HWAVF-27
HWAVF-27
    IDEC(日本和泉)
    紧急停止板
HWAVF-27 数据手册
Switches & Pilot Devices Signaling Lights Switches & Pilot Devices ø22mm - HW Series HW Series — 22mm IEC Style Global Pushbuttons Key features: • Locking lever removable contact blocks • Finger-safe IP20 contacts • Tamperproof construction • All E-stops meet EN60947-5-5, and are compliant with SEMI S2 standards • Worldwide approvals • Easy to assemble • Choice of black plastic or metallic front bezels • LED illumination • Transformer or full voltage • Slow make double break contacts HW: The Best Engineered Switch in the World IDEC’s HW switches are “The best engineered switch in the world” for a reason. Carrying the CE mark, UL, CSA, CCC (Chinese), and TUV approvals, these switches are designed for use in almost any part of the world. File No. E68961 All switches also incorporate mechanically keyed safety locking levers, ensuring correct installation and maintaining safety in high-vibration applications. Certificate No. Certificate No. R50086203_HW_e-stop 2017010305987846 R50391189_HW File No. LR21451 Electrical Specifications Contactors Timers Relays & Sockets Complete with finger-safe contact blocks offering IP20 protection, these 7/8” (22mm) switches include illuminated and non-illuminated pushbuttons, pilot lights, selector switches, and emergency stop switches. Rated Operational Characteristics AC-15: A600 or Ue = 250V, le = 3A (NO, NC, NO-EM, NC-LB) DC-13: P600 or Ue = 125V, le = 1.1A (NO, NC) DC-13: Q600 or Ue = 125V, le = 0.9A (NO-EM, NC-LB) Rated Insulation Voltage 600V Rated Switching Over-Voltage Less than 4kV, conforming to IEC60947-1 Rated Impulse Withstanding Voltage 4kV for contact circuit, 2.5kV for lamp circuit Rated Thermal Current 10 Amp Minimum Switching Capacity 5 mA at 3V AC/DC Electrical Reliability MTBF < 1 fault for 10 million operation cycles (3V DC, 5mA) Lamp Ratings LEDs: 6V/17mA max, 12V & 24V/11mA max, 120 & 240V/10mA max Contact Operation Slow break NC or NO Positive Action Operation (Emergency Stops with NC contacts) 5.5mm to 10mm travel to latch, 45N minimum force to latch 10mm maximum travel, 1,800 operations per hour maximum for a Pushlock Turn Reset 900 operations per hour maximum for a Push-Pull Operating Force Flush and extended pushbuttons—with 1NO or 1NC contact: 6.2±2N (momentary), 7.0±2N (maintained) Additional contacts—1NO or 1NC: +3.2N (momentary), + 3.3N (maintained) Wire Number of Wires Recommended Tightening Torque (Nm) Crimping Terminal Unit Recommended Terminal Torque HW-U Contact Block Solid Wire Stranded Wire 2 1.0 to 1.3 ø0.5 to 1.6 mm (AWG14 to 22) 2 1.0 to 1.3 ø1.7 to 2.0 mm (AWG12) 1 1.2 to 1.3 0.3 to 2.0 mm2 (AWG14 to 22) 2 1.0 to 1.3 2.1 to 3.5 mm2 (AWG12) 1 1.2 to 1.3 2 1.0 to 1.3 Terminal Screw M3.5 Circuit Breakers Mechanical Terminal Blocks Crimping Terminal Illuminated Unit (*1) Solid Wire ø0.5 to 1.6 mm (AWG14 to 22) Stranded Wire 0.3 to 2.0 mm (AWG14 to 22) Crimping Terminal Applicable Wire Size Pilot Light Solid Wire ø0.5 to 1.6 mm (AWG14 to 22) Stranded Wire ø0.3 to 2.0 mm (AWG14 to 22) 2 M3.5 0.6 to 1.0 (M3.0) 1.0 to 1.3 (M3.5) 1. * refers to the lamp terminals of the illuminated push buttons and selector switches. Applicable Wire Size Minimum 1 x 22 AWG, max. 2 x 14 AWG or 1 x 12 AWG Contact Resistance Initial contact resistance of 50mΩ or less Contact Gap 4mm (NO and NC), 2mm (NO-EM and NC-LB) Horsepower Rating Reference Value: 1/4 HP @ 120V (1ø non-reversing), 1HP @ 240V (3ø non-reversing) Contact Material Silver (gold plated contacts available - contact IDEC) Operating Temperature Operation: -25 to +60°C (illuminated -25 to +50°C dome -25 to +55°C) Vibration Resistance 10 to 55Hz, 98m/sec2 (10G) conforming to IEC6068-2-6 Shock Resistance 980m/sec2 (100G) conforming to IEC6068-2-7 Mechanical Life Momentary pushbuttons: 5,000,000 (900 operations per hour), All other switches: 500,000 634 www.IDEC.com 1904032200 Switches & Pilot Devices Standards & Approvals EN60947-1, EN60947-5-1, VDE0660-200, UL508, CSA C22-2 No.14 File No. LR92374 Approvals Registration No. R9551089 (E-stops) Registration No. R50054316 (Dual Pushbuttons) Registration No. J9650511 (Pilot Lights) Registration No. J9551458 (all other switches) Certificate No. 2005010305145656 Electric Shock Protection CSA: pushbuttons and selector switches: A600 pilot lights and illuminated pushbuttons, direct supply pilot lights and illuminated pushbuttons with integral transformer (100/110, 115, 120, 200/220, 230, 240, 380, 400/440, 480V) UL: pushbuttons and selector switches: A600 pilot lights and illuminated pushbuttons, direct supply pilot lights and illuminated pushbuttons with integral transformer (100/110, 115, 120, 200/220, 230, 240, 380, 400/440, 480V) TÜV: pushbuttons and selector switches: A600=P600 (NO, NC)/Q600 (NO-EM, NC-LB) pilot lights and illuminated pushbuttons, direct supply pilot lights and illuminated pushbuttons with integral transformer (100/110, 115, 120, 200/220, 230, 240, 380, 400/440, 480V) Degree of Protection (conforming to IEC60529 and UL50) Class 2 conforming to IEC60664-7 UL Type 1, 4X, 12, 13 1 IP65 (from front of the panel) IP20 (Type HW-U contact block) Pollution Degree (conforming to IEC60947-1) 3 External Short-Circuit Protection 10A 250V fuse conforming to IEC60269-1 Contact Block Type HW-U Rated Insulation Voltage 600V Rated Continuous Current 10A Contact Ratings by Utilization Category IEC 60947-5-1 AC-15 (A600) DC-13 (P600) Characteristics Operational Voltage AC 50/60 Hz Operational Current DC 24V 48V 50V 110V 220V 440V AC-12 Control of resistive loads & solid state loads 10A — 10A 10A 6A 2A AC-15 Control of electromagnetic loads (> 72VA) 10A — 7A 5A 3A 1A DC-12 Control of resistive loads & solid state loads 10A 5A — 2.2A 1.1A — DC-13 Control of electromagnets 5A 2A — 1.1A 0.6A — Relays & Sockets Pushbuttons Illuminated Pushbuttons Selector Switches Illuminated Selector Switches Pushbutton Selectors Signaling Lights Contact Ratings File No. E68961 Switches & Pilot Devices Conforming to Standards ø22mm - HW Series For dimensions, see page 685. Note 1. Except HW2B Timers LED Lamp Ratings (LSTD Type) Model LSTD-6k LSTD-1k Lamp Base LSTD-2k LSTD-H2k LSTD-M4k BA9S/13 Rated Voltage 6V AC/DC 12V AC/DC 24V AC/DC 120V AC 240V AC Voltage Range 6V AC/DC ±10% 12V AC/DC ±10% 24V AC/DC ±10% 120V AC ±5% 240V AC ±5% AC A, R, W: G, S: 17mA 8mA 11mA 11mA 10mA 10mA DC A, R, W: G, S: 14mA 5.5mA 10mA 10mA – – Color Code A (amber), G (green), R (red), S (blue), W (white) Lamp Base Color Same as illumination color Voltage Marking Life (reference value) Contactors Current Draw Die stamped on the base Approx. 50,000 hours (The luminance reduces to 50% the initial intensity when used on complete DC.) A, R, W A, R, W In place of k, specify the Lens/LED Color Code. Terminal Blocks Internal Circuit G, S 1904032200 800-262-IDEC (4332) • USA & Canada Circuit Breakers LED Chip LED Chip LED Chip Protection Diode Protection Protection DiodeDiode Zener Diode Zener Diode Zener Diode 635 Switches & Pilot Devices Switches & Pilot Devices ø22mm - HW Series Contactors Timers Relays & Sockets Signaling Lights Non-Illuminated Round Pushbuttons (Assembled) Round Flush Function Momentary Maintained Plastic Bezel Metal Bezel Plastic Bezel Metal Bezel Operator Only HW1B-M1-j HW4B-M1-j HW1B-M2-j HW4B-M2-j 1NO HW1B-M1F10-j HW4B-M1F10-j HW1B-M2F10-j HW4B-M2F10-j 1NC HW1B-M1F01-j HW4B-M1F01-j HW1B-M2F01-j HW4B-M2F01-j 1NO-1NC HW1B-M1F11-j HW4B-M1F11-j HW1B-M2F11-j HW4B-M2F11-j 2NO HW1B-M1F20-j HW4B-M1F20-j HW1B-M2F20-j HW4B-M2F20-j 2NC HW1B-M1F02-j HW4B-M1F02-j HW1B-M2F02-j HW4B-M2F02-j 2NO-2NC HW1B-M1F22-j HW4B-M1F22-j HW1B-M2F22-j HW4B-M2F22-j Operator Only HW1B-A1-j HW4B-A1-j HW1B-A2-j HW4B-A2-j 1NO HW1B-A1F10-j HW4B-A1F10-j HW1B-A2F10-j HW4B-A2F10-j 1NC HW1B-A1F01-j HW4B-A1F01-j HW1B-A2F01-j HW4B-A2F01-j 1NO-1NC HW1B-A1F11-j HW4B-A1F11-j HW1B-A2F11-j HW4B-A2F11-j 2NO HW1B-A1F20-j HW4B-A1F20-j HW1B-A2F20-j HW4B-A2F20-j 2NC HW1B-A1F02-j HW4B-A1F02-j HW1B-A2F02-j HW4B-A2F02-j 2NO-2NC HW1B-A1F22-j HW4B-A1F22-j HW1B-A2F22-j HW4B-A2F22-j j Button Color Code Color Code Black B Green G Red R Blue S White W Yellow Y 1. 2. 3. 4. 5. 6. 7. In place of j, specify the Button Color Code from table below. For nameplates and accessories, see page 680 and 683. For dimensions, see page 685. For contact assembly part numbers, see page 685. All assembled part numbers in catalog include standard, Finger-Safe (HW-U...) contacts. Operator only models include operator plus button. Additional contact configurations available (up to 6 total contacts). Circuit Breakers Terminal Blocks Round Extended Contacts 636 www.IDEC.com 1904032200 Switches & Pilot Devices ø22mm - HW Series H W 1 B - M 1 F 10 – R Button Colors Bezel 1: Plastic Bezel 4: Metal Bezel Function Contact Arrangement Operator M: Momentary Action A: Maintained Action Terminals 1: Flush 2: Extended 20: 2NO 02: 2NC 22: 2NO-2NC Signaling Lights F: Finger-Safe Spring-Up Contacts Note: Use only for interpreting part numbers. Do not use for developing part numbers. 10: 1NO 01: 1NC 11: 1NO-NC B: Black G: Green R: Red S: Blue W: White Y: Yellow Non-Illuminated Round Pushbuttons (Replacement Parts) Contact Blocks + Mounting Adaptor Safety Lever Lock + Style Anti-Rotation Ring + Operator Anti-Rotation Ring 1NO 1NC FingerSafe Spring-Up Terminal HW-U10-F HW-U01-F HW-U10R-F (early make) HW-U01R-F (late break) Dummy Block Style Button = Buttons Part Number Style Part Number Round Flush HW9Z-RL HW1A-B1-j Use with notched panel cutout to prevent unit rotation. Round Extended HW-DB Operators Contact Block Mounting Adaptor Part Number HW1A-B2-j Plastic Bezel Style HW-CB2C Metal Bezel 1. In place of j, specify the Button Color Code from table. HW1B-M0 Contactors Round Flush/ Extended Momentary Style Completed Unit Timers Contacts + Relays & Sockets Contact Blocks + Switches & Pilot Devices Part Number Structure HW4B-MO 1. Used to mount contact blocks to operator. 2. IDEC strongly recommends using the safety lever lock to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. HW1B-A0 Safety Lever Lock Style Part Number HW4B-AO Color Code Black B Green G Red R Blue S White W Yellow Y Terminal Blocks Maintained j Button Color Code HW9Z-LS Circuit Breakers 1904032200 800-262-IDEC (4332) • USA & Canada 637 Switches & Pilot Devices Switches & Pilot Devices ø22mm - HW Series Relays & Sockets Signaling Lights Non-Illuminated Mushroom Head Pushbuttons (Assembled) ø29mm Mushroom Head Function Timers Momentary Contactors Maintained ø40mm Mushroom Head Contacts Plastic Bezel Metal Bezel Plastic Bezel Metal Bezel Operator Only HW1B-M3-j HW4B-M3-j HW1B-M4-j HW4B-M4-j 1NO HW1B-M3F10-j HW4B-M3F10-j HW1B-M4F10-j HW4B-M4F10-j 1NC HW1B-M3F01-j HW4B-M3F01-j HW1B-M4F01-j HW4B-M4F01-j 1NO-1NC HW1B-M3F11-j HW4B-M3F11-j HW1B-M4F11-j HW4B-M4F11-j 2NO HW1B-M3F20-j HW4B-M3F20-j HW1B-M4F20-j HW4B-M4F20-j 2NC HW1B-M3F02-j HW4B-M3F02-j HW1B-M4F02-j HW4B-M4F02-j 2NO-2NC HW1B-M3F22-j HW4B-M3F22-j HW1B-M4F22-j HW4B-M4F22-j Operator Only HW1B-A3-j HW4B-A3-j HW1B-A4-j HW4B-A4-j 1NO HW1B-A3F10-j HW4B-A3F10-j HW1B-A4F10-j HW4B-A4F10-j 1NC HW1B-A3F01-j HW4B-A3F01-j HW1B-A4F01-j HW4B-A4F01-j 1NO-1NC HW1B-A3F11-j HW4B-A3F11-j HW1B-A4F11-j HW4B-A4F11-j 2NO HW1B-A3F20-j HW4B-A3F20-j HW1B-A4F20-j HW4B-A4F20-j 2NC HW1B-A3F02-j HW4B-A3F02-j HW1B-A4F02-j HW4B-A4F02-j 2NO-2NC HW1B-A3F22-j HW4B-A3F22-j HW1B-A4F22-j HW4B-A4F22-j Terminal Blocks j Button Color Code ø60mm Mushroom Head Function Circuit Breakers Momentary 638 Contacts Plastic Bezel Operator Only HW1B-M5-j* 1NO HW1B-M5F10-j* 1NC HW1B-M5F01-j* 1NO-1NC HW1B-M5F11-j* 2NO HW1B-M5F20-j* 2NC HW1B-M5F02-j* 2NO-2NC HW1B-M5F22-j* Color Code Black B Green G Red R Blue S White W Yellow Y www.IDEC.com In place of j, specify the Button Color Code from table. *60mm mushroom available only in red, green, black, and yellow. For nameplates and accessories, see page 680 and 683. For dimensions, see page 685. For contact assembly part numbers, see page 685. All assembled part numbers in catalog include standard spring-up Finger-Safe (HW-U...) contacts. 7. Operator only models include operator plus button. 8. Additional contact configurations available (up to 6 total contacts). 1. 2. 3. 4. 5. 6. 1904032200 Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices Part Number Structure H W 1 B - M 3 F 10 – R Button Colors Bezel 1: Plastic Bezel 4: Metal Bezel Function (Not available for 60mm mushroom) 10: 1NO 01: 1NC 11: 1NO-NC Operator M: Momentary Action A: Maintained Action 3: ø29mm Mushroom 4: ø40mm Mushroom 5: ø60mm Mushroom (Not available for 60mm jumbo mushroom pushbutton.) Note: Use only for interpreting part numbers. Do not use for developing part numbers. Terminals 20: 2NO 02: 2NC 22: 2NO-2NC F: Finger-Safe Spring-Up Contacts Signaling Lights B: Black G: Green R: Red S: Blue W: White Y: Yellow Contact Arrangement Non-Illuminated Mushroom Head Pushbuttons (Replacement Parts) Contact Blocks + Mounting Adaptor + Safety Lever Lock Operator + Button 1NO 1NC HW-U10-F HW-U01-F HW-U10R-F (early make) HW-U01R-F (late break) Dummy Block HW-DB Style = Completed Unit Buttons Part Number Style HW9Z-LS ø29mm Mushroom Cap Part Number HW1A-B3-j Anti-Rotation Ring Appearance Part Number ø40mm Mushroom Cap HW9Z-RL Contact Block Mounting Adaptor Style Part Number HW1A-B4-j HW1B-M5-j* HW4B-MOL HW4B-AOL 1. In place of j, specify the Button Color Code from table. j Button Color Code Color Code Color Code Black B Blue S Green G White W R Yellow Y Red HW1B-M5 available only in black, red, green and yellow. – Circuit Breakers Maintained Ø60mm Jumbo Mushroom HW1B-A0L Metal Bezel Terminal Blocks 1. Used to mount contact blocks to operator. 2. IDEC strongly recommends using the safety lever lock to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. HW1B-M0L Momentary ø29mm Mushroom ø40mm Mushroom Momentary Plastic Bezel Contactors Operators Style HW-CB2C Timers FingerSafe Spring-Up Terminal + Relays & Sockets Contacts Anti-Rotation Ring Safety Lever Lock Contact Blocks Style + 1. *60mm mushroom operator includes non-removable button (available in red, black, green and yellow only). 