TC0132W 24MM X 24MM SQ-648
    TAPECASE
    TC0132W WHITE 1/32 THICK DOUBLE
TC0132W 24MM X 24MM SQ-648 数据手册
TapeCase Ltd. 150 Gaylord S treet, E lk Grove V illage, IL 60007 phone: (847) 299-7880 fax: (847) 299-7804 www.tape case.com sale s@t apeca se.com Double Coated Foam Tape with Permanent Adhesive/Removable Adhesive TC0132W General Description 1/32" thick double-sided foam tape that is removable one side and permanent on the other. Removes from hard, non-delaminating surfaces such as wood, metal, plastic and glass while offering 4 times the strength of standard removable tape. The permanent face side is ideal for adhesion to a wide variety of surfaces including glass, metals, and plastics. Works with hard to stick LSE (low surface energy) substrates such as powder coat, polyethylene and polypropylene surfaces. The removable side holds well to many surfaces and provides clean removal without adhesive residue or delamination. Product Benefits    Permanent adhesive on the face side; repositionable adhesive on the secondary side. Repositionable side provides clean removal from many surfaces. Use for interior applications. Technical Data TECHNICAL PROPERTIES Adhesive Type Backing Color Adhesion Strength (lbs/in²) Rubber 1/32” Polyethylene Foam White 0.5 NOTE: 1. When applying pressure sensitive adhesive films to any surface, be sure that the surface is free from oil or other surface contaminates such as powder, dust, or release agents. Adhesive performance should be carefully checked when used on substrates containing plasticizers. 2. The above values are “Typical Values” which have a nominal range about them and are not intended for specification purposes. 12/06/2019
TC0132W 24MM X 24MM SQ-648 价格&库存
很抱歉,暂时无法提供与“TC0132W 24MM X 24MM SQ-648”相匹配的价格&库存,您可以联系我们找货
