TC242 18MM X 18MM-864
    TAPECASE
    TC242 WHITE 1/32 THICK PERMANEN
TC242 18MM X 18MM-864 数据手册
TapeCase Ltd. 150 Gaylord St Elk Grove Village, IL 60007 phone: (847) 299 -7880 fax: (847) 299 -7804 www.tapecase.com sales@tapecase.com Double Coated Polyethylene Foam Tape TC242/DFF SERIES General Description 1/32 in. white closed cell, cross linked polyethylene foam coated on both sides with a high performance rubber based adhesive. White kraft liner. Applications      Plastic extrusion Signage Wire raceways Wire mounts Trim Product Benefits      Very high immediate bond strength High shear Adheres well to irregular surfaces Conformable High shear Service temperature -0°F to 150°F Technical Data TECHNICAL PROPERTIES Adhesive Type Backing Color Tensile Strength (psi) S252 Dynamic Shear (psi) S253 180° Peel (oz./in) PSTC-101 Static Shear S217 (PSTC-107*) Probe Tack ASTM D-2979-01 Rubber 1/32” Cross-Linked Closed Cell PE Foam White 70 70 125 15 psi for 100+ hours 975** NOTE: 1. When applying pressure sensitive adhesive films to any surface, be sure that the surface is free from oil or other surface contaminates such as powder, dust, or release agents. Adhesive performance should be carefully checked when used on substrates containing plasticizers. 2. The above values are “Typical Values” which have a nominal range about them and are not intended for specification purposes. 5/15/2012
TC242 18MM X 18MM-864 价格&库存
很抱歉,暂时无法提供与“TC242 18MM X 18MM-864”相匹配的价格&库存,您可以联系我们找货
