Scapa 0485
Rubber Resin Adhesive Strip
DESCRIPTION
Scapa 0485 is a solvent free rubber resin based hot melt adhesive. Scapa 0485 is available in amber in a
strip format supplied on an easily removable liner.
APPLICATIONS
Jointing of plastic sheeting, filter membranes, damp proof membranes etc
Bonding lightweight insulation panels, kickplates etc
Mounting lightweight trim
As a temporary ‘Third Hand’ fix
Bonding of insulation to walls
Joining of plastic sheeting
Fixing of edgings, sheeting, signs and tiles
Fixing roof bars on commercial vehicles
Fixing of carpets, decorative edging and board and trims
PRODUCT BENEFITS
Clean, easy to use alternative to brush on adhesives
Very aggressive pressure sensitive adhesive
Non‐hardening and permanently flexible
Excellent bond strength
No curing time required
Solvent free, therefore no fumes
Forms a strong waterproof bond
Well established product with long term proven success
Pre‐formed to a choice of sizes
Versatile “instant stick” adhesive on a roll
TECHNICAL PROPERTIES
Version: 5
www.scapa.com
Date: 07/04/2016
Page: 1 of 2
Technical Property
Nominal Value
Unit
Test Method
Tack (Rolling Ball Method)
30
mm
55233*
This Technical Data Sheet (TDS) is provided by Scapa for information only. The contents of this TDS are considered to be reliable but accuracy is not guaranteed. The results shown in
this TDS may not be relevant to all users of the product and it is the user’s responsibility to determine the suitability of the product for its intended purpose. Scapa expressly disclaims
Specific Gravity
0.98
g/cm3
55295*
all express or implied warranties including merchantability and fitness for a particular purpose to the fullest extent permitted by law and does not accept responsibility or liability
(whether direct, indirect, or consequential) arising from use of the product or reliance on the TDS. Scapa does not exclude liability for death or personal injury arising from its negligence or
Softening Point (Ring and Ball)
85
°C
55272*
fraud. Scapa refers to Scapa Group plc and its subsidiaries.
Service Temperature
0 ‐ 40
°C
Cohesion
0.6
N mm‐² 55270*
Technical Property
Specific Gravity
Service Temperature
Cohesion
Nominal Value
30
0.98
85
0 ‐ 40
0.6
Unit
mm
g/cm3
°C
°C
N mm‐²
Test Method
55233*
55295*
55272*
55270*
STANDARD PRESENTATIONS
Roll Width: 12mm, 19mm, 25mm, 38mm, 50mm
Packaging: Bulk packed
Core: 76mm plain
Note:
Note: Information on stock items, non‐standard sizes, and lead times is available on request
RECOMMENDATIONS
It is recommended that this product is applied at temperatures over 10º C To aid the cutting of 0485, it is
advisable to dip blades or scissors into water immediately prior to use. The rolls should be stored flat on
their cut edges in the original packaging, until required for use. The product must be protected from dust,
heat, moisture, direct sunlight and solvent fumes. Service life will vary with conditions of use and is affected
by climatic environment, but should not be less than one year from date of manufacture, if stored in a
moderate climate and good conditions.
Version: 5
Date: 07/04/2016
Page: 2 of 2
www.scapa.com
很抱歉,暂时无法提供与“1/2-0312-32-485”相匹配的价格&库存,您可以联系我们找货
