TapeCase Ltd.
1982 Lunt Ave, Elk Grove Village, IL 60007
phone: (847) 299-7880
fax: (847) 299-7804
www.tape case.com
sale s@t apeca se.com
Tape Made with Teflon PTFE
SG05-10
Product Description
SG05-10 is a fiberglass fabric impregnated with PTFE (polytetraflouroethylene) dispersion and
coated with high-temperature, pressure-sensitive silicone adhesive
Application Information
SG05-10 is frequently used by the packaging industry as a release surface on heat sealers, blister
formation and form-fill-seal equipment. The durability and anti-stick properties of SG05-10
make it an ideal material for the lining of guide rails, chutes, and slides. The high temperature
capabilities and non-stick properties of SG05-10 allow it to perform as an excellent release
surface in the composite aircraft industry.
Technical Properties
Property
Backing Material
Characteristic
PTFE-Coated Fiberglass Fabric
Adhesive Type
Super Stick Silicone
Total Thickness (in.)
0.0117
Backing Thickness (in)
0.0100
Adhesive Thickness (in.)
0.0017
Adhesion to Steel (oz/in)
60
Elongation (% at break)
很抱歉,暂时无法提供与“11-36-SG05-10”相匹配的价格&库存,您可以联系我们找货