2. For nameplates and accessories, see page 680 and 683. 3. For dimensions, see page 685. 1904032200 800-262-IDEC (4332) • USA & Canada 639 Switches & Pilot Devices Switches & Pilot Devices ø22mm - HW Series Relays & Sockets Signaling Lights Non-Illuminated Square Pushbuttons (Assembled) Function Square Flush Square Extended Plastic Bezel Plastic Bezel Operator Only HW2B-M1-j HW2B-M2-j 1NO HW2B-M1F10-j HW2B-M2F10-j 1NC HW2B-M1F01-j HW2B-M2F01-j 1NO-1NC HW2B-M1F11-j HW2B-M2F11-j 2NO HW2B-M1F20-j HW2B-M2F20-j 2NC HW2B-M1F02-j HW2B-M2F02-j 2NO-2NC HW2B-M1F22-j HW2B-M2F22-j Operator Only HW2B-A1-j HW2B-A2-j 1NO HW2B-A1F10-j HW2B-A2F10-j 1NC HW2B-A1F01-j HW2B-A2F01-j 1NO-1NC HW2B-A1F11-j HW2B-A2F11-j 2NO HW2B-A1F20-j HW2B-A2F20-j 2NC HW2B-A1F02-j HW2B-A2F02-j 2NO-2NC HW2B-A1F22-j HW2B-A2F22-j Contacts Timers Momentary Contactors Maintained Color Code Black B Green G Red R Blue S White W Yellow Y In place of j, specify the Button Color Code from table. For nameplates and accessories, see page 680 and 683. For dimensions, see page 685. For contact assembly part numbers, see page 685. Square pushbuttons available in plastic bezel only. All assembled part numbers in catalog include finger-safe spring-up (HW-U...) contacts. 7. Operator only model includes operator and button. 8. Additional contact configurations available (up to 6 total contacts). 1. 2. 3. 4. 5. 6. Circuit Breakers Terminal Blocks j Button Color Code 640 www.IDEC.com 1904032200 Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices Part Number Structure H W 2 B - M 1 F 10 – R Button Colors Function M: Momentary Action A: Maintained Action Contact Arrangement Operator 10: 1NO 01: 1NC F: Finger-Safe Spring-Up Contacts 11: 1NO-NC 1: Flush 2: Extended Terminals 20: 2NO 02: 2NC 22: 2NO-2NC Signaling Lights Note: Use only for interpreting part numbers. Do not use for developing part numbers. B: Black G: Green R: Red S: Blue W: White Y: Yellow Non-Illuminated Square Pushbuttons (Replacement Parts) Contact Blocks Mounting Adaptor + + Safety Lever Lock + Anti-Rotation Ring + Operator + Button = Completed Unit Relays & Sockets Safety Lever Lock Contact Blocks Style 1NO 1NC FingerSafe Spring-Up Terminal HW-U10-F HW-U01-F HW-U10R-F (early make) HW-U01R-F (late break) Dummy Block Style Part Number Square Flush HW2A-B1-j Anti-Rotation Ring HW-DB Style HW9Z-LS Appearance Part Number Square Extended HW2A-B2-j HW9Z-RL Contact Block Mounting Adaptor Part Number HW-CB2C Use with notched panel cutout to prevent unit rotation. Operators Plastic Bezel Momentary Square Flush Extended HW2B-M0 HW2B-A0 1. In place of j, specify the Button Color Code from table. j Button Color Code Color Code Color Code Black B Blue S Green G White W Red R Yellow Y Terminal Blocks 1. Used to mount contact blocks to operator. 2. IDEC strongly recommends using the safety lever lock to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. Maintained Style Contactors Style Buttons Part Number Timers Contacts 1904032200 800-262-IDEC (4332) • USA & Canada Circuit Breakers 2. For nameplates and accessories, see pages 680 and 683. 3. For dimensions, see page 685. 641 Switches & Pilot Devices Switches & Pilot Devices ø22mm - HW Series Ø29mm Head Pushlock Turn Reset Ø40mm Head Pushlock Turn Reset Contacts Plastic Bezel Metal Bezel Plastic Bezel Metal Bezel Operator Only HW1B-V3j† HW4B-V3j† HW1B-V4j† HW4B-V4j† 1NO HW1B-V3F10-j† HW4B-V3F10-j† HW1B-V4F10-j† HW4B-V4F10-j† 1NC HW1B-V3F01-j† HW4B-V3F01-j† HW1B-V4F01-j† HW4B-V4F01-j† 1NO-1NC HW1B-V3F11-j† HW4B-V3F11-j† HW1B-V4F11-j† HW4B-V4F11-j† 2NO HW1B-V3F20-j† HW4B-V3F20-j† HW1B-V4F20-j† HW4B-V4F20-j† 2NC HW1B-V3F02-j† HW4B-V3F02-j† HW1B-V4F02-j† HW4B-V4F02-j† Timers Relays & Sockets Signaling Lights Non-Illuminated E-Stop Pushbuttons (Assembled) Plastic Bezel Metal Bezel Plastic Bezel Metal Bezel Operator Only HW1B-V4R-EMO-2* HW4B-V4R-EMO-2* HW1B-X4R* HW4B-X4R* 1NO HW1B-V4F10-R-EMO-2* HW4B-V4F10-R-EMO-2* HW1B-X4F10-R* HW4B-X4F10-R* 1NC HW1B-V4F01-R-EMO-2* HW4B-V4F01-R-EMO-2* HW1B-X4F01-R* HW4B-X4F01-R* 1NO-1NC HW1B-V4F11-R-EMO-2* HW4B-V4F11-R-EMO-2* HW1B-X4F11-R* HW4B-X4F11-R* 2NO HW1B-V4F20-R-EMO-2* HW4B-V4F20-R-EMO-2* HW1B-X4F20-R* HW4B-X4F20-R* 2NC HW1B-V4F02-R-EMO-2* HW4B-V4F02-R-EMO-2* HW1B-X4F02-R* HW4B-X4F02-R* ø60mm Head Pushlock Turn Reset Circuit Breakers Ø40mm Head Pushlock Key Reset Contacts Terminal Blocks Contactors Ø40mm Head EMO Pushlock Turn Reset Contacts Plastic Bezel Operator Only HW1B-V5R* 1NO HW1B-V5F10-R* 1NC HW1B-V5F01-R* 1NO-1NC HW1B-V5F11-R* 2NO HW1B-V5F20-R* 2NC HW1B-V5F02-R* 642 1. * Available in Red only. 2. † Available in red or yellow. Insert color code in place of j (R: Red, Y: Yellow). 2. For accessories, see page 683. 3. For dimensions, see page 685. 5. For nameplates and shrouds, see page 685. 4. For contact assembly part numbers, see page 685. 7. All HW series E-stops comply with EN60947-5-5, the IEC “E-Stop Addendum to the Low Voltage Directive,” this includes “tamper proof” operation whereby a change of contact state is not possible by “teasing” or “floating” the operator. 8. All assembled part numbers in catalog include standard finger-safe spring-up (HW-U...) contacts. 9. Operator only models include operator and button. 10. Additional contact configurations available (up to 6 total contacts). www.IDEC.com 1904032200 Switches & Pilot Devices ø22mm - HW Series H W 1 B – V 3 F 10 – R – EMO-2 Engraved Button* Bezel EMO-2: EMO switch 1: Plastic Bezel 4: Metal Bezel Function (not available for 60mm V: Pushlock Turn Reset X: Pushlock Key Reset jumbo mushroom) Operator 3: ø29mm Head 4: ø40mm Head 5: ø60mm Head Button Colors Contact Arrangement Terminals 10: 1NO 01: 1NC 11: 1NO-NC F: Finger-Safe Spring-Up R: Red Y: Yellow 20: 2NO 02: 2NC 22: 2NO-2NC Note: some switches only available in red. Signaling Lights Note: Use only for interpreting part numbers. Do not use for developing part numbers. *Option available for red EMO E-Stop only Non-Illuminated E-Stop Pushbuttons (Replacement Parts) Contact Blocks + Mounting Adaptor + + Anti-Rotation Ring + 1NO 1NC FingerSafe Spring-Up Terminal HW-U10-F HW-U01-F HW-U10R-F (early make) HW-U01R-F (late break) Dummy Block HW-DB Style Part Number Appearance Part Number HW9Z-LS HW9Z-RL Use with notched panel cutout to prevent unit rotation. Operators Style Plastic ø29mm Head Pushlock Turn Reset Part Number HW-CB2C Metal red HW1B-V3R HW4B-V3R yellow HW1B-V3Y HW4B-V3Y red HW1B-V4R HW4B-V4R yellow HW1B-V4Y HW4B-V4Y Contactors ø40mm Head Pushlock Turn Reset ø40mm Head EMO Pushlock Turn Reset* HW1B-V4R-EMO-2 HW4B-V4R-EMO-2 HW1B-X4R HW4B-X4R HW1B-V5R – Terminal Blocks 1. Used to mount contact blocks to operator. 2. IDEC strongly recommends using the safety lever lock to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. Completed Unit Anti-Rotation Ring Contact Block Mounting Adaptor Style = Timers Contacts Operator Relays & Sockets Safety Lever Lock Contact Blocks Style Safety Lever Lock Switches & Pilot Devices Part Number Structure ø40mm Head Pushlock Key Reset* ø60mm Head Pushlock Turn Reset* 1904032200 800-262-IDEC (4332) • USA & Canada Circuit Breakers 1. *Available in red only. 2. All E-Stop buttons are not removable from the operator. Note: Determine mounting centers to ensure proper spacing. 643 Switches & Pilot Devices Switches & Pilot Devices ø22mm - HW Series Timers Relays & Sockets Signaling Lights Push Pull & Unibody E-Stop Pushbuttons (Assembled) ø40mm Unibody Pushlock Turn Reset* ø40mm Head Push–Pull Contacts Plastic Bezel Metal Bezel Contacts Plastic Bezel HW1E-BV4F11-R Operator Only (Red) HW1B-Y2R HW4B-Y2R 1NO-1NC Operator Only (Yellow) HW1B-Y2Y HW4B-Y2Y 2NC HW1E-BV4F02-R 1NO HW1B-Y2F10-j† HW4B-Y2F10-j† 1NC HW1B-Y2F01-j† HW4B-Y2F01-j† 1NO-2NC* HW1E-BV412R-TK2093-1 1NO-1NC HW1B-Y2F11-j† HW4B-Y2F11-j† 2NC HW1B-Y2F02-j† HW4B-Y2F02-j† 2NO HW1B-Y2F20-j† HW4B-Y2F20-j† * NO contact is used as a monitoring contact Circuit Breakers Terminal Blocks Contactors l Full Voltage LED Code Terminal Numbering (Unibody only) Voltage Code Models Terminal Number Unibody Illuminated E-Stops* 6VAC/DC 6V 1NO-1NC NO = 13/14, NC = 11/12 Contacts LED 12VAC/DC 12V 2NC NC = 11/12, NC = 21/22 1NO-1NC HW1E-LV4F11QD-R-l 24VAC/DC 24V 120V AC 120V HW1E-L HW1E-T LED + = X2, LED - = X1 240V AC 240V 2NC HW1E-LV4F02QD-R-l 2NC (with push-on illumination) HW1E-TV4F02QD-R-l 1NO-1NC (with push-on illumination ) HW1E-TV4F11QD-R-l 1. * Available in Red only. 2. † Available in red or yellow. Insert color code in place of j (R: Red, Y: Yellow). 3. In place of l, specify Full Voltage LED Code. 4. With single unit construction, the positive action contacts are integrated in the body of the switch. This provides an extra degree of safety and reliability for critical emergency stop functions. 5. In the illuminated version, the light is independent of the switch action (except push-on LED model). 6. For accessories, see page 683. 7. For dimensions, see page 685. 8. For nameplates and shrouds, see page 683. 9. For contact assembly part numbers, see page 683. 10. All HW Series E-Stop operators include non-removable color caps. 11. All HW series E-Stops comply with EN60947-5-5, the IEC “E-Stop Addendum to the Low Voltage Directive,” this includes “tamper proof” operation whereby a change of contact state is not possible by “teasing” or “floating” the operator. 12. All HW series E-Stop switches comply with SEMI S2 standards. 13. All assembled part numbers in catalog include standard finger-safe spring-up (HW-U...) contacts. 14. Additional contact configurations available (up to 6 total contacts). 644 www.IDEC.com 1904032200 Switches & Pilot Devices ø22mm - HW Series H W 1 E – LV4 F 11 – Q D – R – 24V Bezel 1: Plastic Bezel 4: Metal Bezel* (*not available for HW1E unibody) Full Voltage Code Button Colors (Illuminated E-Stop) Function R: Red Y: Yellow* Lamp Code B: Push Pull E: Unibody Pushlock Turn Reset D: LED (*only available in 40mm Push Pull E-Stop) Illumination Illumination Circuit 6V AC/DC 12V AC/DC 24V AC/DC 120VC AC 240V AC Signaling Lights Contacts BV4: Non-illuminated (unibody style) 11: 1NO-1NC LV4: Illuminated (unibody style) TV4: Illuminated Push On (unibody style) 02: 2NC 10: 1NO Y2: Non-illuminated Push Pull E-Stop 20: 2NO 6V: 12V: 24V: 120V: 240V: Switches & Pilot Devices Part Number Structure blank: 40mm Push Pull & Non-illuminated Unibody E-Stop Q: Illuminated Unibody E-Stop Note: Use only for interpreting part numbers. Do not use for developing part numbers. Illuminated & Non-Illuminated E-Stop Pushbuttons (Replacement Parts) Mounting Adaptor + + Operator 1NO 1NC FingerSafe Spring-Up Terminal HW-U10-F HW-U01-F HW-U10R-F (early make) HW-U01R-F (late break) Style Part Number = Completed Unit Anti-Rotation Ring Appearance Part Number Timers Contacts Dummy Block Anti-Rotation Ring Contact Block Mounting Adaptor Contact Blocks Style + Relays & Sockets Safety Lever Lock HW9Z-RL HW-CB2C 1. There are no replacement parts for the HW1E unibody E-Stop. 2. For illuminated unibody E-Stop, see page 685 for replacement lens. Safety Lever Lock Style Operators Style Part Number ø40mm Head Push-Pull Part Number HW9Z-LS Plastic HW1B-Y2R Metal HW4B-Y2R Plastic HW1B-Y2Y HW4B-Y2Y Terminal Blocks Metal Contactors 1. Used to mount contact blocks to operator. 2. IDEC strongly recommends using the safety lever lock to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. HW-DB Use with notched panel cutout to prevent unit rotation. red + yellow Contact Blocks All E- Stop Buttons are not removable from the operator. Circuit Breakers 1904032200 800-262-IDEC (4332) • USA & Canada 645 Switches & Pilot Devices Switches & Pilot Devices ø22mm - HW Series Relays & Sockets Signaling Lights E-Stop Stations 29mm Pushlock Turn Reset 40mm Pushlock Turn Reset Plastic Bezel Metal Bezel Plastic Bezel Metal Bezel 1NO-1NC FB1W-HW1B-V311R FB1W-HW4B-V311R FB1W-HW1B-V411R FB1W-HW4B-V411R 2NC FB1W-HW1B-V302R FB1W-HW4B-V302R FB1W-HW1B-V402R FB1W-HW4B-V402R Contacts Plastic Bezel Metal Bezel Plastic Bezel Metal Bezel 1NO-1NC FB1W-HW1B-Y211R FB1W-HW4B-Y211R FB1W-HW1B-X411R FB1W-HW4B-X411R 2NC FB1W-HW1B-Y202R FB1W-HW4B-Y202R FB1W-HW1B-X402R FB1W-HW4B-X402R Timers Contacts Terminal Blocks Contactors 40mm Push-Pull Reset 40mm Pushlock Key Reset 40mm EMO Pushlock Turn Reset Contacts Plastic Bezel Metal Bezel 1NO-1NC FB1W-HW1B-V411R-EMO-2 FB1W-HW4B-V411R-EMO-2 2NC FB1W-HW1B-V402R-EMO-2 FB1W-HW4B-V402R-EMO-2 Circuit Breakers 1. Maximum of two contact blocks. 2. Box is supplied with yellow top and black bottom only. 646 www.IDEC.com 1904032200 Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices Jumbo Dome Pilot Lights Actual Size Operator Only HW1P-5Q0 Full Voltage 24V AC/DC HW1P-5Q4-k Signaling Lights Jumbo Dome Plastic Bezel LED 1. In place of k, specify the Lens/LED Color Code. 2. Spring-Up terminals with 24V LED. 3. For nameplates and accessories, see page 680 and 683. 4. For dimensions, see page 685. Relays & Sockets k Lens/LED Color Code Code Amber A Green G Red R Blue S White W Yellow Y Timers Color Jumbo Dome Replacement Parts Item Appearance Description Part Number Lens HW1A-P5k Polycarbonate Lens Contactors LED Diffusing Lens HW9Z-PP5C LED Lamps Jumbo Dome LED Lamp LSTDB-2k 1. In place of k, specify the Lens/LED Color Code. 2 . Use white LED for yellow lens. Terminal Blocks Lamp Ratings LED Part Number Operating Voltage Rated Current LSTDB-2 24V AC/DC ±10% 15mA Power Consumption 0.36W Circuit Breakers 1904032200 800-262-IDEC (4332) • USA & Canada 647 Switches & Pilot Devices Switches & Pilot Devices ø22mm - HW Series Relays & Sockets Signaling Lights Pilot Lights (Assembled) Round Flush Dome Plastic Bezel Metal Bezel Plastic Bezel Metal Bezel Operator Only HW1P-1FQ0-k HW4P-1FQ0-k HW1P-2FQ0-k HW4P-2FQ0-k Full Voltage HW1P-1FQD-k-l HW4P-1FQD-k-l HW1P-2FQD-k-l HW4P-2FQD-k-l 120V AC HW1P-1FH2D-k HW4P-1FH2D-k HW1P-2FH2D-k HW4P-2FH2D-k 240V AC HW1P-1FM4D-k HW4P-1FM4D-k HW1P-2FM4D-k HW4P-2FM4D-k 480V AC HW1P-1FT8D-k HW4P-1FT8D-k HW1P-2FT8D-k HW4P-2FT8D-k 110V DC HW1P-1D2D-k – HW1P-2D2D-k – Transformer Timers DC-DC Converter* Square Flush Contactors Plastic Bezel Operator Only HW2P-1FQ0-k Full Voltage HW2P-1FQD-k-l Transformer DC-DC Converter* 120V AC HW2P-1FH2D-k 240V AC HW2P-1FM4D-k 480V AC HW2P-1FT8D-k 110V DC HW2P-1D2D-k Circuit Breakers Terminal Blocks * DC-DC converter voltage input from 90-140V DC. k Lens/LED Color Code l LED Full Voltage Code Color Code Voltage Code Amber A 6VAC/DC 6V Green G 12VAC/DC 12V Red R 24VAC/DC 24V Blue S 120V AC 120V White W 240V AC 240V Yellow Y 648 1. In place of k, specify the Lens/LED Color Code from table below. 