12-5-VF08B
12-5-VF08B
    TAPECASE
    1/8 THICK BLACK DOUBLE COATED V
12-5-VF08B 数据手册
TapeCase Ltd. 1982 Lunt Ave Elk Grove Village, IL 60007 phone: (847) 299-7880 fax: (847) 299-7804 www.tapecase.com sales@tapecase.com Double Coated Vinyl Foam Tape VF Series PRODUCT DESCRIPTION: Tape VF32 Tape VF16 Tape VF08 1/32 in. (0.8 mm) Double Coated Vinyl Foam Tape 1/16 in. (1.6 mm) Double Coated Vinyl Foam Tape 1/8 in. (3.2 mm) Double Coated Vinyl Foam Tape APPLICATIONS: General purpose mounting and joining. Surfaces and conditions for removal should be tested by the user to determine fitness for the user’s particular purpose. The high degree of conformability of these tapes make them ideal for joining many rough irregular surfaces, and the closed-cell foam can make good water and air seals in certain applications. PHYSICAL PROPERTIES: Adhesive Type Adhesive Carrier Density Temperature Resistance Tensile Strength Water and Humidity Resistance Shelf Life High Tack Acrylic Closed Cell Polyvinyl Chloride Foam 20 lb/ft³ up to 150°F 60 psi Excellent 18 months from DOM COLORS AVAILABLE: White and Black. Black only in 1/8” thickness NOTE: 1. When applying pressure sensitive adhesive films to any surface, be sure that the surface is free from oil or other surface contaminates such as powder, dust, or release agents. Adhesive performance should be carefully checked when used on substrates containing plasticizers. 2. The above values are “Typical Values” which have a nominal range about them and are not intended for specification purposes.
12-5-VF08B
- 物料型号:文档中列出了三种型号的胶带,分别是VF32(1/32英寸,0.8毫米厚)、VF16(1/16英寸,1.6毫米厚)和VF08(1/8英寸,3.2毫米厚)。
- 器件简介:这些胶带是双涂层乙烯基泡沫胶带,适用于一般目的的安装和连接。
- 引脚分配:文档中没有提及引脚分配,因为这是关于胶带的产品,而不是电子元件。
- 参数特性: - 粘合剂类型:高粘度丙烯酸 - 粘合剂载体:闭孔聚氯乙烯泡沫 - 密度:20磅/立方英尺 - 温度抗性:高达150°F - 拉伸强度:60 psi - 水和湿度抵抗力:优秀 - 保质期:从制造日期起18个月
- 功能详解:胶带的高适应性使其非常适合连接许多粗糙不规则的表面,闭孔泡沫在某些应用中可以形成良好的水和气密封。
- 应用信息:适用于一般目的的安装和连接,用户应测试表面和条件以确定是否适合特定用途。
- 封装信息:提供白色和黑色两种颜色,黑色仅提供1/8英寸厚度。
- 注意事项: 1. 应用压敏粘合剂膜到任何表面时,确保表面无油或其他表面污染物,如粉末、灰尘或脱模剂。 2. 文档中提供的是“典型值”,这些值有名义范围,不适用于规格目的。
12-5-VF08B 价格&库存
很抱歉,暂时无法提供与“12-5-VF08B”相匹配的价格&库存,您可以联系我们找货
