1.5-5-MPFT-GREEN
1.5-5-MPFT-GREEN
    TAPECASE
    MPFT-GREEN METALIZED POLYESTER T
1.5-5-MPFT-GREEN 数据手册
TapeCase Ltd. 1982 Lunt Ave, Elk Grove Village, IL 60007 phone: (847) 299-7880 fax: (847) 299-7804 www.tape case.com sale s@t apeca se.com Metalized Polyester Film Tape MPFT Series Product Description 1.0 mil metalized polyester film with brilliant, vibrant mirror-like finish; coated with an aggressive long lasting acrylic adhesive system. Tapes have excellent chemical and thermal stability. Silver can be qualified to meet Federal Specification #L-T-100B, Type II. Applications Reflective Shielding; industrial & graphic arts; decorative trim, automotive trim, nameplates, electric appliances, advertising displays; suitable for micro film splicing; also can be used in photo sensing applications to detect splices and to facilitate roll changeovers. Typical Physical Properties Thickness Adhesive Tensile Adhesion Elongation Temperature 2 mil Acrylic 24 lbs/in. 45 oz/in. 100% -60° - 300° F Available Colors Black, Gold, Red, Green, Blue, Silver Updated on 1/19/2011 4:12:00 PM TapeCase Ltd. 1982 Lunt Ave, Elk Grove Village, IL 60007 phone: (847) 299-7880 fax: (847) 299-7804 www.tape case.com sale s@t apeca se.com Available Sizes Width 1/4" 3/8" 1/2" 3/4" 1" 1.5" 2" 3" 4" 6" Length 72YDS or 5YDS 72YDS or 5YDS 72YDS or 5YDS 72YDS or 5YDS 72YDS or 5YDS 72YDS or 5YDS 72YDS or 5YDS 72YDS or 5YDS 72YDS or 5YDS 72YDS or 5YDS Available Core Sizes: 1.5”for 5 yd rolls and 3” for 72yd rolls NOTE: 1. When applying pressure sensitive adhesive films to any surface, be sure that the surface is free from oil or other surface contaminates such as powder, dust or release agents. Adhesive performance should be carefully checked when used on substrates containing plasticizers.. 2. The above values are “Typical Values” which have a nominal range about them and are not intended for specification purposes. Updated on 1/19/2011 4:12:00 PM
1.5-5-MPFT-GREEN
1. 物料型号:文档中没有明确列出具体的物料型号,但描述了MPFT系列的通用特性。 2. 器件简介:金属化聚酯薄膜胶带,具有1.0 mil厚度,镜面般的金属光泽,涂有持久的丙烯酸粘合剂,具有出色的化学和热稳定性。 3. 引脚分配:文档中没有提及引脚分配,因为这是关于胶带的产品,而不是电子元件。 4. 参数特性: - 厚度:2 mil - 粘合剂类型:丙烯酸 - 拉伸强度:24 lbs/in. - 粘附力:45 oz/in. - 伸长率:100% - 温度范围:-60°-300°F 5. 功能详解:胶带可用于反射屏蔽、工业和图形艺术、装饰性装饰、汽车装饰、铭牌、电器、广告展示等。也适用于微缩胶片拼接,以及在光感应用中检测拼接和促进卷筒更换。 6. 应用信息:文档中提到了胶带的多种应用场景,包括反射屏蔽、装饰性装饰、广告展示等。 7. 封装信息:提供了胶带的多种尺寸和颜色选项,以及卷芯尺寸信息。
1.5-5-MPFT-GREEN 价格&库存
很抱歉,暂时无法提供与“1.5-5-MPFT-GREEN”相匹配的价格&库存,您可以联系我们找货
