TC0116W 18MM X 18MM-864 数据手册
TapeCase Ltd.
150 Gaylord S treet, E lk Grove V illage, IL 60007
phone: (847) 299-7880
fax: (847) 299-7804
www.tape case.com
sale s@t apeca se.com
Double Coated Foam Tape with
Permanent Adhesive/Removable Adhesive
TC0116W
General Description
1/16" thick double-sided foam tape that is removable one side and permanent on the other.
Removes from hard, non-delaminating surfaces such as wood, metal, plastic and glass while
offering 4 times the strength of standard removable tape.
The permanent face side is ideal for adhesion to a wide variety of surfaces including glass,
metals, and plastics. Works with hard to stick LSE (low surface energy) substrates such as
powder coat, polyethylene and polypropylene surfaces. The removable side holds well to many
surfaces and provides clean removal without adhesive residue or delamination.
Product Benefits
Permanent adhesive on the face side; repositionable adhesive on the secondary side.
Repositionable side provides clean removal from many surfaces.
Use for interior applications.
Technical Data
TECHNICAL PROPERTIES
Adhesive Type
Backing
Color
Adhesion Strength (lbs/in²)
Rubber
1/16” Polyethylene Foam
White
0.5
NOTE:
1.
When applying pressure sensitive adhesive films to any surface, be sure that the surface is free from oil or other surface
contaminates such as powder, dust, or release agents. Adhesive performance should be carefully checked when used on
substrates containing plasticizers.
2.
The above values are “Typical Values” which have a nominal range about them and are not intended for specification
purposes.
12/06/2019
TC0116W 18MM X 18MM-864 价格&库存
很抱歉,暂时无法提供与“TC0116W 18MM X 18MM-864”相匹配的价格&库存,您可以联系我们找货