2. In place of lspecify the Full Voltage Code from table below. 3. For nameplates and accessories, see page 680 and 683. 4. For dimensions, see page 685. 5. Pilot lights do not come with anti-rotation ring. 6. Operator models come with operator and lens. 7. Yellow pilot light comes with white LED. www.IDEC.com 1904032200 Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices Part Number Structure H W 1 P – 2 F Q D – R – 12V LED Voltage Bezel 1: Round Plastic 2: Square Plastic 4: Round Metal Operator 1: Flush 2: Dome Illumination Circuit Lens/LED Colors Transformer* A: Amber G: Green R: Red S: Blue W: White Y: Yellow Lamp Type Code D: LED Signaling Lights Q: Full Voltage H2: 120V AC Transformer M4: 240V AC Transformer T8: 480V AC Transformer D2: DC-DC Converter Note: Use only for interpreting part numbers. Do not use for developing part numbers. (full voltage units only) 6V: 6V AC/DC 12V: 12V AC/DC 24V: 24V AC/DC 120V: 120V AC 240V: 240V AC Pilot Lights (Replacement Parts) + LED + Operator + Lens = Completed Unit Relays & Sockets (not applicable for full voltage units) Transformer Units Operators Style Voltage Part Number LED 120V AC HW-FH20 240V AC HW-FM40 480V AC HW-FT80 (6V secondary voltage) Round Flush HW-RD0* Dome Square Flush LED Lamps Part Number 6V AC/DC LSTD-6k 12V AC/DC LSTD-1k 24V AC/DC LSTD-2k 120V AC LSTD-H2k 240V AC LSTD-M4k HW4P-1FQ0 Finger-Safe HW1P-10 HW4P-10 Used for DC-DC convertor only HW1P-100 - Full Voltage Finger-Safe HW1P-2FQ0 HW4P-2FQ0 Transformer Finger-Safe HW1P-20 HW4P-20 Full Voltage Finger-Safe HW2P-1FQ0 – Finger-Safe HW2P-10 – Used for DC-DC convertor only HW2P-100 – Transformer 1. Transformer type requires separate transformer & LED. Must select correct transformer bases. Use 6V LEDs. 2. Full voltage type only requires LED. Lenses Style l Lens Color Code Part Number Round/ Flush HW1A-P1-l k LED Color Code Color Code Color Code Amber A Blue S Green G White W Red R For yellow lens use white LED. Dome HW1A-P2-l Color Code Amber A Green G Red R Blue S White W Yellow Terminal Blocks 1. In place of k, specify the LED Color Code. 2. The LED contains a current-limiting resistor and reverse polarity protection diodes. Metal Bezel HW1P-1FQ0 Contactors LED Voltage Plastic Bezel Finger-Safe Transformer 1. *DC-DC convertor can only be used with HW1P-100 and HW2P-100 operators 2. † DC-DC converter voltage input from 90-140V DC. Style Type Full Voltage Timers 110V DC † Style Y For yellow lens use white LED. HW2A-P1-l Circuit Breakers Square/ Flush In place of l, specify the Lens Color Code. 1904032200 800-262-IDEC (4332) • USA & Canada 649 Switches & Pilot Devices Illuminated Round Pushbuttons (Assembled) Illuminated Full Voltage Pushbuttons Flush Plastic Bezel Extended Extended w/ Full Shroud Metal Bezel Plastic Bezel Metal Bezel Plastic Bezel Metal Bezel Momentary Contacts Operator Only 1NO 1NC 1NO-1NC 2NO HW1L-M1-k HW1L-M1F10QD-k-l HW1L-M1F01QD-k-l HW1L-M1F11QD-k-l HW1L-M1F20QD-k-l HW4L-M1-k HW4L-M1F10QD-k-l HW4L-M1F01QD-k-l HW4L-M1F11QD-k-l HW4L-M1F20QD-k-l HW1L-M2-k HW1L-M2F10QD-k-l HW1L-M2F01QD-k-l HW1L-M2F11QD-k-l HW1L-M2F20QD-k-l HW4L-M2-k HW4L-M2F10QD-k-l HW4L-M2F01QD-k-l HW4L-M2F11QD-k-l HW4L-M2F20QD-k-l HW1L-MF2-k HW1L-MF2F10QD-k-l HW1L-MF2F01QD-k-l HW1L-MF2F11QD-k-l HW1L-MF2F20QD-k-l HW4L-MF2-k HW4L-MF2F10QD-k-l HW4L-MF2F01QD-k-l HW4L-MF2F11QD-k-l HW4L-MF2F20QD-k-l Maintained Timers Relays & Sockets Signaling Lights Switches & Pilot Devices ø22mm - HW Series Operator Only 1NO 1NC 1NO-1NC 2NO HW1L-A1-k HW1L-A1F10QD-k-l HW1L-A1F01QD-k-l HW1L-A1F11QD-k-l HW1L-A1F20QD-k-l HW4L-A1-k HW4L-A1F10QD-k-l HW4L-A1F01QD-k-l HW4L-A1F11QD-k-l HW4L-A1F20QD-k-l HW1L-A2-k HW1L-A2F10QD-k-l HW1L-A2F01QD-k-l HW1L-A2F11QD-k-l HW1L-A2F20QD-k-l HW4L-A2-k HW4L-A2F10QD-k-l HW4L-A2F01QD-k-l HW4L-A2F11QD-k-l HW4L-A2F20QD-k-l HW1L-AF2-k HW1L-AF2F10QD-k-l HW1L-AF2F01QD-k-l HW1L-AF2F11QD-k-l HW1L-AF2F20QD-k-l HW4L-AF2-k HW4L-AF2F10QD-k-l HW4L-AF2F01QD-k-l HW4L-AF2F11QD-k-l HW4L-AF2F20QD-k-l Circuit Breakers Flush Plastic Bezel Extended Metal Bezel Plastic Bezel Extended w/ Full Shroud Metal Bezel Plastic Bezel Metal Bezel Momentary Contacts Operator Only 1NO-1NC 2NO HW1L-M1-k HW1L-M1F11-lD-k HW1L-M1F20-lD-k HW4L-M1-k HW4L-M1F11-lD-k HW4L-M1F20-lD-k HW1L-M2-k HW1L-M2F11-lD-k HW1L-M2F20-lD-k HW4L-M2-k HW4L-M2F11-lD-k HW4L-M2F20-lD-k HW1L-MF2-k HW1L-MF2F11-lD-k HW1L-MF2F20-lD-k HW4L-MF2-k HW4L-MF2F11-lD-k HW4L-MF2F20-lD-k Maintained Terminal Blocks Contactors Illuminated Transformer Pushbuttons Operator Only 1NO-1NC 2NO HW1L-A1-k HW1L-A1F11-lD-k HW1L-A1F20-lD-k HW4L-A1-k HW4L-A1F11-lD-k HW4L-A1F20-lD-k HW1L-A2-k HW1L-A2F11-lD-k HW1L-A2F20-lD-k HW4L-A2-k HW4L-A2F11-lD-k HW4L-A2F20-lD-k HW1L-AF2-k HW1L-AF2F11-lD-k HW1L-AF2F20-lD-k HW4L-AF2-k HW4L-AF2F11-lD-k HW4L-AF2F20-lD-k 1. In place of k, specify Lens/LED Color Code from table. 2. In place of lspecify Voltage Code from table. 3. Light independent of switch position. 4. For replacement part numbers, see page 651. 5. For nameplates and accessories, see page 680. and 683. 6. For dimensions, see page 685. 7. For contact assembly part numbers, see page 685. 8. Full voltage and transformer models use the same operator. 9. Additional contact configurations available (up to 6 total contacts). 10. Yellow pushbutton comes with white LED. 650 k Lens/LED Color Code Color Code Amber A Green G Red R Blue S White W Yellow Y l Voltage Code Full Voltage Models Yellow LED not available. Use white LED for yellow lens. Transformer Models Voltage Code Voltage Code 6V AC/DC 6V 120V AC H2 12V AC/DC 12V 240V AC M4 24V AC/DC 24V 480V AC T8 120V AC 120V 240V AC 240V www.IDEC.com 1904032200 Switches & Pilot Devices Bezel 1: Plastic 4: Metal W 1 L Switches & Pilot Devices H ø22mm - HW Series Part Number Structure – M 1F 10 Q D – G – 12V LED Lamp Voltage Function Operator M: Momentary A: Maintained (full voltage units only) 6V: 6V AC/DC 12V: 12V AC/DC 24V: 24V AC/DC 120V: 120VC AC 240V: 240V AC Lens Color A: Amber S: Blue G: Green W: White R: Red Y: Yellow Contact Arrangement 1F: Flush 2F: Extended F2F: Extended w/ shroud 10: 01: 11: 20: 1NO 1NC 1NO-1NC 2NO Signaling Lights Note: Use only for interpreting part numbers. Do not use for developing part numbers. Illumination Circuit Q: Full Voltage H2: Transformer 120V AC M4: Transformer 240V AC T8: Transformer 480V AC Illuminated Round Pushbuttons (Replacement Parts) Transformer* + Contact Blocks + Lead Holder + Mounting Adaptor + Safety Lever Lock + Lamp + Anti-Rotation Ring + Operator + Lens Completed Unit = Relays & Sockets *Transformer not needed with full voltage models. Lamp Circuit Components Contact Blocks Description Lead Holder For use with HW-CBL on all illuminated pushbutton units. One required for each deck (pair) of contacts. HW-LH3 For use with odd number of contacts. HW-DA1FBN Dummy Block with Full Voltage Adaptor Full Voltage Adaptor DC-DC Converter Finger-Safe Part Number Finger-Safe TW-DA1FB 120VAC 240VAC 480VAC Finger-Safe 110VDC 1NC Finger-Safe Spring-Up Terminal HW-U10-F HW-U10R-F (early make) HW-U01-F HW-U01R-F (late break) 1. All assembled part numbers in catalog include standard finger-safe spring-up (HW-U...) contacts. . Style Part Number 1. Used to mount contact blocks to operator (first pair only). 2. IDEC strongly recommends using the safety lever lock to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. TW-F126B TW-F246B TW-F486B HW-L16D Anti-Rotation Ring Part Number Appearance Momentary HW1L-M0 HW4L-M0 Maintained HW1L-A0 HW4L-A0 Momentary HW1L-MF0 HW4L-MF0 Maintained HW1L-AF0 HW4L-AF0 Style Part Number HW9Z-LS Lenses Style Round Flush Part Number HW1A-L1-k Round Extended HW1A-L2-k Use with notched panel cutout to prevent unit rotation. LED Lamps Style LED Voltage Part Number 6V AC/DC LSTD-6k 12V AC/DC LSTD-1k 24V AC/DC LSTD-2k 120V AC LSTD-H2k 240V AC LSTD-M4k 1. In place of k, specify the LED Color Code. 2. The LED contains a current-limiting resistor and reverse polarity protection diodes. 3. Yellow LED not available, use white LED when using yellow lens. In place of k, specify the Lens Color Code from previous page. 800-262-IDEC (4332) • USA & Canada 651 Circuit Breakers Metal Bezel Safety Lever Lock HW9Z-RL Terminal Blocks Plastic Bezel Style 1904032200 1NO HW-CBL Operators Extended with Full Shroud Contacts Contact Block Mounting Adaptor 1. *With spring-up terminals - to use spring-up terminal type, must use transformer type operator designed for spring-up transformer. 2. ** DC-DC converter voltage input from 90-140V DC. Round Flush/ Extended Style Contactors Transformer Unit (6V secondary voltage) For use with even number of contacts. Terminals Timers Style Switches & Pilot Devices Switches & Pilot Devices ø22mm - HW Series Relays & Sockets Signaling Lights Illuminated Mushroom & Square Pushbuttons (Assembled) Full Voltage Timers Momentary Transformer Contactors Momentary Maintained Plastic Bezel Metal Bezel Plastic Bezel Operator Only† HW1L-M4-k HW4L-M4-k HW2L-M1-k 1NO HW1L-M4F10QD-k-l HW4L-M4F10QD-k-l HW2L-M1F10QD-k-l 1NC HW1L-M4F01QD-k-l HW4L-M4F01QD-k-l HW2L-M1F01QD-k-l 1NO-1NC HW1L-M4F11QD-k-l HW4L-M4F11QD-k-l HW2L-M1F11QD-k-l 2NO HW1L-M4F20QD-k-l HW4L-M4F20QD-k-l HW2L-M1F20QD-k-l Operator Only HW1L-A4-k HW4L-A4-k HW2L-A1-k 1NO HW1L-A4F10QD-k-l HW4L-A4F10QD-k-l HW2L-A1F10QD-k-l 1NC HW1L-A4F01QD-k-l HW4L-A4F01QD-k-l HW2L-A1F01QD-k-l 1NO-1NC HW1L-A4F11QD-k-l HW4L-A4F11QD-k-l HW2L-A1F11QD-k-l 2NO HW1L-A4F20QD-k-l HW4L-A4F20QD-k-l HW2L-A1F20QD-k-l 1NO-1NC HW1L-M4F11lD-k HW4L-M4F11lD-k HW2L-M1F11lD-k 2NO HW1L-M4F20lD-k HW4L-M4F20lD-k HW2L-M1F20lD-k 1NO-1NC HW1L-A4F11lD-k HW4L-A4F11lD-k HW2L-A1F11lD-k 2NO HW1L-A4F20lD-k HW4L-A4F20lD-k HW2L-A1F20lD-k 1. † Full voltage and transformer units use the same operator. Terminal Blocks 2. In place of k, specify the Lens/LED Color Code from table. Circuit Breakers 3. In place of lspecify the Voltage Code from table. 4. Light independent of switch position 5. For nameplates and accessories, see page 680. and 683. 6. For dimensions, see page 685. 7. For contact assembly part numbers, see page 685. 8. Additional contact configurations available (up to 6 total contacts). 9. Yellow pushbutton comes with white LED. 652 Square Flush Contacts † Maintained 40mm Mushroom Head k Lens/LED Color Code Color Code Amber A Green G Red R Blue S White W Yellow Y* l Voltage Code 1. *40mm mushroom lenses not available in yellow. 2. Yellow LED not available. Use white LED for yellow lens. www.IDEC.com Full Voltage Models Transformer Models Voltage Code Voltage Code 6V AC/DC 6V 120V AC H2 12V AC/DC 12V 240V AC M4 24V AC/DC 24V 480V AC T8 120V AC 120V 240V AC 240V 1904032200 Switches & Pilot Devices W 1 Switches & Pilot Devices H ø22mm - HW Series Part Number Structure – M 1 F 10 Q D – G – 12V L Voltage Bezel 1: Round Plastic 2: Square Plastic 4: Round Metal Function M: Momentary A: Maintained Lens Color Operator 1: Square Flush 4: Mushroom A: Amber S: Blue G: Green W: White R: Red Y: Yellow Contact Arrangement Note: Use only for interpreting part numbers. Do not use for developing part numbers. 1NO 1NC 1NO-1NC 2NO Illumination Circuit Q: Full Voltage H2: Transformer 120V AC M4: Transformer 240V AC T8: Transformer 480V AC Signaling Lights 10: 01: 11: 20: (full voltage units only) 6V: 6V AC/DC 12V: 12V AC/DC 24V: 24V AC/DC 120V: 120VC AC 240V: 240V AC Illuminated Mushroom & Square Pushbuttons (Replacement Parts) Transformer* + Contact Blocks + Lead Holder + Adaptor† + Safety Lever Lock + LED + Anti-Rotation Ring + Operator + Lens = Completed Unit Relays & Sockets *Transformer not needed with full voltage models. Lamp Circuit Components Contact Blocks Description Lead Holder For use with HW-CBL on all illuminated pushbutton units. One required for each deck (pair) of contacts. HW-LH3 For use with odd number of contacts. Finger-Safe HW-DA1FBN For use with even number of contacts. Finger-Safe TW-DA1FB Dummy Block with Full Voltage Adaptor Full Voltage Adaptor DC-DC Converter Part Number 120VAC 240VAC 480VAC Finger-Safe 110VDC 1NC Finger-Safe Spring-Up Terminal HW-U10-F HW-U10R-F (early make) HW-U01-F HW-U01R-F (late break) 1. All assembled part numbers in catalog include standard finger-safe spring-up contacts (HW-U...). . Style Part Number 1. Used to mount contact blocks to operator (first pair only). 2. IDEC strongly recommends using the safety lever lock to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. TW-F126B TW-F246B TW-F486B HW-L16D Safety Lever Lock Anti-Rotation Ring Appearance Part Number Part Number Lenses Momentary HW1L-M0L HW4L-M0L Maintained HW1L-A0L HW4L-A0L Momentary HW2L-M0 Maintained HW2L-A0 – Style Part Number ø40mm Mushroom Lens ALW4BLU-k* Square Flush HW2A-L1-k Use with notched panel cutout to prevent unit rotation. LED Lamps Style LED Voltage Part Number 6V AC/DC LSTD-6k 12V AC/DC LSTD-1k 24V AC/DC LSTD-2k 120V AC LSTD-H2k 240V AC LSTD-M4k 1. In place of k, specify the LED Color Code. 2. The LED contains a current-limiting resistor and reverse polarity protection diodes. 3. Yellow LED not available, use white LED when using yellow lens. Circuit Breakers Metal Bezel HW9Z-RL Terminal Blocks Style HW9Z-LS Plastic Bezel Style 1904032200 1NO HW-CBL Operators Square Contacts Contact Block Mounting Adaptor 1. *With spring-up terminals - to use spring-up terminal type, must use transformer type operator designed for spring-up transformer. 