. Technical Properties Property Backing Material Characteristic Film-FEP Adhesive Type Silicone Total Thickness (in.) 0.0035 Backing Thickness (in) 0.002 Adhesive Thickness (in.) 0.0015 Adhesion to Steel (oz/in) 20 Tensile Strength (lb/in) 8 Dielectric Strength (volts) 9000 Dielectric Electrolytic Corr. 1 Elongation (%) 275 Operating Temperature (F) Color -100 to 400 Clear Features/ Benefits “C” Tape is very durable and versatile. The FEP backing offers excellent high temperature resistance and it offers the highest electrical strength in volts per mil. FEP backing is chemically inert, thin and conformable. The tape construction is weather resistant, stable and non-toxic. NOTE: 1. When applying pressure sensitive adhesive films to any surface, be sure that the surface is free from oil or other surface contaminates such as powder, dust, or release agents. Adhesive performance should be carefully checked when used on substrates containing plasticizers. 2. The above values are “Typical Values” which have a nominal range about them and are not intended for specification purposes 5/15/12
0.125-5-CTAPE (PK5)
1. 物料型号:文档中没有明确提到物料型号,但描述了一种使用Teflon FEP材料的光学透明胶带。
2. 器件简介:这是一种由透明FEP(氟化乙烯丙烯)制成的胶带,带有压敏、耐高温的硅橡胶粘合剂。
3. 引脚分配:文档中没有提及引脚分配,因为这是一种胶带产品,不是电子元件。
4. 参数特性: - 基材:FEP薄膜 - 粘合剂类型:硅橡胶 - 总厚度:0.0035英寸 - 基材厚度:0.002英寸 - 粘合剂厚度:0.0015英寸 - 对钢的粘附力:20盎司/英寸 - 拉伸强度:8磅/英寸 - 介电强度:9000伏特 - 介电电解腐蚀:1 - 伸长率:275% - 工作温度范围:-100至400°F - 颜色:透明
5. 功能详解:这种胶带因其透明度,常用于线圈和变压器的绝缘,也适用于线束的“透视”标识。
6. 应用信息:胶带通常用于线圈和变压器的绝缘,并且由于其透明性,适用于线束的透视标识。
7. 封装信息:文档中没有提供封装信息,因为它是胶带,不是电子元件。
8. 注意事项: - 应用压敏胶膜到任何表面时,确保表面无油或其他污染物,如粉末、灰尘或脱模剂。 - 粘合剂性能在使用含有增塑剂的基材时应仔细检查。 - 文档中提到的数值是“典型值”,具有名义范围,不适用于规格目的。
0.125-5-CTAPE (PK5) 价格&库存
很抱歉,暂时无法提供与“0.125-5-CTAPE (PK5)”相匹配的价格&库存,您可以联系我们找货
