10-18-SG56-03
10-18-SG56-03
    TAPECASE
    SG56-03 BLACK SEMI CONDUCTIVE AB
10-18-SG56-03 数据手册
TapeCase Ltd. 1982 Lunt Ave, Elk Grove Village, IL 60007 phone: (847) 299-7880 fax: (847) 299-7804 www.tape case.com sale s@t apeca se.com Semi Conductive Abrasion Resistant Fiberglass Tape Coated with Teflon PTFE SG56-03 Product Description SG56-03 is a fiberglass fabric impregnated with PTFE dispersion and coated with high temperature, pressure sensitive silicone adhesive. Application Ideas SG56-03 is frequently used by the packaging industry as a release surface on heat-sealers, blister formation and form-fill seal equipment. The durability and anti-stick properties of this tape also make it an ideal material for the lining of guide rails, chutes, and slides. The high temperature capabilities and the non stick properties allow it to perform as an excellent release surface in the composite aircraft industry. Technical Data 5 mil Version Property Backing Material Backing Thickness Adhesive System Adhesive Thickness (in.) Adhesion (oz/in.) Color Elongation Operating Temperature Data PTFE - Coated Fiberglass Fabric 0.003 Clean Release Silicone 0.002 45 Black
10-18-SG56-03
1. 物料型号:SG56-03 2. 器件简介:这是一种玻璃纤维布,浸渍了PTFE分散液,并涂有高温压敏硅胶粘合剂。 3. 引脚分配:文档中没有提及引脚分配,因为这不是电子元件。 4. 参数特性: - 基材:PTFE涂层玻璃纤维 - 基材厚度:0.003英寸 - 粘合剂系统:清洁释放硅胶 - 粘合剂厚度:0.002英寸 - 粘附力:45盎司/英寸 - 颜色:黑色 - 伸长率:<5% - 工作温度:-100至500°F 5. 功能详解:SG56-03通常用于包装行业,作为热封机、泡罩成型和填充封口设备的释放表面。其耐用性和抗粘附特性也使其成为导轨、滑槽和滑道内衬的理想材料。耐高温特性和非粘附性能使其在复合飞机行业中作为出色的释放表面。 6. 应用信息:SG56-03在包装行业、导轨、滑槽和滑道的内衬以及复合飞机行业中有广泛应用。 7. 封装信息:文档中没有提及封装信息,因为这不是半导体封装。
10-18-SG56-03 价格&库存
很抱歉,暂时无法提供与“10-18-SG56-03”相匹配的价格&库存,您可以联系我们找货