2. ** DC-DC converter voltage input from 90-140V DC. ø40mm Mushroom Style Contactors Transformer Unit (6V secondary voltage) Terminals Timers Style 1. In place of k, specify the Lens Color Code. 2. *Mushroom lens not available in yellow. 800-262-IDEC (4332) • USA & Canada 653 Switches & Pilot Devices Switches & Pilot Devices ø22mm - HW Series Signaling Lights Selector Switches 2-Position (Assembled) Mounting Contact Operator Position L Handle R Operator Only Maintained L Spring Return from Right L R R Knob Lever HWnS-2T HWnS-2L HWnS-21T HWnS-21L 1NO 1 O X Knob Lever HWnS-2TF10 HWnS-2LF10 HWnS-21TF10 HWnS-21LF10 1NO1NC 1 2 O X X O Knob Lever HWnS-2TF11 HWnS-2LF11 HWnS-21TF11 HWnS-21LF11 2NO 1 2 O O X X Knob Lever HWnS-2TF20 HWnS-2LF20 HWnS-21TF20 HWnS-21LF20 2NO2NC 1 2 3 4 X O X O O X O X Knob Lever HWnS-2TF22 HWnS-2LF22 HWnS-21TF22 HWnS-21LF22 1. In place of n enter 1 for plastic bezel or 4 for metal bezel. 2. For nameplates, see page 680. 3. All assembled part numbers in catalog include standard fingersafe spring-up (HW-U...) contacts. 4. Standard color for knob and lever is black. 5. Optional colors available for lever type. Must order in components. See next page for part numbers. 6. Additional contact configurations available (up to 6 total contacts). 7. For Truth Tables see page 693. n Bezel Type Type Code Plastic 1 Metal 4 Circuit Breakers Terminal Blocks Contactors Timers Relays & Sockets 2-Position Selector Switches 654 www.IDEC.com 1904032200 Switches & Pilot Devices ø22mm - HW Series H W 1 S - 2 1 T F Switches & Pilot Devices Part Number Structure 10 Contact Arrangement 10: 1NO 11: 1NO-1NC 20: 2NO Bezel 1: Plastic 4: Metal # of Positions 2: 2-Position Handle Operator T: Knob L: Lever Signaling Lights blank: Maintained 1: Spring Return from Right Note: Use only for interpreting part numbers. Do not use for developing part numbers. Selector Switches 2-Position (Replacement Parts) Contact Blocks + Mounting Adaptor + Safety Lever Lock Anti-Rotation Ring 1NO 1NC FingerSafe Spring-Up Terminal HW-U10-F HW-U01-F HW-U10R-F (early make) HW-U01R-F (late break) HW-DB Style Completed Unit Part Number HW9Z-RL Use with notched panel cutout to prevent unit rotation. Operators Style Description Contact Block Mounting Adaptor Metal Bezel Knob HW1S-2T HW4S-2T Lever HW1S-2 HW4S-2 Knob HW1S-21T HW4S-21T Lever HW1S-21 HW4S-21 1. Knob operator comes with black handle. 2. To order lever type, lever and inserts must be ordered separately, along with lever operator. See part numbers below. Levers & Inserts Style Part Number HW9Z-LS Lever TW-HC1-j Standard lever color is black. Standard insert color is white. 800-262-IDEC (4332) • USA & Canada Color Code Black* B Blue S Green G Red R Yellow Y White† W Circuit Breakers Lever Color Insert ASWHHL-j j Handle/Insert Color Code Terminal Blocks Part Number Plastic Bezel Contactors Spring Return from Right 1. Used to mount contact blocks to operator (first pair only). 2. IDEC strongly recommends using the safety lever lock to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. Safety Lever Lock Handle Maintained Part Number HW-CB2C 1904032200 = Timers Dummy Block Style Operator Relays & Sockets Contacts Style + Anti-Rotation Ring Contact Blocks Style + 1. * Lever color inserts not available in black. 2. †Lever not available in white. 655 Switches & Pilot Devices Selector Switches 3-Position (Assembled) Relays & Sockets Timers Contactors Terminal Blocks Circuit Breakers Mounting 3–Position Selector Switches Contact Signaling Lights Switches & Pilot Devices ø22mm - HW Series Operator Position L C Handle R Operator Only Spring Return from Right Maintained L C L R C Spring Return from Left L R C Spring Return Two-Way L R C Knob Lever HWnS-3T* HWnS-3L HWnS-31T HWnS-31L HWnS-32T HWnS-32L HWnS-33T HWnS-33L R 1NO1NC 1 2 0 0 X 0 X X Knob Lever HWnS-3TF11 HWnS-3LF11 HWnS-31TF11 HWnS-31LF11 HWnS-32TF11 HWnS-32LF11 HWnS-33TF11 HWnS-33LF11 2NO 1 2 X 0 0 0 0 X Knob Lever HWnS-3TF20 HWnS-3LF20 HWnS-31TF20 HWnS-31LF20 HWnS-32TF20 HWnS-32LF20 HWnS-33TF20 HWnS-33LF20 2NC 1 2 0 X X X X 0 Knob Lever HWnS-3TF02 HWnS-3LF02 HWnS-31TF02 HWnS-31LF02 HWnS-32TF02 HWnS-32LF02 HWnS-33TF02 HWnS-33LF02 2NO1NC 1 2 3 X 0 0 0 0 X 0 X 0 Knob HWnS-3JTF21N1 – – – 2NO2NC 1 2 3 4 X 0 0 X 0 0 X X 0 X X 0 Knob HWnS-3TF22 HWnS-31TF22 HWnS-32TF22 HWnS-33TF22 2NO2NC 1 2 3 4 0 X X 0 0 0 X 0 X 0 0 X Knob HWnS-3STF22N9 – – – 4NO 1 2 3 4 X 0 X 0 0 0 0 0 0 X 0 X Knob 4NO 1 2 3 4 X 0 X 0 0 X 0 0 0 X 0 X Knob HWnS-3STF40N2 – – – 4NC 1 2 3 4 0 X 0 X X X X X X 0 X 0 Knob HWnS-3TF04 HWnS-31TF04 HWnS-32TF04 HWnS-33TF04 n Bezel Type HWnS-3TF40 HWnS-31TF40 1. In place of n enter 1 for plastic bezel or 4 for metal bezel. 2. Knob operator includes black knob/lever operator includes black lever. 3. * Three position operator is available with three different cams. HWnS-3T: Maintained (standard cam) HWnS-3ST: Maintained (S cam) HWnS-3JT: Maintained (J cam) 4. Operator cams are color coded (white=standard cam, red=S cam, black =J cam). 5. For nameplates, see page 680. 6. For contact assembly part numbers, see page 685 656 HWnS-32TF40 HWnS-33TF40 Type Code Plastic 1 Metal 4 7. All assembled part numbers in catalog include standard finger-safe spring-up (HW-U...) contacts. 8. Standard color for knob and lever is black. 9. Optional colors available for lever type. Must order in components. See next page for part numbers. 10. Additional contact configurations available (up to 6 total contacts). 11. For Truth Tables see page 693. www.IDEC.com 1904032200 Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices Part Number Structure H W 1 S - 3 1 T F 20 Contact Arrangement 11: 1NO-1NC 20: 2NO 21: 2NO-1NC 22: 2NO-2NC 40: 4NO 04: 4NC Bezel 1: Plastic 4: Metal # of Positions 3: 3-Position Handle Operator T: Knob L: Lever Note: Use only for interpreting part numbers. Do not use for developing part numbers. Signaling Lights blank: Maintained 1: Spring Return from Right 2: Spring Return from Left 3: Spring Return Two Way Selector Switches 3-Position (Replacement Parts) Contact Blocks + Mounting Adaptor + Safety Lever Lock Anti-Rotation Ring 1NC FingerSafe Spring-Up Terminal HW-U10-F HW-U01-F HW-U10R-F (early make) HW-U01R-F (late break) Style Completed Unit Part Number HW-DB Part Number Description Handle Plastic Bezel Metal Bezel Maintained (standard cam) Knob HW1S-3T HW4S-3T Lever HW1S-3 HW4S-3 Maintained (S cam) Knob HW1S-3ST HW4S-3ST Maintained (J cam) Knob HW1S-3JT HW4S-3JT Spring Return from Right (standard cam) Knob HW1S-31T HW4S-31T Lever HW1S-31 HW4S-31 Spring Return from Left (standard cam) Knob HW1S-32T HW4S-32T Lever HW1S-32 HW4S-32 2-Way Spring Return (standard cam) Knob HW1S-33T HW4S-33T Lever HW1S-33 HW4S-33 Contactors HW-CB2C Levers & Inserts Style j Handle/Insert Color Code Part Number HW9Z-LS Lever ASWHHL-j Lever Color Insert TW-HC1-j Black* B Color Blue S Yellow Code Y Green G White W Red R † Circuit Breakers Terminal Blocks 1. Knob operator comes with black handle. 2. Three position knob operator is available with three different cams. 3. Operator cams are color coded (white=standard cam, red=S cam, black =J cam). 4. To order lever type, lever and inserts must be ordered separately, along with lever operator. See part numbers below. 1. Used to mount contact blocks to operator (first pair only). 2. IDEC strongly recommends using the safety lever lock to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. Part Number Use with notched panel cutout to prevent unit rotation. Operators Contact Block Mounting Adaptor Safety Lever Lock HW9Z-RL Style 1904032200 = Timers 1NO Dummy Block Style Operator Relays & Sockets Contacts Style + Anti-Rotation Ring Contact Blocks Style + 1. * Lever color inserts not available in black. 2. †Lever not available in white. Standard lever color is black. Standard insert color is white. 800-262-IDEC (4332) • USA & Canada 657 Switches & Pilot Devices Switches & Pilot Devices ø22mm - HW Series Signaling Lights Selector Switches 4- & 5-Position (Assembled) 2 3 4 Maintained 1 2 3 4 Operator Only Mounting 1 Handle Contact Mounting Contact 5-Position Selector Switch Operator Position Knob Lever HWnS-4T HWnS-4L Operator Only 2NO2NC 1NO2NC 1 2 3 4 X 0 0 0 0 X 0 0 O 0 X 0 O 0 0 0 Knob Lever HWnS-4TF12 HWnS-4LF12 1NO3NC 1 2 3 4 O O O O X X O O X O X O X O O X Knob Lever HWnS-4TF13N6 HWnS-4LF13N6 2NO2NC 1 2 3 4 X O O O O X O O O O X O O O O X Knob Lever HWnS-4TF22N3 HWnS-4LF22N3 1. In place of n enter 1 for plastic bezel or 4 for metal bezel. 2. Knob operator includes black knob/lever operator includes black lever. 3. For nameplates, see page 680. 4. For contact assembly part numbers, see page 685. 5. Five position circuit cannot be made to make five independent contact closures. 6. All assembled part numbers in catalog include standard finger-safe spring-up (HW-U...) contacts. 7. Standard color for knob and lever is black. 8. Optional colors available for lever type. Must order in components. See next page for part numbers. 9. Additional contact configurations available (up to 6 total contacts). 10. For Truth Tables see page 693. 1 2 3 4 Operator Position 1 X O O O 2 O X O O 3 O O O O 4 O O X O Handle 5 O O O X Maintained 1 2 3 4 5 Knob Lever HWnS-5T HWnS-5L Knob Lever HWnS-5TF22N3 HWnS-5LF22N3 n Bezel Type Type Code Plastic 1 Metal 4 Circuit Breakers Terminal Blocks Contactors Timers Relays & Sockets 4-Position Selector Switches 658 www.IDEC.com 1904032200 Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices Part Number Structure H W 1 S - 4 T F 13N6 Contact Arrangement Bezel 1: Plastic 4: Metal (based on desired truth table) 12: 1NO-2NC 13N6: 1NO-3NC 22N3: 2NO-2NC # of Positions 4: 4-Position 5: 5-Position Handle T: Knob L: Lever Signaling Lights Note: Use only for interpreting part numbers. Do not use for developing part numbers. Selector Switches 4- & 5-Position (Replacement Parts) Contact Blocks + Mounting Adaptor + Safety Lever Lock Style Anti-Rotation Ring 1NO 1NC FingerSafe Spring-Up Terminal HW-U10-F HW-U01-F HW-U10R-F (early make) HW-U01R-F (late break) HW-DB Style Completed Unit Part Number HW9Z-RL Use with notched panel cutout to prevent unit rotation. Operators Style Position Contact Block Mounting Adaptor 4 Part Number 5 1. Used to mount contact blocks to operator (first pair only). 2. IDEC strongly recommends using the safety lever lock to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. Handle Plastic Bezel Metal Bezel Knob HW1S-4T HW4S-4T Lever HW1S-4 HW4S-4 Knob HW1S-5T HW4S-5T Lever HW1S-5 HW4S-5 Maintained Maintained 1. Knob operator comes with black handle. 2. To order lever type, lever and inserts must be ordered separately, along with lever operator. See part numbers below. Levers & Inserts Style Part Number Part Number Lever HW9Z-LS Lever Color Insert TW-HC1-j Standard lever color is black. Standard insert color is white. 800-262-IDEC (4332) • USA & Canada Color Code Black* B Blue S Green G Red R Yellow Y White W † Circuit Breakers ASWHHL-j j Handle/Insert Color Code Terminal Blocks Safety Lever Lock Description Contactors HW-CB2C 1904032200 = Timers Dummy Block Style Operator Anti-Rotation Ring Contacts Style + Relays & Sockets Contact Blocks + 1. * Lever color inserts not available in black. 2. †Lever not available in white. 659 Switches & Pilot Devices Key Switches 2-Position (Assembled) Operator Position L R Operator Only Maintained L R Spring Return from Right L HWnK-2A HWnK-21B R 1NO 1 O X HWnK-2AF10 HWnK-21BF10 1NO1NC 1 2 0 X X 0 HWnK-2AF11 HWnK-21BF11 2NO 1 2 O O X X HWnK-2AF20 HWnK-21BF20 2NO2NC 1 2 3 4 0 X 0 X X 0 X 0 HWnK-2AF22 HWnK-21BF22 Timers Relays & Sockets Mounting 2-Position Key Switches Contact Signaling Lights Switches & Pilot Devices ø22mm - HW Series Contactors 1. In place of n enter 1 for plastic bezel or 4 for metal bezel. 2. Key is removable in all maintained positions. Other key removable options available. 3. Two keys are supplied with all switches. 4. All standard operators are keyed alike. 5. Other key removable options available. See table below 6. For nameplates, see page 680. 7. For contact assembly part numbers, see page 685. 8. Key is retained in “Spring Return” position. 9. All assembled part numbers in catalog include finger-safe spring-up (HW-U...) contacts. 10. Additional contact configurations available (up to 6 total contacts). 11. For Truth Tables see page 685. n Bezel Type Type Code Plastic 1 Metal 4 Code Description A Key not retained in any position (removable in all positions) B Key retained in right position only (removable LEFT) C Key retained in left position only (removable RIGHT) Circuit Breakers Terminal Blocks Key Removable Option Codes 660 www.IDEC.com 1904032200 Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices Part Number Structure H W 1 K - 2 1 B F 10 Contact Arrangement 10: 1NO 20: 2NO 11: 1NO-1NC 22: 2NO-2NC Bezel 1: Plastic 4: Metal # of Positions 2: 2-Position Operator Key Retained Position blank: Maintained 1: Spring Return from Right Note: Use only for interpreting part numbers. Do not use for developing part numbers. Signaling Lights A: Key not retained in any position (removable in all positions) B: Key retained in right position only (removable LEFT) C: Key retained in left position only (removable RIGHT) Key Switches 2-Position (Replacement Parts) Contact Assembly + Mounting Adaptor + Safety Lever Lock Anti-Rotation Ring + Operator = Completed Unit Relays & Sockets Safety Lever Lock Contact Blocks Style + 1NO 1NC FingerSafe Spring-Up Terminal HW-U10-F HW-U01-F HW-U10R-F (early make) HW-U01R-F (late break) Style Part Number HW9Z-LS Timers Contacts Anti-Rotation Ring Dummy Block HW-DB Style Part Number HW9Z-RL Contact Block Mounting Adaptor Part Number Operators Style HW-CB2C Description Plastic Bezel Metal Bezel Maintained HW1K-2A HW4K-2A Maintained, key removed left only HW1K-2B HW4K-2B Spring Return from Right HW1K-21B HW4K-21B Maintained, key removed right only HW1K-2C HW4K-2C Terminal Blocks 1. Used to mount contact blocks to operator (first pair only). 