TC441 12MM X 12MM-1296
    TAPECASE
    TC441 WHITE 1/16 THICK DOUBLE C
TC441 12MM X 12MM-1296 数据手册
Tape Case Lt d. 150 Gaylord St., Elk Grove, IL 60007 phone : ( 847) 299 - 788 0 fax: ( 847) 299 - 7804 www.tapecase.com sales@tapecase.com TC441 1/16” White Polyethylene Double Coated Removable Removable Foam Tape Product Description TC441 is a 1/16” thick white closed cell, crosslinked polyethylene foam that is coated on both sides with a high performance rubber based removable adhesive with a blue kraft liner. Typical applications: plastic extrusion, signage, wire raceways, wire mounts and trim Features      Die cut compatible High immediate bond Excellent chemical resistance Low compression set Excellent conformability, cushioning & vibration dampening Technical Properties TEST Peel Adhesion Tack Tensile Strength Min Application Temp Max Continuous Use Temp Max Short Term Temp METHOD PSTC-101 ASTM D2979 PSTC-131 VALUE IMPERIAL 12.5 oz/in* 23 oz ** 480 oz/in 55°F 176°F*** 203°F*** VALUE METRIC 0.136 N/mm* 650 gram** 52.4 N/10mm 13°C 80°C*** 95°C*** * Foam Destruction Tack numbers may not be exact values of tack as foam can tear during a tack test. *** The pressure sensitive adhesive used in this tape construction will perform at higher than listed temperatures. The temperature limits are due to the polyolefin foam substrate. ** Application and Storage For Maximum adhesion, bonding surfaces should be clean, dry and free from grease and oils. The firmer the application pressure and the greater the contact area, the stronger the bond. Bond strengths will increase as a function of time as the adhesive continues to wet out the bonding surfaces. Note: All statements, technical information and recommendations contained herein are based on tests we believe to be reliable, but the accuracy or completeness thereof is not guaranteed, and the following is made in lieu of all warranties, expressed or implied: Seller’s and manufacturer’s only obligation shall be to replace such quantity of the product proved to be defective. Neither seller nor manufacturer shall be liable for any injury, loss, or damage, direct or consequential, arising out of the use of or the inability to use the product. Before using, user shall determine the suitability of the product for his or her intended use, and the user assumes all risk and liability whatsoever in connection therewith. No representative of ours has authority to waive or change the foegoing provisions, but subject to such provisions, our engineers are available to assist purchasers in adapting our products to the needs and circumstances prevailing in their business. 0 8 / 06 / 2 0 13
TC441 12MM X 12MM-1296 价格&库存
很抱歉,暂时无法提供与“TC441 12MM X 12MM-1296”相匹配的价格&库存,您可以联系我们找货
