PT6405 1X10
PT6405 1X10
    TAPECASE
    WHITE THERM-A-LECTRIC UHMW TAPE
PT6405 1X10 数据手册
TapeCase Ltd. 1982 Lunt Ave, Elk Grove Village, IL 60007 phone: (847) 299-7880 fax: (847) 299-7804 www.tape case.com sale s@t apeca se.com Product Description PT6405 combines the high abrasion resistance and non stick properties of the Ultra High Molecular Weight Polyethylene with the cushioning of a polyurethane foam backing in an easily applied pressure sensitive form. The tape absorbs shock, dampens noise, and cushions fragile parts when used as a liner for chutes, bins, and delivery systems. The non stick, low friction, UHMWPE surfaces speeds conveying and cleans easily. The acrylic pressure sensitive adhesive applied to the foam backing allows the product to be attached to a broad variety of surfaces. Application Ideas PT6405 absorbs shock, dampens noise, and cushions fragile parts. Technical Data Property Backing Material Adhesive System Adhesive Thickness (in.) Max. Operating Temp (F) Data Conformable, vibration absorbing PU foam Acrylic 0.067 200 NOTE: 1. When applying pressure sensitive adhesive films to any surface, be sure that the surface is free from oil or other surface contaminates such as powder, dust or release agents. Adhesive performance should be carefully checked when used on substrates containing plasticizers.. 2. The above values are “Typical Values” which have a nominal range about them and are not intended for specification purposes. 5/15/12
PT6405 1X10 价格&库存
很抱歉,暂时无法提供与“PT6405 1X10”相匹配的价格&库存,您可以联系我们找货