2. IDEC strongly recommends using the safety lever lock to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. Contactors Style Use with notched panel cutout to prevent unit rotation. 1. Operator includes two keys. 2. All standard operators are keyed alike. Circuit Breakers 1904032200 800-262-IDEC (4332) • USA & Canada 661 Switches & Pilot Devices Key Switches 3-Position (Assembled) Mounting 3-Position Key Switches Contact Signaling Lights Switches & Pilot Devices ø22mm - HW Series Operator Position L C R Spring Return from Right Maintained L C L R C R Spring Return from Left L C Spring Return Two Way L R C R n Bezel Type Circuit Breakers Terminal Blocks Contactors Timers Relays & Sockets Operator Only HWnK-3A* HWnK-31B HWnK-32C HWnK-33D Type Code HWnK-31BF11 HWnK-32CF11 HWnK-33DF11 Plastic 1 Metal 4 1NO1NC 1 2 0 0 X 0 X X HWnK-3AF11 2NO 1 2 X 0 0 0 0 X HWnK-3AF20 HWnK-31BF20 HWnK-32CF20 HWnK-33DF20 2NC 1 2 0 X X X X 0 HWnK-3AF02 HWnK-31BF02 HWnK-32CF02 HWnK-33DF02 2NO1NC 1 2 3 X 0 0 0 0 X 0 X 0 HWnK-3JAF21N1 2NO2NC 1 2 3 4 X 0 0 X 0 0 X X 0 X X 0 HWnK-3AF22 2NO2NC 1 2 3 4 0 X X 0 0 0 X 0 X 0 0 X HWnK-3SAF22N9 4NO 1 2 3 4 X 0 X 0 0 0 0 0 0 X 0 X HWnK-3AF40 4NO 1 2 3 4 X 0 X 0 0 X 0 0 0 X 0 X HWnK-3SAF40N2 4NC 1 2 3 4 0 X 0 X X X X X X 0 X 0 HWnK-3AF04 1. In place of n enter 1 for plastic bezel or 4 for metal bezel. 2. Key is removable in all maintained positions. Other key removable options available. 3. Two keys are supplied with all switches. 4. All standard operators are keyed alike. 5. Other key removable options available. See table to the right. 6. * Operator is available with three different cams. HWnK-3A: Maintained (standard cam) HWnK-3SA: Maintained (Cam S) HWnK-3JA: Maintained (Cam J) 7. For nameplates, see page 680. 662 – HWnK-31BF22 – HWnK-31BF40 – HWnK-31BF04 – HWnK-32CF22 – HWnK-33DF22 – HWnK-32CF40 – HWnK-33DF40 – HWnK-32CF04 8. For contact assembly part numbers, see page 685. 9. All assembled part numbers in catalog include standard Finger-Safe spring-up (HW-U...) contacts. 10. Additional contact configurations available (up to 6 total contacts). 11. For Truth Tables see page 693. www.IDEC.com – HWnK-33DF04 Key Removable Option Codes Code Description A Key not retained in any position (removable in all positions) B Key retained in right position only C Key retained in left position only D Key retained in left and right (3 position only) E Key retained in center only (3 position only) G Key retained right and center (3 position only) H Key retained left and center (3 position only) 1904032200 Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices Part Number Structure H W 1 K - 3 1 B F 11 Contact Arrangement 11: 1NO-1NC 40: 4NO 20: 2NO 04: 4NC 22: 2NO-2NC Bezel 1: Plastic 4: Metal # of Positions 3: 3-Position Operator blank: Maintained 1: Spring Return from Right 2: Spring Return from Left 3: Spring Return Two Way Contact Assembly + Key Switches 3-Position (Replacement Parts) Mounting Adaptor + Safety Lever Lock + Anti-Rotation Ring + Operator = Completed Unit Relays & Sockets Safety Lever Lock Contact Blocks Style (see chart on previous page) Signaling Lights Note: Use only for interpreting part numbers. Do not use for developing part numbers. Key Removable Option Code 1NO 1NC FingerSafe Spring-Up Terminal HW-U10-F HW-U01-F HW-U10R-F (early make) HW-U01R-F (late break) Dummy Block HW-DB Style Part Number HW9Z-LS Timers Contacts Anti-Rotation Ring Style Part Number HW9Z-RL Contact Block Mounting Adaptor Part Number Operators Style HW-CB2C 1. 2. 3. 4. Description Plastic Bezel Metal Bezel Maintained (standard cam) HW1K-3A HW4K-3A Maintained (S cam) HW1K-3SA HW4K-3SA Maintained (J cam) HW1K-3JA HW4K-3JA Spring Return from Right (standard cam) HW1K-31B HW4K-31B Spring Return from Left (standard cam) HW1K-32C HW4K-32C 2-Way Spring Return (standard cam) HW1K-33D HW4K-33D Terminal Blocks 1. Used to mount contact blocks to operator (first pair only). 2. IDEC strongly recommends using the safety lever lock to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. Contactors Style Use with notched panel cutout to prevent unit rotation. Operator includes two keys. All standard operators are keyed alike. Other key removable options available. See table on previous page. Key not removable from spring-returned position Circuit Breakers 1904032200 800-262-IDEC (4332) • USA & Canada 663 Switches & Pilot Devices Switches & Pilot Devices ø22mm - HW Series Signaling Lights Illuminated Selector Switches 2-Position (Assembled) 2-Position Illuminated Selector Switches Mounting Contact Relays & Sockets Style Operator Position L Part Number Type R L Operator Only Full Voltage 1NO1NC 1 2 O X X O 2NO 1 2 X O O X 2NO2NC 1 2 3 4 O X O X X O X O Transformer 120V 240V 480V Terminal Blocks Circuit Breakers 120V 240V 480V Full Voltage Transformer 120V 240V 480V L R R HWnF-2k HWnF-21k HWnF-2F11QD-k-l HWnF-21F11QD-k-l HWnF-2F11H2D-k HWnF-2F11M4D-k HWnF-2F11T8D-k HWnF-21F11H2D-k HWnF-21F11M4D-k HWnF-21F11T8D-k HWnF-2F20QD-k-l HWnF-21F20QD-k-l HWnF-2F20H2D-k HWnF-2F20M4D-k HWnF-2F20T8D-k HWnF-21F20H2D-k HWnF-21F20M4D-k HWnF-21F20T8D-k HWnF-2F22QD-k-l HWnF-21F22QD-k-l HWnF-2F22H2D-k HWnF-2F22M4D-k HWnF-2F22T8D-k HWnF-21F22H2D-k HWnF-21F22M4D-k HWnF-21F22T8D-k 1. In place of k specify Lens/LED color code. 2. In place of l specify Full Voltage code. 3. In place of n enter 1 for plastic bezel or 4 for metal bezel. 4. For nameplates, see page 680. 5. For contact assembly part numbers, see page 685. 6. Light is independent of switch position. 7. All assembled part numbers in catalog include standard Finger-Safe spring-up (HW-U...) contacts. 8. Yellow selector switch comes with white LED. 9. Additional contact configurations available (up to 6 total contacts). 10. For Truth Tables see page 693. Contactors Timers Full Voltage Transformer Spring Return from Right Maintained k Lens/LED Color Code l Full Voltage Code n Bezel Code Color Code Type Code Amber A Voltage Code Plastic 1 Green G 6VAC/DC 6V Metal 4 Red R 12VAC/DC 12V Blue S 24VAC/DC 24V White W 120V AC 120V Yellow Y 240V AC 240V 664 Full Voltage Models www.IDEC.com 1904032200 Switches & Pilot Devices W 1 F Part Number Structure – 21 F 20 Q D – G – 24V Bezel 1: Plastic 4: Metal LED Voltage (Full voltage units only) 6V: 6V AC/DC A: Amber S: Blue G: Green W: White 12V: 12V AC/DC R: Red Y: Yellow 24V: 24V AC/DC 120V: 120V AC 240V: 240V AC Lens Color Position Contact Arrangement 2: Maintained 21: Spring Return from Right 11: 1NO-1NC 20: 2NO 22: 2NO-2NC Illumination Circuit Illuminated Selector Switches 2-Position (Replacement Parts) Transformer* + Contact Blocks + Lead Holder + Mounting Adaptor + Safety Lever Lock + LED + Anti-Rotation Ring + Operator + Lens = Completed Unit Lamp Circuit Components Contact Blocks Description Lead Holder For use with HW-CBL on all illuminated pushbutton units. HW-LH3 One required for each deck (pair) of contacts. Finger-Safe HW-DA1FBN 120VAC 240VAC 480VAC Finger-Safe Style Part Number Finger-Safe TW-DA1FB TW-F126B TW-F246B TW-F486B 1. Used to mount contact blocks to operator (first pair only). 2. IDEC strongly recommends using the safety lever lock to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. 110VDC Part Number Description 1904032200 HW1F-2 HW4F-2 Spring return from right HW1F-21 HW4F-21 Illuminated knobs must be ordered separately. Code Color Code Amber A Blue S Green G White W Red R Yellow Y Anti-Rotation Ring Style Appearance Part Number HW9Z-FDY-k In place of k, specify the Color Code. 800-262-IDEC (4332) • USA & Canada Part Number HW9Z-RL Use with notched panel cutout to prevent unit rotation. Lamps Voltage Part Number 6V AC/DC LSTD-6k 12V AC/DC LSTD-1k 24V AC/DC LSTD-2k 120V AC LSTD-H2k 240V AC LSTD-M4k 1. In place of k, specify the LED Color Code. 2. The LED contains a current-limiting resistor and reverse polarity protection diodes. 3. Use white LED for yellow lens. Yellow LED not available. Circuit Breakers Maintained Color LED Illuminated Knob Metal Bezel HW-U01-F HW-U01R-F (late break) Terminal Blocks Style HW-U10-F HW-U10R-F (early make) HW9Z-LS 1. DC-DC convertor features spring-up terminals. 2. DC-DC convertor applicable voltage range 90-140V DC. Plastic Bezel Finger-Safe Spring-Up Terminal Style HW-L16D Operators 1NC Safety Lever Lock Style DC-DC Converter 1NO Contact Block Mounting Adaptor k Lens/LED Color Code HW-CBL For use with even number of contacts. Contacts Contactors Transformer Unit (6V secondary voltage) For use with odd number of contacts. Style Timers Full Voltage Adaptor Terminals Part Number Style Dummy Block with Full Voltage Adaptor Relays & Sockets *Transformer not needed with full voltage models. Signaling Lights Q: Full Voltage H2: Transformer 120V AC M4: Transformer 240V AC T8: Tranformer 480V AC Note: Use only for interpreting part numbers. Do not use for developing part numbers. Switches & Pilot Devices H ø22mm - HW Series 665 Switches & Pilot Devices Signaling Lights Switches & Pilot Devices ø22mm - HW Series Illuminated Selector Switches 3-Position (Assembled) 3-Position Illuminated Selector Switches Mounting Contact Relays & Sockets Style Part Number Operator Position L C Type R L Operator Only Full Voltage 1NO1NC 1 2 O O X O X X 2NO 1 2 X 0 0 0 O X 2NC 1 2 O X X X X O 1 2 3 4 X O O X O O X X O X X O Full Voltage 2NO2NC X O X O O O O O O X O X Full Voltage 4NO 1 2 3 4 O X O X X X X X X O X O Full Voltage 4NC 1 2 3 4 Transformer 120V 240V 480V Circuit Breakers Terminal Blocks Contactors Timers Full Voltage Transformer 120V 240V 480V Full Voltage Transformer Transformer Transformer Transformer 1. In place of k specify Lens/LED color code. 2. In place of l specify Full Voltage code. 3. In place of n enter 1 for plastic bezel or 4 for metal bezel. 4. For nameplates, see page 680. 5. For contact assembly part numbers, see page 685. 6. Light is independent of switch position. 7. All assembled part numbers in catalog include standard Finger-Safe spring-up (HW-U..) contacts. 666 Spring Return from Right Maintained 120V 240V 480V 120V 240V 480V 120V 240V 480V 120V 240V 480V C L R C R Spring Return from Left L C Spring Return TwoWay L R C R HWnF-3k HWnF-31k HWnF-32k HWnF-33k HWnF-3F11QD-k-l HWnF-31F11QD-k-l HWnF-32F11QD-k-l HWnF-33F11QD-k-l HWnF-3F11H2D-k HWnF-3F11M4D-k HWnF-3F11T8D-k HWnF-31F11H2D-k HWnF-31F11M4D-k HWnF-31F11T8D-k HWnF-32F11H2D-k HWnF-32F11M4D-k HWnF-32F11T8D-k HWnF-33F11H2D-k HWnF-33F11M4D-k HWnF-33F11T8D-k HWnF-3F20QD-k-l HWnF-31F20QD-k-l HWnF-32F20QD-k-l HWnF-33F20QD-k-l HWnF-3F20H2D-k HWnF-3F20M4D-k HWnF-3F20T8D-k HWnF-31F20H2D-k HWnF-31F20M4D-k HWnF-31F20T8D-k HWnF-32F20H2D-k HWnF-32F20M4D-k HWnF-32F20T8D-k HWnF-33F20H2D-k HWnF-33F20M4D-k HWnF-33F20T8D-k HWnF-3F02QD-k-l HWnF-31F02QD-k-l HWnF-32F02QD-k-l HWnF-33F02QD-k-l HWnF-3F02H2D-k HWnF-3F02M4D-k HWnF-3F02T8D-k HWnF-31F02H2D-k HWnF-31F02M4D-k HWnF-31F02T8D-k HWnF-32F02H2D-k HWnF-32F02M4D-k HWnF-32F02T8D-k HWnF-33F02H2D-k HWnF-33F02M4D-k HWnF-33F02T8D-k HWnF-3F22QD-k-l HWnF-31F22QD-k-l HWnF-32F22QD-k-l HWnF-33F22QD-k-l HWnF-3F22H2D-k HWnF-3F22M4D-k HWnF-3F22T8D-k HWnF-31F22H2D-k HWnF-31F22M4D-k HWnF-31F22T8D-k HWnF-32F22H2D-k HWnF-32F22M4D-k HWnF-32F22T8D-k HWnF-33F22H2D-k HWnF-33F22M4D-k HWnF-33F22T8D-k HWnF-3F40QD-k-l HWnF-31F40QD-k-l HWnF-32F40QD-k-l HWnF-33F40QD-k-l HWnF-3F40H2D-k HWnF-3F40M4D-k HWnF-3F40T8D-k HWnF-31F40H2D-k HWnF-31F40M4D-k HWnF-31F40T8D-k HWnF-32F40H2D-k HWnF-32F40M4D-k HWnF-32F40T8D-k HWnF-33F40H2D-k HWnF-33F40M4D-k HWnF-33F40T8D-k HWnF-3F04QD-k-l HWnF-31F04QD-k-l HWnF-32F04QD-k-l HWnF-33F04QD-k-l HWnF-3F04H2D-k HWnF-3F04M4D-k HWnF-3F04T8D-k HWnF-31F04H2D-k HWnF-31F04M4D-k HWnF-31F04T8D-k HWnF-32F04H2D-k HWnF-32F04M4D-k HWnF-32F04T8D-k HWnF-33F04H2D-k HWnF-33F04M4D-k HWnF-33F04T8D-k 8. Yellow selector switch comes with white LED. 9. Additional contact configurations available (up to 6 total contacts). 10. For Truth Tables see page 693. k Lens/LED Color l Full Voltage Code Color Code Type Code Amber A Voltage Code Plastic 1 Green G 6VAC/DC 6V Metal 4 Red R 12VAC/DC 12V Blue S 24VAC/DC 24V White W 120V AC 120V Yellow Y 240V AC 240V www.IDEC.com Full Voltage Models n Bezel Code 1904032200 Switches & Pilot Devices W 1 F Part Number Structure – 31 F 20 Q D – G – 24V Bezel Transformer* + + 6V: 6V AC/DC 12V: 12V AC/DC A: Amber S: Blue G: Green W: White 24V: 24V AC/DC R: Red Y: Yellow 120V: 120V AC 240V: 240V AC Contact Arrangement 11: 1NO-1NC 22: 2NO-2NC Illumination Circuit 20: 2NO 40: 4NO Q: Full Voltage 02: 2NC 04: 4NC H2: Transformer 120V AC M4: Transformer 240V AC T8: Tranformer 480V AC Note: Use only for interpreting part numbers. Do not use for developing part numbers. Contact Blocks Full Voltage Code Lens Color Illuminated Selector Switches 3-Position (Replacement Parts) Lead Holder + Mounting Adaptor + Safety Lever Lock + LED + Anti-Rotation Ring + Operator + Lens = Completed Unit Lamp Circuit Components Contact Blocks Lead Holder For use with HW-CBL on all illuminated pushbutton units. One required for each deck (pair) of contacts. HW-LH3 For use with odd number of contacts. HW-DA1FBN 120VAC 240VAC 480VAC Style Finger-Safe HW-U01-F HW-U01R-F (late break) Finger-Safe TW-F126B TW-F246B TW-F486B 1. Used to mount contact blocks to operator (first pair only). 2. IDEC strongly recommends using the safety lever lock to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. Color Code Color Code Amber A Blue S Green G White W Red R Yellow Y Anti-Rotation Ring Style HW9Z-RL Safety Lever Lock Part Number HW-L16D HW9Z-LS Plastic Bezel Metal Bezel Maintained HW1F-3 HW4F-3 Spring return from right HW1F-31 HW4F-31 Spring return from left HW1F-32 HW4F-32 2-Way spring return HW1F-33 HW4F-33 Appearance Part Number HW9Z-FDY-k In place of k, specify the Color Code. Style 800-262-IDEC (4332) • USA & Canada Voltage Part Number 6V AC/DC LSTD-6k 12V AC/DC LSTD-1k 24V AC/DC LSTD-2k 120V AC LSTD-H2k 240V AC LSTD-M4k 1. In place of k, specify the LED Color Code. 2. The LED contains a current-limiting resistor and reverse polarity protection diodes. 3. Use white LED for yellow lens. Yellow LED not available. 