0.125-5-SG05-03 (PK10)
    TAPECASE
    SG05-03 BROWN TAPE MADE WITH TEF
0.125-5-SG05-03 (PK10) 数据手册
TapeCase Ltd. 1982 Lunt Ave, Elk Grove Village, IL 60007 phone: (847) 299-7880 fax: (847) 299-7804 www.tape case.com sale s@t apeca se.com Tape Made with Teflon PTFE SG05-03 Product Description SG05-03 is a fiberglass fabric impregnated with PTFE (polytetraflouroethylene) dispersion and coated with high-temperature, pressure-sensitive silicone adhesive Application Information SG05-03 is frequently used by the packaging industry as a release surface on heat sealers, blister formation and form-fill-seal equipment. The durability and anti-stick properties of SG05-03 make it an ideal material for the lining of guide rails, chutes, and slides. The high temperature capabilities and non-stick properties of SG05-03 allow it to perform as an excellent release surface in the composite aircraft industry. Technical Properties Property Backing Material Characteristic PTFE-Coated Fiberglass Fabric Adhesive Type Super Stick Silicone Total Thickness (in.) 0.0047 Backing Thickness (in) 0.003 Adhesive Thickness (in.) 0.0017 Adhesion to Steel (oz/in) 45 Elongation (% at break)
物料型号:SG05-03
器件简介:SG05-03是一种用PTFE(聚四氟乙烯)分散液浸渍的玻璃纤维布,并涂有高温、压敏型硅胶。
引脚分配:文档中未提及引脚分配,因为这是一种胶带材料,不是电子元件。
参数特性: - 基材:PTFE涂层玻璃纤维布 - 胶粘剂类型:超强粘性硅胶 - 总厚度:0.0047英寸 - 基材厚度:0.003英寸 - 胶粘剂厚度:0.0017英寸 - 对钢的粘附力:45盎司/英寸 - 伸长率:断裂时小于5% - 工作温度范围:-100至500°F - 颜色:棕色
功能详解:SG05-03因其耐用性和多功能性而受到青睐。PTFE、玻璃纤维和高温硅胶的结合使其能在高达500°F的连续温度下工作。SG05-03尺寸稳定,抗撕裂、抗穿刺、耐磨损。它在重载下不会发生“冷流”。
应用信息:SG05-03通常被包装行业用作热封机、泡罩成型和成型-填充-封口设备上的释放表面。SG05-03的耐用性和抗粘性能使其成为导轨、滑槽和滑道内衬的理想材料。SG05-03的高温能力和不粘特性使其在复合飞机行业中作为出色的释放表面。
封装信息:文档中未提及封装信息,因为这是一种胶带,不是电子元件。
0.125-5-SG05-03 (PK10) 价格&库存
很抱歉,暂时无法提供与“0.125-5-SG05-03 (PK10)”相匹配的价格&库存,您可以联系我们找货
