12-36-SG05-10
12-36-SG05-10
    TAPECASE
    SG05-10 BROWN TAPE MADE WITH TEF
12-36-SG05-10 数据手册
TapeCase Ltd. 1982 Lunt Ave, Elk Grove Village, IL 60007 phone: (847) 299-7880 fax: (847) 299-7804 www.tape case.com sale s@t apeca se.com Tape Made with Teflon PTFE SG05-10 Product Description SG05-10 is a fiberglass fabric impregnated with PTFE (polytetraflouroethylene) dispersion and coated with high-temperature, pressure-sensitive silicone adhesive Application Information SG05-10 is frequently used by the packaging industry as a release surface on heat sealers, blister formation and form-fill-seal equipment. The durability and anti-stick properties of SG05-10 make it an ideal material for the lining of guide rails, chutes, and slides. The high temperature capabilities and non-stick properties of SG05-10 allow it to perform as an excellent release surface in the composite aircraft industry. Technical Properties Property Backing Material Characteristic PTFE-Coated Fiberglass Fabric Adhesive Type Super Stick Silicone Total Thickness (in.) 0.0117 Backing Thickness (in) 0.0100 Adhesive Thickness (in.) 0.0017 Adhesion to Steel (oz/in) 60 Elongation (% at break)
12-36-SG05-10
1. 物料型号:SG05-10 2. 器件简介:SG05-10是用于包装行业作为热封机、泡罩成型和填充封口设备的释放表面,具有耐用性和抗粘性,适合作为导轨、滑槽和滑道的内衬材料。在复合飞机行业中,SG05-10的高温能力和不粘特性使其成为出色的释放表面。 3. 引脚分配:文档中未提及引脚分配,因为SG05-10是一种材料,不是电子元件。 4. 参数特性: - 基材:PTFE涂层玻璃纤维布 - 粘合剂类型:超粘硅胶 - 总厚度:0.0117英寸 - 基材厚度:0.0100英寸 - 粘合剂厚度:0.0017英寸 - 对钢的粘附力:60盎司/英寸 - 伸长率(断裂时):<5% - 工作温度:-100至500°F - 颜色:棕色 5. 功能详解:SG05-10非常耐用且多功能,PTFE、玻璃纤维和高温硅胶粘合剂的组合使其能在高达500°F的连续温度下工作。SG05-10尺寸稳定,抗撕裂、抗穿刺、耐磨损。它在重载下不会“冷流”。 6. 应用信息:SG05-10常用于包装行业,也适用于复合飞机行业。 7. 封装信息:文档中未提及封装信息,因为SG05-10是一种材料,不是电子元件。
12-36-SG05-10 价格&库存
很抱歉,暂时无法提供与“12-36-SG05-10”相匹配的价格&库存,您可以联系我们找货