667 Circuit Breakers Illuminated knobs must be ordered separately. Use with notched panel cutout to prevent unit rotation. Lamps LED Illuminated Knob Part Number Terminal Blocks 1904032200 HW-U10-F HW-U10R-F (early make) TW-DA1FB Operators Finger-Safe Spring-Up Terminal HW-CBL 110VDC Description 1NC Part Number 1. DC-DC convertor features spring-up terminals. 2. DC-DC convertor applicable voltage range 90-140V DC. Style 1NO Contact Block Mounting Adaptor k Lens/LED Color Code Style DC-DC Converter Contacts Contactors Transformer Unit (6V secondary voltage) For use with even number of contacts. Finger-Safe Style Timers Description Full Voltage Adaptor Terminals Part Number Style Dummy Block with Full Voltage Adaptor Relays & Sockets *Transformer not needed with full voltage models. Signaling Lights 1: Plastic Position 4: Metal 3: Maintained 31: Spring Return from Right 32: Spring Return from Left 33: Spring Return 2-Way Switches & Pilot Devices H ø22mm - HW Series Switches & Pilot Devices Switches & Pilot Devices ø22mm - HW Series Signaling Lights Mono Lever Switches 2-Position (Assembled) 2-Position Mono Lever Switches HW1M Standard Lever Timers Relays & Sockets Style Description HW1M-F1010-20 Maintained up and down HW1M-F2020-20 Spring return up and down HW1M-F1010-40 Maintained up and down HW1M-F2020-40 Spring return up and down HW1M-F0101-20 Maintained right and left HW1M-F0202-20 Spring return right and left HW1M-F0101-40 Maintained right and left HW1M-F0202-40 Spring return right and left HW1M-LF1010-20 Maintained up and down HW1M-LF2020-20 Spring return up and down HW1M-LF1010-40 Maintained up and down HW1M-LF2020-40 Spring return up and down HW1M-LF0101-20 Maintained right and left HW1M-LF0202-20 Spring return right and left HW1M-LF0101-40 Maintained right and left HW1M-LF0202-40 Spring return right and left Circuit Diagrams 2 Position Left/Right Circuit Number 20 40 Contact Mounting No. Position Left Center Right X 0 0 HW-U10-F 0 0 X HW-U10-F X 0 0 HW-U10-F 0 0 X HW-U10-F X 0 0 HW-U10-F 0 0 X 1 HW-U10-F 2 1 2 3 4 2 Position Up/Down Circuit Number 20 40 All Assembled units with Finger-Safe spring-up (HW-U...) contacts Contact Mounting No. Position Down Center Up X 0 0 HW-U10-F 0 0 X HW-U10-F X 0 0 HW-U10-F 0 0 X HW-U10-F X 0 0 HW-U10-F 0 0 X 1 HW-U10-F 2 1 2 3 4 Circuit Breakers Terminal Blocks Contactors HW1M-L Interlocking Lever Part Number 668 www.IDEC.com 1904032200 Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices Part Number Structure H W 1 M - L F 0 1 0 1 20 up right down left Type blank: Standard L: Interlocking Circuit Number 20 or 40 (see contact arrangement on previous page) Lever Action 1: Maintained 2: Spring 0: Blocked Note: Use only for interpreting part numbers. Do not use for developing part numbers. Signaling Lights Mono Lever Switches 2-Position (Sub-assembled) Part Numbers Contact Assembly + Mounting Adaptor + 1NO 1NC FingerSafe Spring-Up Terminal HW-U10-F HW-U01-F HW-U10R-F (early make) HW-U01R-F (late break) Operator = Completed Unit HW-DB Contact Block Mounting Adaptor Style Part Number HW9Z-RL Use with notched panel cutout to prevent unit rotation. Timers Dummy Block Operators Description Part Number Standard Maintained Up/Down HW1M-1010 Spring return Up/Down HW1M-2020 Maintained Left/Right HW1M-0101 Spring return Left/Right HW1M-0202 Maintained Up/Down HW1M-L1010 Spring return Up/Down HW1M-L2020 Maintained Left/Right HW1M-L0101 Spring return Left/Right HW1M-L0202 Part Number Interlocking 1. Used to mount contact blocks to operator (first pair only). 2. IDEC strongly recommends using the safety lever lock (included) to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. Safety Lever Lock Replacement Parts Item Part Number Terminal Blocks Part Number Contactors Style HW-CB2C Style + Relays & Sockets Contacts Style Anti-Rotation Ring + Anti-Rotation Ring Contact Blocks Style Safety Lever Lock Black Cap HW9Z-CPM HW9Z-LS Boot HW9Z-BLM (fits standard operator only) Circuit Breakers 1904032200 800-262-IDEC (4332) • USA & Canada 669 Switches & Pilot Devices Switches & Pilot Devices ø22mm - HW Series Signaling Lights Mono Lever Switches 3- & 4-Position (Assembled) 3-Position 4-Position Relays & Sockets Style Part Number Description HW1M Standard Lever HW1M-F0121-12N3 Maintained right and left, spring return down Style HW1M-F0222-12N3 Spring return right, down, left HW1M-L Interlocking Lever HW1M-LF0121-12N3 Maintained right and left, spring return down HW1M-LF0222-12N3 Spring return right, down, left HW1M Standard Lever Circuit Diagram Timers Circuit Number Contact Mounting No. 12N3 Position Down Left Center Up Right 1 HW-U01-F 0 0 0 O X 2 HW-U01-F X 0 0 O 0 3 HW-U10-F 0 X 0 0 0 HW1M-L Interlocking Lever Description HW1M-F1111-22N9 Maintained all positions HW1M-F1212-22N9 Maintained up and down, spring left and right HW1M-2121-22N9 Spring up and down, maintained left and right HW1M-2222-22N9 Spring return all positions HW1M-LF1111-22N9 Maintained all positions HW1M-LF1212-22N9 Maintained up and down, spring left and right HW1M-LF2121-22N9 Spring up and down, maintained left and right HW1M-LF2222-22N9 Spring return all positions Circuit Diagram Circuit Number 22N9 Contactors Part Number Contact Mounting No. Position Down Left Center Up Right 1 HW-U01-F 0 O 0 0 X 2 HW-U01-F X 0 0 0 0 3 HW-U10-F 0 X 0 0 0 4 HW-U10-F 0 0 0 X 0 Circuit Breakers Terminal Blocks All assembled part numbers in catalog include Finger-Safe spring-up (HW-U...) contacts. 670 www.IDEC.com 1904032200 Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices Part Number Structure H W 1 M - L F 0 1 2 1 12N3 up right down left Type blank: Standard L: Interlocking Circuit Number 3 Position: 12N3 4 Position: 22N9 Lever Action 1: Maintained 2: Spring 0: Blocked Note: Use only for interpreting part numbers. Do not use for developing part numbers. Signaling Lights Mono Lever Switches 3 & 4-Position (Sub-assembled) Part Numbers Contact Assembly + Mounting Adaptor + 1NO 1NC FingerSafe Spring-Up Terminal HW-U10-F HW-U01-F HW-U10R-F (early make) HW-U01R-F (late break) Operator = Completed Unit HW-DB Style Part Number HW9Z-RL Use with notched panel cutout to prevent unit rotation. Operators Style Standard Contact Block Mounting Adaptor Part Number Interlocking 1. Used to mount contact blocks to operator (first pair only). 2. IDEC strongly recommends using the safety lever lock (included) to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. Safety Lever Lock Part Number Combination, 3 position HW1M-0121 Spring return, 3 position HW1M-0222 Maintained, 4 position HW1M-1111 Combination, 4 position HW1M-1212 Combination, 4 position HW1M-2121 Spring return, 4 position HW1M-2222 Combination, 3 position HW1M-L0121 Spring return, 3 position HW1M-L0222 Maintained, 4 position HW1M-L1111 Combination, 4 position HW1M-L1212 Combination, 4 position HW1M-L2121 Spring return, 4 position HW1M-L2222 Contactors HW-CB2C Description Timers Dummy Block Terminal Blocks Style + Relays & Sockets Contacts Style Anti-Rotation Ring + Anti-Rotation Ring Contact Blocks Style Safety Lever Lock Part Number Replacement Parts HW9Z-LS Item Part Number Black Cap HW9Z-CPM Circuit Breakers Boot HW9Z-BLM (fits standard operator only) 1904032200 800-262-IDEC (4332) • USA & Canada 671 Switches & Pilot Devices Signaling Lights Switches & Pilot Devices ø22mm - HW Series Pushbutton Selectors (Assembled) 2-Position Pushbutton Selectors Operator Position Left Relays & Sockets Cam Contacts Mounting Normal j Button Color Code Right Push Normal Push Operator Only 1NO-1NC A HW1R-2A-j 1 2 HW-U10-F HW-U01-F 0 X X 0 0 0 X 0 1 2 HW-U10-F HW-U10-F 0 0 X X 0 X X X HW1R-2AF20-j 2NO-2NC 1 2 3 4 HW-U10-F HW-U01-F HW-U10-F HW-U01-F 0 X 0 X X 0 X 0 0 0 0 0 X 0 X 0 HW1R-2AF22-j 2NO 1 2 HW-U10-F HW-U10-F 0 0 X 0 0 0 0 X HW1R-2DF20-j 2NO-2NC 1 2 3 4 HW-U10-F HW-U10-F HW-U01-F HW-U01-F 0 0 X X X 0 0 X 0 0 X X 0 X X 0 HW1R-2DF22N1-j 1 2 3 4 HW-U10-F HW-U10-F HW-U01-F HW-U01-F 0 0 0 X X 0 0 X 0 0 X 0 0 X X 0 1 2 3 4 HW-U10-F HW-U10-F HW-U01-F HW-U01-F 0 0 0 X 0 X 0 0 0 0 X 0 X 0 0 0 1 2 3 4 HW-U01-F HW-U10-F HW-U01-F HW-U10-F 0 0 0 0 0 X 0 X X 0 X 0 0 X 0 X Timers D Contactors 2NO-2NC 2NO-2NC Terminal Blocks Code Black B White W Green G Yellow Y Red R Blue S HW1R-2EF22N1-j HW1R-2FF22N1-j HW1R-2N-j Operator Only T Circuit Breakers 2NO-2NC Color HW1R-2F-j Operator Only N Code HW1R-2E-j Operator Only 2NO-2NC Color HW1R-2D-j Operator Only F HW1R-2AF11-j 2NO Operator Only E Part Number HW1R-2NF22N2-j HW1R-2T-j 1 2 3 4 HW-U10-F HW-U10-F HW-U01-F HW-U01-F 0 0 X X X X 0 0 X X 0 0 Blocked HW1R-2TF22N1-j 1. All assembled part numbers in catalog include Finger-Safe spring-up (HW-U...) contacts. 2. Operator only models come with operator and button. 672 www.IDEC.com 1904032200 Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices Part Number Structure H W 1 R - 2 D F 22N1 – R Button Colors Operator B: Black G: Green R: Red S: Blue W: White Y: Yellow Contact Arrangement Code 11: 1NO-1NC 20: 2NO (For additional contact codes see previous page) Signaling Lights A: Cam A D: Cam D E: Cam E F: Cam F N: Cam N T: Cam T Note: Use only for interpreting part numbers. Do not use for developing part numbers. Pushbutton Selectors (Sub-assembled) Contact Blocks + Mounting Adaptor + Safety Lever Lock Anti-Rotation Ring + Operator Contacts 1NO 1NC FingerSafe Spring-Up Terminal HW-U10-F HW-U01-F HW-U10R-F (early make) HW-U01R-F (late break) = Completed Unit Buttons Style Part Number Part Number Round Flush HW9Z-LS HW1A-B1-j Anti-Rotation Ring HW-DB Style HW9Z-RL (safety lever lock included) Part Number Use with notched panel cutout to prevent unit rotation. Style Part Number Cam A HW1R-2A Cam D HW1R-2D Cam E HW1R-2E Cam F HW1R-2F Cam N HW1R-2N Cam T HW1R-2T j Button Color Code Color Code Color Code Black B White W Green G Yellow Y Red R Blue S Terminal Blocks 1. Used to mount contact blocks to operator (first pair only). 2. IDEC strongly recommends using the safety lever lock (included) to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. Description In place of j, specify the Button Color Code from table below. Contactors Operators HW-CB2C Part Number Contact Block Mounting Adaptor Style Button Timers Dummy Block Style + Relays & Sockets Safety Lever Lock Contact Blocks Style + Circuit Breakers 1904032200 800-262-IDEC (4332) • USA & Canada 673 Switches & Pilot Devices Relays & Sockets Signaling Lights Switches & Pilot Devices ø22mm - HW Series Dual Pushbutton Switches Key features: • Two pushbuttons and a pilot light are integrated into one spacesaving ø22 mm control unit. • Momentary and interlock types are available for pushbuttons. Interlock type prevents both buttons from being pressed at the same time. • Pilot lights are available in full voltage and transformer with LED. • IP40 protection, IP65 when using silicon boot. Applications: • Ideal for use as power switches and start/stop switches (available with I/ON and O/OFF markings on the buttons and a pilot light in the center). • Interlock type prevents two pushbuttons from being pressed at the same time. Dual Pushbutton Switches (Assembled) Part Numbers Without Center Pilot Light Timers Operation Type Button Style Flush (top) Flush (bottom) Momentary Contactors Flush (top) Extended (bottom) Circuit Breakers Terminal Blocks Flush (top) Flush (bottom) Interlock* Flush (top) Extended (bottom) Contact Arrangement Part Number Top Button Bottom Button 1NO 1NC HW7D-B11F1001-mn 1NO 1NO HW7D-B11F1010-mn 1NO-1NC 1NO-1NC HW7D-B11F1111-mn 2NO 2NC HW7D-B11F2002-mn 2NO 2NO HW7D-B11F2020-mn 1NO 1NC HW7D-B12F1001-mn 1NO 1NO HW7D-B12F1010-mn 1NO-1NC 1NO-1NC HW7D-B12F1111-mn 2NO 2NC HW7D-B12F2002-mn 2NO 2NO HW7D-B12F2020-mn 1NO 1NC HW7D-B21F1001-mn 1NO 1NO HW7D-B21F1010-mn 1NO-1NC 1NO-1NC HW7D-B21F1111-mn 2NO 2NC HW7D-B21F2002-mn 2NO 2NO HW7D-B21F2020-mn 1NO 1NC HW7D-B22F1001-mn 1NO 1NO HW7D-B22F1010-mn 1NO-1NC 1NO-1NC HW7D-B22F1111-mn 2NO 2NC HW7D-B22F2002-mn 2NO 2NO HW7D-B22F2020-mn mButton Color Code GR: Green (top) Red (bottom) WB: White (top) Black (bottom) nLegend Code Blank: Without legend 1: I/ON (top) O/OFF (bottom) 1. *Interlock type prevents both top and bottom buttons from being pressed simultaneously. 2. Clear silicon rubber cover part number HW9Z-D7D. 3. Additional contact configurations available (up to 6 total contacts). 674 www.IDEC.com 1904032200 Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices With Center Pilot Light Operation Type Button Style Flush (Top) Flush (Bottom) Flush (top) Flush (bottom) Momentary Flush (top) Extended (bottom) Interlock* Flush (Top) Extended (Bottom) Part Number 1NO 1NC HW7D-L11F1001kl-mn 1NO 1NO HW7D-L11F1010kl-mn 1NO-1NC 1NO-1NC HW7D-L11F1111kl-mn 2NO 2NC HW7D-L11F2002kl-mn 2NO 2NO HW7D-L11F2020kl-mn 1NO 1NC HW7D-L12F1001kl-mn 1NO 1NO HW7D-L12F1010kl-mn 1NO-1NC 1NO-1NC HW7D-L12F1111kl-mn 2NO 2NC HW7D-L12F2002kl-mn 2NO 2NO HW7D-L12F2020kl-mn 1NO 1NC HW7D-L21F1001kl-mn 1NO 1NO HW7D-L21F1010kl-mn 1NO-1NC 1NO-1NC HW7D-L21F1111kl-mn 2NO 2NC HW7D-L21F2002kl-mn 2NO 2NO HW7D-L21F2020kl-mn 1NO 1NC HW7D-L22F1001kl-mn 1NO 1NO HW7D-L22F1010kl-mn 1NO-1NC 1NO-1NC HW7D-L22F1111kl-mn 2NO 2NC HW7D-L22F2002kl-mn 2NO 2NO HW7D-L22F2020kl-mn Relays & Sockets Flush (Top) Flush (Bottom) Bottom Button Signaling Lights Flush (Top) Extended (Bottom) Top Button kPilot Light Illumination & Voltage Code Full Voltage l Pilot Lamp Color Code Timers 1. *Interlock type prevents both top and bottom buttons from being pressed simultaneously. 2. Clear silicon rubber cover part number HW9Z-D7D. 3. All assembled part numbers in catalog include Finger-Safe spring-up (HW-U...) contacts. mPushbutton Color Code Color Code Color Code A Top Green Code Green G Bottom Red 6V AC/DC, LED Q2 Red R Top White 12V AC/DC, LED Q3 Blue S Bottom Black 24V AC/DC, LED Q4 White W 120V AC, LED Q8 GR WB Engraving Code No Engraving Blank I/ON Top O/OFF Bottom 1 Contactors Amber Voltage nEngraving Codes Step-Down Transformer (6V Secondary LED Voltage) Code 120V AC, LED H22 240V AC, LED M42 480V AC, LED T82 Terminal Blocks Voltage Circuit Breakers 1904032200 800-262-IDEC (4332) • USA & Canada 675 Switches & Pilot Devices H Pilot Light Part Number Structure – L 21 F 20 20 H22 R – GR 1 Note: Use only for interpreting part numbers. Do not use for developing part numbers. Contact Blocks + Voltage Code Mounting Adaptor Part Number Description For use with HW-CBL on all illuminated pushbutton units. One required for each deck (pair) of contacts. Lead Holder Dummy Block with Full Voltage Adaptor For use with odd number of contacts. Full Voltage Adaptor For use with even number of contacts. + Safety Lever Lock 120VAC 240VAC 480VAC Button Operator Style HW-LH3 + Lens Momentary Flush (top) Extended (bottom) Interlock Flush (top) Flush (bottom) Flush (top) Extended (bottom) TW-DA1FB 1NC FingerSafe Spring-Up Terminal HW-U10-F HW-U01-F HW-U10R-F (early make) HW-U01R-F (late break) HW-DB Code Top Green Bottom Red GR 676 Non-illuminated HW-CB2C Illuminated (with Pilot Light) HW-CBL 1. Used to mount contact blocks to operator (first pair only). 2. IDEC strongly recommends using the safety lever lock (included) to prevent heavy vibration or maintenance personnel from inadvertently unlocking contacts. Style Instead of * insert: B: Non-illuminated L: Illuminated Code White Bottom Black WB Style Voltage Part Number 6V AC/DC LSTD-6k 12V AC/DC LSTD-1k 24V AC/DC LSTD-2k 120V AC LSTD-H2k 240V AC LSTD-M4k Nonilluminated HW9Z-B7B Illuminated HW9Z-L7W 1. In place of k, specify the LED Color Code. 2. The LED contains a current-limiting resistor and reverse polarity protection diodes. HW9Z-LS Anti-Rotation Ring Appearance kLED Color Code Part Number HW9Z-RL Top Lamps/Lens Part Number HW7D-*22m-n Color Contact Arrangement Chart Part Number Safety Lever Lock HW7D-*11m-n HW7D-*21m-n Completed Unit 1NO Style mPushbutton Color Code Color GR: Top: Green Bottom: Red WB: Top: White Bottom: Black HW-DA1FBN TW-F126B TW-F246B TW-F486B HW7D-*12m-n = Contacts Dummy Block Part Number Flush (bottom) Pushbutton Color Contact Blocks Operators Flush (top) Circuit Breakers + Contact Block Mounting Adaptor Style Y: Yellow blank: without center pilot light blank: No Engraving 1: Top: I/ON Bottom: O/OFF Dual Pushbutton Switches (Sub-assembled) Part Numbers Lamp Circuit Components with Finger-Safe Terminals Style Pilot Lamp Color A: Amber blank: without center pilot light G: Green Full Voltage* Transformer* Q2: 6V LED H22: 120V AC LED R: Red S: Blue *For additional voltage codes, please see previous page W: White 02: 2NC 20: 2NO Momentary (Flush/Flush) Momentary (Flush/Extended) Bottom Button 01: 1NC 02: 2NC Interlock (Flush/Flush) 10: 1NO 20: 2NO Interlock (Flush/Extended) Signaling Lights Relays & Sockets Timers 01: 1NC 10: 1NO Transformer Unit (6V secondary voltage) Contactors D Contact Arrangement Top Button Button Arrangement Terminal Blocks 7 Engraving Code B: Without Center Pilot Light L: With Center Pilot Light 11: 12: 21: 22: W LED Switches & Pilot Devices ø22mm - HW Series Use with notched panel cutout to prevent unit rotation. Color Code Color Code Amber A Blue S Green G White W Red R nEngraving Codes Engraving Code No Engraving I/ON Top O/OFF Bottom Blank 1 www.IDEC.com Contact Block Mounting Position Example 1904032200 Switches & Pilot Devices 1NO 1NO 1010 1NO 1NC 1001 1NC 1NO 0110 1NC 1NO 2NO 1NO-1NC 1NO 2NC 1NC 2NO 1NO-1NC 1NC 2NC 1NO 1NC 1NO-1NC 1NC 0111 0102 2010 2001 1110 1101 NO 2 NC 1 NC 2 NO 1 NC 2 NC 1 NO 2 NO 3 Dummy 4 NO 1 NO 2 NO 3 Dummy 4 NC 1 NO 2 NC 3 Dummy 4 NC 1 NC 2 NO 3 Dummy 4 NO 1 NC 2 NO 3 Dummy 4 NC 1 NC 2 NC 3 Dummy 4 NC 1 NO 2 NO 3 NO 4 Dummy 1 NO 2 NC 3 NO 4 Dummy 1 NO 2 NO 3 NC 4 Dummy 1 NO 2 NC 3 NC 4 Dummy X X X Mounting Position 3 Mounting Position 1 X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X Circuit Breakers 1NO-1NC 1NO 0120 1 Mounting Position 4 Mounting Position 2 Push Terminal Blocks 2NO 1002 NO Bottom Button Normal Contactors 2NO 1011 NO 2 Push Timers 1NC 1020 1 Normal Relays & Sockets 1NO 0101 Top Button Type Signaling Lights 1NC Contact Block Mounting Position X 1. Transformers can have two or four contact blocks only. 2. Contact blocks 1 and 3 are actuated by the top button. Contact blocks 2 and 4 are actuated by the bottom button. 1904032200 Switches & Pilot Devices Contact Arrangement Top Button Bottom Button Contact Code ø22mm - HW Series 800-262-IDEC (4332) • USA & Canada 677 Switches & Pilot Devices Signaling Lights Switches & Pilot Devices ø22mm - HW Series Contact Arrangement Top Button 2NC 2NC Relays & Sockets 2NO 2NO Timers 2NO 1NO-1NC Contactors 1NO-1NC 1NO-1NC 2NC Terminal Blocks Contact Block Mounting Position Example Contact Arrangement Chart (con’t) 2NC Circuit Breakers 2NC 678 Bottom Button 1NO 1NC 2NO 1NO-1NC 2NC 2NO 1NO-1NC 2NC 2NO 1NO-1NC 2NC Contact Code 0210 0201 2020 2011 2002 1120 1111 1102 0220 0211 0202 Contact Block Mounting Position Top Button Type Normal 1 NC X 2 NO 3 NC 4 Dummy 1 NC 2 NC 3 NC 4 Dummy 1 NO 2 NO 3 NO 4 NO 1 NO 2 NO 3 NO 4 NC 1 NO 2 NC 3 NO 4 NC 1 NO 2 NO 3 NC 4 NO 1 NO 2 NO 3 NC 4 NC 1 NO 2 NC 3 NC 4 NC 1 NC 2 NO 3 NC 4 NO 1 NC 2 NO 3 NC 4 NC 1 NC 2 NC 3 NC 4 NC Bottom Button Push Normal Mounting Position 4 Mounting Position 2 Push X X Mounting Position 3 Mounting Position 1 X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X X www.IDEC.com 1904032200 Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices Contactor Reset Button Signaling Lights Reset Buttons (Assembled) j Button Color Code Metal Bezel (Blank) HW1B-M1RS-jT HW4B-M1RS-jT Color Code Color Code Engraved “R” HW1B-M1RS-jT-ENG-R HW4B-M1RS-jT-ENG-R Black B White W Green G Yellow Y Red R Blue S 1. In place of j specify Button Color Code. 2. 130mm (5.1”) overall length. 3. 16mm flat base for easy alignment Relays & Sockets Plastic Bezel Contactor Reset Button (Sub-assembled) Rod + Operator + Button = Completed Unit Timers Rod Button Style Part Number Style Part Number HW1A-B1-j Operator Style Plastic Contactors HW9Z-RS-TK2141 Metal In place of j, specify the Button Color Code from table. j Button Color Code HW4B-MO Code Color Code Black B White W Green G Yellow Y Red R Blue S Terminal Blocks HW1B-MO Color Circuit Breakers 1904032200 800-262-IDEC (4332) • USA & Canada 679 Switches & Pilot Devices Switches & Pilot Devices ø22mm - HW Series Nameplates - HW Series Engraving Plate 1.6 0.9 12.1 30 R14.9 ø22 1 45 2.7 HWAV–Yellow Plastic 22mm ø22 1.9 1 Nameplate (blank engraving plate included) HWAM-OB HWAQ-OB HWAS-OB HWAV-O HWAV5-0† Nameplate (engraved) HWAM-j HWAQ-j HWAS-j HWAV-27* HWAV5-27† Additional Insert (blank) HWNP-O HWNP-O HWNP Dimensions Additional Insert (engraved) HWNP-j HWNP-j 12 Signaling Lights 1.5 HWAS–Black Plastic 27 14.5 14.9 2 29 2.7 14.5 14.9 R14.9 ø2 Relays & Sockets Engraving Plate 12.1 30 29 27 HWAQ–Black Plastic ø60mm HWAM–Black Plastic 27 1. In place of j, insert either the standard legend code from table below or custom engraving delimited by “ “. 2. Standard engravings are available at no charge. 3. * HWAV-27 comes engraved “Emergency Stop” as shown in drawing. 4. † HWAV5-27 and HWAV5-0 for 60mm diameter E-Stops (80mm diameter nameplate). Standard Legend Codes Pushbuttons/Selector Switches Selector Switches Legend Code Legend Code Legend Code Legend Code Legend Code AUTO CLOSE DOWN EMERG.STOP FAST FORWARD HAND HIGH IN INCH JOG LOW LOWER OFF ON 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 OPEN OUT RAISE RESET REVERSE RUN SLOW START STOP TEST UP I (Int’l On) O (Int’l Off) EMO 116 117 118 119 120 121 122 123 125 126 127 150 151 152 AUTO-MAN CLOSE-OPEN DOWN-UP FAST-SLOW FOR-REV HAND-AUTO HIGH-LOW JOG-RUN LEFT-RIGHT LOWER-RAISE MAN-AUTO OFF-ON ON-OFF OPEN-CLOSE RAISE-LOWER 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 REV-FOR RUN-JOG RUN-SAFE SAFE-RUN SLOW-FAST START-STOP STOP-START UP-DOWN OI (Int’l OFF ON) 216 217 218 219 220 221 222 223 250 AUTO-MAN-OFF AUTO-OFF-MAN CLOSE-OFF-OPEN DOWN-OFF-SLOW FAST-OFF-SLOW FOR-OFF-REV LEFT-OFF-RIGHT LOWER-OFF-RAISE OFF-MAN-AUTO OFF-SLOW-FAST OFF-1-2 OPEN-OFF-CLOSE SLOW-OFF-FAST SUMMER-OFF-WINTER UP-OFF-DOWN 1-OFF-2 HAND-OFF-AUTO 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 1. To order engraved nameplates, add legend code to nameplate part number. 2. Character height based on the number of characters and size of nameplate. Standard character size is 3/16”. 3. Nameplates with standard legends are the same list price as blank nameplates. 4. Nameplates have built-in anti-rotation feature for use with notched panel cut-outs. Additional anti-rotation ring (HW9Z-RL) is not necessary. Circuit Breakers Terminal Blocks Contactors Timers Pushbuttons 680 www.IDEC.com 1904032200 Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices Nameplates Order Form — HW Series Copy this order form and use it to specify Letter Height, Custom Engravings, Location of Engraving on Nameplate, and Quantity Desired. To ensure engraving accuracy, fax it to your IDEC representative or Distributor. IDEC Rep/Distributor Contact: Name: PO number (if known): Telephone: IDEC Rep/Distributor Phone: Fax & Email: IDEC Rep/Distributor Fax & Email: Signaling Lights Your Company: HWAM Nameplate Engraving Location Step 2. Specify Quantity. Enter the number of nameplates desired in the box on the right. 7/64” Letter Size 11 characters maximum (for 7/64” size letters) 1/8” Letter Size 9 characters maximum (for 7/8” size letters) Relays & Sockets Step 1. Choose Letter Size - 7/64” or 1/8”. Check the box for the letter size you want. Then write your lettering in box below the check boxes. Note: 1/8” size letters cannot exceed 9 characters. Sample Letter Sizes Qty 1 2 3 4 5 6 7 8 9 10 11 7/64” Letters: ABCD 1/8” Letters: A BCD HWAQ Nameplate 11 characters maximum (for 7/64” size letters) 1/8” Letter Size 9 characters maximum (for 1/8” size letters) Sample Letter Sizes Qty 1 2 3 4 5 6 7 8 9 10 11 7/64” Letters: ABCD 1/8” Letters: A BCD Contactors Step 2. Specify Quantity. Enter the number of nameplates desired in the box on the right. 7/64” Letter Size Timers Engraving Location Step 1. Choose Letter Size - 7/64” or 1/8”. Check the box for the letter size you want. Then write your lettering in box below the check boxes. Note: 1/8” size letters cannot exceed 9 characters. HWAS Nameplate Engraving Location A Step 2. Specify Quantity. Enter the number of nameplates desired in the box on the right. Qty 20 characters maximum (for 3/32” size letters) 1/8” Letter Size 14 characters maximum (for 1/8” size letters) A 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 B 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 Circuit Breakers Step 3. Specify Location. Enter the location of engraving Location (A or B or Both), in box on the right. 3/32” Letter Size Terminal Blocks Engraving Location B Step 1. Choose Letter Size - 3/32” or 1/8”. Check the box for the letter size you want. Then write your lettering in box below the check boxes. Note: 1/8” size letters cannot exceed 14 characters. Sample Letter Sizes 3/32” Letters: A B C D 1/8” Letters: A 1904032200 800-262-IDEC (4332) • USA & Canada BCD 681 Switches & Pilot Devices Signaling Lights Switches & Pilot Devices ø22mm - HW Series Switch Engraving Order Form – HW Series Copy this order form and use it to specify Letter Height, Maximum Number of Lines and Text to be engraved. To ensure engraving accuracy, fax it to your IDEC representative or Distributor. Your Company: Telephone: Name: Fax: Address: Email: PO: Part Number to be Engraved: Please check one of the boxes below to indicate your choice of engraving options: ø29mm, ø40mm Mushroom Head Relays & Sockets Engraving # of Lines Letter Height Max. Characters Per Line 5/32 5 Timers 1 Contactors Engraving Area 1 Round Switch Square Switch # of Lines Area 2† Letter Height Max. Characters Per Line 5/32 5 1 1/8 6 5/32 5 2 1/8 5 5/32 5 2 1/8 6 3 1/8 6 4 3/32 5 1/8 6 3 1/8 5 4 3/32 5 Engraving Area 1 1 Engraving Area 2 1 Letter Height Max. Characters Per Line 5/32 5 1/8 5 5/32 7 1/8 7 1. Above mentioned specifications hold true for standard size pushbuttons (round and square). 2. †Engraving Area 2 can be engraved for 40mm mushroom Head non-Illuminated push button only. 3. Engraving is done on the button itself for non-Illuminated push buttons and on marking plate for illuminated push buttons and pilot lights. 4. Please enter text exactly how you want it engraved, take care to emphasize capital or small letters. Enter text to be engraved: Sample Letter Sizes 1/8 Letters: Line 1: 5/32 Letters: Line 2: Terminal Blocks # of Lines Line 3: Line 4: Circuit Breakers For IDEC Internal Use Only: Work Order #: 682 www.IDEC.com 1904032200 Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices Accessories Item Appearance Part Number Locking Ring Wrench Metallic tool used to tighten the plastic locking ring when installing the HW series in a panel MW9Z-T1 Lamp/LED Removal Tool Rubber tool makes lamp/LED removal easier. OR-55 Anti-Rotation Ring Prevents rotation of switches in panel. (included with all assembled switches except pilot lights) for notched panel cutout (standard) HW9Z-RL for round panel cutout LW9Z-L Black rubber plug fills unused 7/8” mounting holes in panel. OB-31 Metallic Mounting Hole Plug For plugging unused 7/8” mounting holes in the panel. Tighten the attached locking ring to a torque of 12 kfg-cm maximum Degree of protection: IP66 LW9Z-BM Used to cover and protect pushbuttons Flush Pushbuttons OC-31 Operating temperature: –50 to +60°C Extended Pushbuttons OC-32 Pushbutton Clear Boot Padlock Cover Plastic hinged padlockable cover to protect pushbuttons or selector switches. (Not intended for E-Stops) Relays & Sockets Rubber Mounting Hole Plug Signaling Lights Description/Usage HW9Z-KL1 Degree of protection: IP65 Tab #250 (6.35 x 0.8mm): Single tab Mounting Adaptor Used to mount round HW series (except Jumbo Mushroom, unibody, and square units) into a larger panel cut-out. (includes both pieces) TW-FA4 22 to 30mm HW9Z-A30 22 to 25mm HW9Z-A25 Timers Tab Terminal Adapter Used to prevent contact mounting lever from moving due to heavy vibration or panel maintenance. HW9Z-LS Reset Rod for Contactors Overload 5” rod used with HW1B-M0. HW9Z-RS-TK2141 Replacement Operator Washer Provided with operator. Insert between bezel and locking ring. HWM-WASHER Replacement Locking Ring Plastic locking nut comes with all HW operators & assemblies. Switch Cover (Square) Used only with round or square flush pushbuttons. HW9Z-K1 (spring return) HW9Z-K11 (maintained cover) Replacement Keys Pair of Keys (#231) HW9Z-SKP Replacement Lens HW Illuminated Unibody Replacement Lens HWLV-LENSR HW9Z-LN Optional (metal) HW9Z-LNM Circuit Breakers 800-262-IDEC (4332) • USA & Canada Standard (plastic) Terminal Blocks 1904032200 Contactors Replacement Safety Lever Lock 683 Switches & Pilot Devices Timers Relays & Sockets Signaling Lights Switches & Pilot Devices ø22mm - HW Series Item Appearance Description/Usage Replacement Jumbo Dome Lens Part Number HW1A-P5j j = (A, G, R, S, W, Y)) Polycarbonate Replacement Lens (If using yellow lens, use white LED.) Replacement Jumbo LED Diffusing Lens HW9Z-PP5C Replacement LED Lamps for HW Jumbo Dome Replacement LED Lamp - applicable for jumbo pilot lights only LSTDB-2j j = (A, G, R, S, W) Rubber Cover for Dual Pushbuttons Clear Silicon rubber cover HW9Z-D7D Barrier for Dual Pushbuttons Plastic barrier. Used when mounting the HW7 units on 30mm horizontal centers, to prevent possible interconnections between adjoining terminals. HW-VU1 Emergency stop nameplate sticker HW9Z-EMO-NP-TK2120 E MO EMO Sticker 1NC Contact Blocks (with side entry) These contacts are applicable for wires terminated by ring, fork, terminals, not recommended for bare wire connections. These contacts are applicable for wires terminated by ring, fork, or ferule terminals, and also bare wire connections. Contact Blocks (without side entry) 1NO HW-U01 HW-U01-MAU HW-U01R HW-U01R-MAU (with side entry) HW-U10 HW-U10-MAU HW-U10R HW-U10R-MAU (with side entry) HW-U01-F HW-U01-MAU-F HW-U01R-F HW-U01R-MAU-F (no side entry) HW-U10-F HW-U10-MAU-F HW-U10R-F HW-U10R-MAU-F (no side entry) E-Stop Shrouds E-Stop Types Applicable Standards HW9Z-KG1 40mm Mushroom Head SEMI S2-0703, 12.5.1 Compliant HW9Z-KG2 40mm Mushroom Head SEMI S2-0703, 12.5.1 & SEMATECH Compliant Part Numbers Style E-Stop Types Applicable Standards HW9Z-KG3 40mm Mushroom Head SEMI S2 Compliant (Approved by TUV) ISO 13850 HW9Z-KG4 40mm Mushroom Head SEMI S2 Compliant (Approved by TUV) & SEMATECH ISO 13850 Part Numbers Circuit Breakers Terminal Blocks Contactors Style 684 www.IDEC.com 1904032200 Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices Contact Assemblies Standard Contact Assemblies Full Voltage Contact Assemblies For use with Non-Illuminated Pushbuttons & E-Stops For use with Illuminated Pushbuttons. Style Contacts Part Number Standard Finger-Safe Contacts 1NO 1NC 1NO/1NC 2NO 2NC 2NO/2NC HW-CBF10 HW-CBF01 HW-CBF11 HW-CBF20 HW-CBF02 HW-CBF22 Gold contact option is available. Add suffix “MAU” to end of part number. For example, HW-CBF20 becomes HW-CBF20-MAU. Contacts Part Number 1NO 2NO 1NO/1NC 1NC 2NC HW-FL10Q0 HW-FL20Q0 HW-FL11Q0 HW-FL01Q0 HW-FL02Q0 Order LED separately. Signaling Lights Style Transfomer Contact Assemblies For use with Illuminated Pushbuttons. Style Part Number 120V AC with LED 1NO 2NO 1NC 1NO/1NC HW-FL10H2-k HW-FL20H2-k HW-FL01H2-k HW-FL11H2-k 240V AC with LED 1NO 2NO 1NC 1NO/1NC HW-FL10M4-k HW-FL20M4-k HW-FL01M4-k HW-FL11M4-k 480V AC with LED 1NO 2NO 1NC 1NO/1NC HW-FL10T8-k HW-FL20T8-k HW-FL01T8-k HW-FL11T8-k Relays & Sockets Contacts 2. 6V LED included. Timers 1. In place of k, specify the LED Color Code. k = A, G, R, S, or W Dimensions (mm) Non-Illuminated Pushbuttons Flush (HW1B-M1, -A1) Panel Thickness 0.8 to 6 Locking Ring Safety Lever Lock Panel Thickness 0.8 to 6 49.4 (1 block) 69.4 (2 or 3 blocks) 89.4 (4 blocks) 13 23.2 Locking Ring Safety Lever Lock LO Panel Thickness 0.8 to 6 ø 29 41.4 LO CK Locking Ring Safety Lever Lock Panel Thickness 0.8 to 6 49.4 (1 block) 69.4 (2, 3 blocks) 89.4 (4 blocks) 13 29.4 CK 29.6 41.4 29.4 15 LO 26.5 25 26.5 25 ø60 41.4 26.5 25 ø 40 29.4 69.4 (3 or 4 blocks) CK Square Flush (HW2B-M1, -A1) CK 49.4 (1 or 2 blocks) LO 26.5 25 Panel Thickness 0.8 to 6 Terminal Blocks 41.4  29.6 19 ø60mm Mushroom (HW1B-M5) Panel Thickness 0.8 to 6 13 23.2 Locking Ring Safety Lever Lock 26.5 25 ø 23.6 29.4 13 69.4 (3 or 4 blocks) ø40mm Mushroom (HW1B-M4, -A4) 49.4 (1 block) 69.4 (2 or 3 blocks) 89.4 (4 blocks) CK ø29 49.4 (1 or 2 blocks) ø 23.6 29.4 13 Locking Ring Safety Lever Lock 41.4  29.6 ø29 41.4 49.4 (1 or 2 blocks) 69.4 (3 or 4 blocks) LO CK Contactors LO ø29mm Mushroom (HW1B-M3 -A3) 26.5 25 Locking Ring Safety Lever Lock Extended (HW1B-M2, -A2) 24.6 29.4 30.1 Circuit Breakers 1904032200 800-262-IDEC (4332) • USA & Canada 685 Switches & Pilot Devices Square Extended (HW2B-M2, -A2) Terminal Wiring Arrows indicate access directions for wiring Locking Ring Safety Lever Lock Panel Thickness 0.8 to 6 LO CK 29.6 26.5 25 49.4 (1 or 2 blocks) 69.4 (3 or 4 blocks) 13 19 1 contact block 24.8 29.4 2 contact blocks 4 contact blocks Operators Dimensions (mm) Flush (Round & Square) Extended Round Panel Thickness 0.8 to 6 LO Square CK LO LO CK CK Relays & Sockets 3.6 13 .6 23 ø 13 ø2 29.4 29.4 18.5 24.8 29.4 Extended with Full Shroud ø40mm Mushroom LO LO CK Timers 18.5 41.4 3.6 ø40 41.4 ø29.5 25 25 CK ø2 Extended 41.4 ø23.5 41.4 29.6 41.4 25 25 25 Signaling Lights Contact Block (Bottom View) 41.4 Switches & Pilot Devices ø22mm - HW Series 29.4 13 29.4 23.2 Emergency Stop Pushbuttons Dimensions (mm) ø29mm Head Pushlock Turn Reset (HW1B-V3) Panel Thickness 0.8 to 6 Gasket Terminal Screw M3.5 LOC K ø29 41.4 25 Contactors Locking Ring 50.2 (1 or 2 blocks) 70.2 (4 blocks) 29.4 32 ø40mm Head EMO Pushlock Turn Reset (HW1B-V4) LO LOC K Locking Ring 26.5 CK Lock Lever 0 ø4 20 41.4 ø40 Circuit Breakers 50.2 (1 or 2 blocks) 13 41.4 ø40mm Head Pushlock Turn Reset (HW1B-V4) 13 25 2 contact blocks 4 contact blocks 25 Terminal Blocks 1 contact block 29.4 70.2 (4 blocks) 13 32 29.4 32 686 www.IDEC.com 1904032200 Switches & Pilot Devices Switches & Pilot Devices ø40mm Head Pushlock Key Reset (HW1B-X4) ø22mm - HW Series ø60mm Head Pushlock Turn Reset (HW1B-V5) LO ø60 41.4 ø40 25 CK 13 29.4 32 15 Signaling Lights 34.5 49.4 ø40mm Head Push-Pull (HW1B-Y2) ø40mm Head Unibody Pushlock Turn Reset (HW1B-BV4) LO Panel Thickness 0.8 to 6 CK Gasket M3.5 Terminal Screw Relays & Sockets ø40 ø40 41.4 25 Locking Ring 13 29.4 25.5 TOP Marking Terminal Cover 11.5 46 14 32 48 Illuminated E-Stop Pushbuttons (HW1E-LV4) Mounting Hole Panel Thickness 0.8 to 6 R0.8 max. 3.2 ø22 .3 Locking Ring +0.4 0 ø40 24.1 TOP Marking +0.2 0 +0.4 0 Gasket M3.5 Terminal Screw Lamp Terminal 14 32 63 Unit Vertical Spacing Horizontal Spacing HW1B-V3 HW1B-V4 HW1B-X4 HW1B-Y2 50 mm 50 mm HW1B-V5 60 mm 60 mm Contactors 11.5 61 Terminal Cover The minimum mounting centers shown below are applicable to E-Stop switches with one layer of contact blocks (two contact blocks). When two layers of contact blocks are mounted, determine the minimum mounting centers for ease of wiring. Timers M3.5 Terminal Screw Terminal Arrangement (Bottom View) HW1E-BV4 Side HW1E-LV4 TOP X1 .3 (NO) .1 (NC) .4 (NO) (1NO-1NC) LAMP .2 (NC) .3 (NO) .1 (NC) .4 (NO) Terminal Blocks .2 (NC) X2 (1NO-1NC) Circuit Breakers 1904032200 800-262-IDEC (4332) • USA & Canada 687 Switches & Pilot Devices Emergency Stop Stations Dimensions (mm) A 76 59.5 Mounting Hole Layout Operator Dimension A (mm) Pushlock Turn Reset 32 Pushlock Key Reset 32 (Key inserted: 49.4) Push Pull 25.5 4-M4 Tapped Holes for Rear Mounting (Depth: 10 mm) 2-Front Mounting Holes ø14 Knockout 21 76 Switches & Pilot Devices ø22mm - HW Series Signaling Lights 21 41 HW1B-V4R Box Cover Mouting Screws Box Cover Box Base 2- ø4 15.5 .6 62 Pilot Lights Dimensions (mm) Round Flush Terminal screws: M3.5, integrated terminal cover ø2 24 24 3.5 ø2 3.5 9 ø2 Panel Thickness 0.8 to 6 Gasket Locking Ring Panel Thickness 0.8 to 6 Gasket Locking Ring ø2 9 Panel Thickness 0.8 to 6 Gasket Locking Ring 110V DC, 380V AC minumum 9 100/110V AC, 200/220V AC (240V AC maximum) ø2 Relays & Sockets 6, 12, 24V AC/DC, Without LED lamp ø2 3.5 11.5 43.3 60.8 7 7 76.2 29.6 7 29.6 Extended Terminal screws: M3.5, integrated terminal cover 3. Panel Thickness 0.8 to 6 Gasket Locking Ring 9 6 11.5 43.3 60.8 17.5 17.5 24 24 ø 9 ø2 29 3.6 3.6 ø2 Gasket Locking Ring ø2 110V DC, 380V AC minimum Panel Thickness 0.8 to 6 ø2 Gasket Locking Ring Timers 100/110V AC, 200/220V AC (240V AC maximum) Panel Thickness 0.8 to 6 ø2 6, 12, 24V AC/DC, Without LED lamp 29.6 76.2 17.5 29.6 6, 12, 24V AC/DC, Without LED lamp 100/110V AC, 200/220V AC (240V AC maximum) Panel Thickness 0.8 to 6 Panel Thickness 0.8 to 6 Gasket Locking Ring 11.5 7 Jumbo Dome Pilot Light terminal cover 29.6 Panel Thickness 0.8 to 6 Gasket Locking Ring 24.6 60.8 7 76.2 29.6 7 29.6 Terminal screws: M3.5, integrated LED Lamp LSTDB Panel Thickness 1 to 5 Base BA9S/13 Illumination Color Mounting Hole Layout R0.8 max. ø22.3 +0.4 0 3.2 +0.2 0 Mounting Hole Layout Close mounting on 30mm centers Degree of protection: IP65 .3 ø22 24.1 ø10.6 Light blue: LSTDB +0.4 0 Terminal Blocks 43.3 110V DC, 380V AC minimum 24.6 Gasket Locking Ring 24.6 Contactors Square Flush Terminal screws: M3.5, integrated terminal cover +0.4 0 30 min. Circuit Breakers 85 20.4 Locking Ring 6 ø6 Gasket 34.4 0.5 85 50.5 30 min. When mounting transformer or DC-DC converter type units on 30mm centers vertically and horizontally, keep the ambient temperature below 40ºC. 688 www.IDEC.com 1904032200 Switches & Pilot Devices ø22mm - HW Series Switches & Pilot Devices Illuminated Pushbuttons Full Voltage Models 1 Contact Block 2 Contact Blocks 3 Contact Blocks Full Voltage Adapter Full Voltage Adapter M3.5 Terminal Screw Contact Block Locking Ring M3.5 Terminal Screw Contact Block Locking Ring Panel Thickness 0.8 to 6 Full Voltage Adapter M3.5 Terminal Screw Contact Block Panel Thickness 0.8 to 6 Panel Thickness 0.8 to 6 Locking Ring Signaling Lights X1 X2 50.2 (1 block) 1 contact block 65.8 (2 blocks) 2 contact blocks 3 contact blocks Dimensions (mm) 4 Contact Blocks Terminal Wiring Arrows indicate access directions for wiring. Full Voltage Adapter Contact Block Full Voltage Adaptor M3.5 Terminal Screw Contact Block Locking Ring Transformer Panel Thickness 0.8 to 6 X1 X2 Timers 85.8 (4 contacts) 4 contact blocks Relays & Sockets Illuminated Pushbuttons con’t 70.2 (3 blocks) Transformer Models DC-DC Converter Models Safety Lever Lock 3 X1 Locking Ring 4 X2 X2 M3.5 Terminal Screws 89.7 (2 blocks) 109.5 (4 blocks) Contactors X1 M3.5 Terminal Screw 89.5 (2 blocks) 109.5 (4 blocks) Terminal Blocks Circuit Breakers 1904032200 800-262-IDEC (4332) • USA & Canada 689 Switches & Pilot Devices Non-Illuminated Selector & Key Switches Dimensions (mm) Knob Operator Terminal Wiring Locking Ring Safety Lever Lock Panel Thickness 0.8 to 6 49.4 (1 block) 69.4 (2-3 blocks) 89.4 (4 blocks) 7 45° Arrows indicate access directions for wiring. (2-position 90° maintained) (3-position) LO 45° Contact Block Full Voltage Adaptor CK Signaling Lights 1 contact block ø29 41.4 26.5 25 Switches & Pilot Devices ø22mm - HW Series 2 contact blocks 4 contact blocks 29.4 21 Key Operator Tranformer LO 9.4 ø2 25 Relays & Sockets CK 17 41.4 X1 X2 13 29.4 30.5 Illuminated Selector Switches Full Voltage Model Transformer Model 45° LO (2-position Locking Ring Safety Lever Lock 45° CK 90° maintained) Panel Thickness 0.8 to 6 ø 29 41.4 26.5 25 ø 29 X2 25 X1 25 41.4 21 45° CK 79.5 (2 blocks), 99.5 (4 blocks) 29.4 7 21 29.6 Circuit Breakers Terminal Blocks Contactors 7 LO 25 4 49.4 (1 block) 69.4 (2-3 blocks) 89.4 (4 blocks) 45° (3-position) 26.5 Timers Panel Thickness 0.8 to 6 (3-position) 3 Locking Ring Safety Lever Lock (2-position 90° maintained) 690 www.IDEC.com 1904032200 Switches & Pilot Devices ø22mm - HW Series Dimensions (mm) Without Pilot Light Mounting Hole Layout ø22 *3.2 +0. 4 0 +0.2 0 24.1 .3 +0.4 0 HW R0.8 max. 49.4 (2 contacts) 69.4 (3 or 4 contacts) 55 ** 18.7 18.7 18.7 54.8 54.8 41.4 14.5 20 24.6 29.8 24.6 29.8 With Pilot Light Full Voltage Full Voltage Adapter HW The depth of a 3-contact model depends on the combination of contact blocks at top and bottom pushbuttons. (Bottom Button) (Top Button) 1 contact block 2 contact blocks Bottom Button 2 contact blocks 1 contact block Depth 89.4 mm 69.4 mm Timers Top Button -The 3.2 mm recess is for preventing rotation and is not necessary when a nameplate or anti-rotation ring is not used. -When using the safety lever lock, determine the vertical spacing in consideration of convenience for installing and removing the safety lever lock. -Recommended vertical spacing: 100 mm -The minimum mounting centers are applicable to switches with one layer of contact blocks (two contact blocks). When two layers of contact blocks are mounted, determine the minimum mounting centers for ease of wiring. Relays & Sockets 49.4 (1 or 2 blocks) 69.4 (3 or 4 blocks) 30 18.7 Panel Thickness 0.8 to 6 Signaling Lights Locking Ring Safety Lever Lock 69.4 (2 contacts), 89.4 (4 contacts) (Note) Transfomer (240V minimum) Switches & Pilot Devices Dual Pushbutton Transformer (480V) Transformer Transformer, DC-DC Converter HW HW Contactors 89.5 (2 contacts), 109.5 (4 contacts) 79.5 (2 contacts), 99.5 (4 contacts) Monolever Dimensions All dimensions in mm. Interlocking Lever Locking Ring Safety Lever Lock LO Panel Thickness 0.8 to 6 36 max. CK 72 24 ° 49.4 (1-2 blocks) 69.4 (3-4 blocks) Terminal Screws M3.5 800-262-IDEC (4332) • USA & Canada 36 max. 41.4 24° 29.4 ø30 29.4 ø34.2 72 Circuit Breakers 69.4 (3-4 blocks) 36 max. 41.4 49.4 (1-2 blocks) 1904032200 LO 24 ° 24° 36 max. CK 26.5 25 Panel Thickness 0.8 to 6 26.5 25 Locking Ring Safety Lever Lock Terminal Blocks Standard Lever Integrated Terminal Cover 691 Switches & Pilot Devices Accessory Dimensions TOP 1.5 ø29 ø22 3.5 3.5 HW9Z-D7D Dual Pushbutton Rubber Cover ø25 HW-VU1 Dual Pushbutton Barrier MW9Z-T1 Locking Ring Wrench 22.5 HW-VL1 Barrier 8 ø2 110 45 45 33 59 58 Signaling Lights OR-55 Lamp/LED Removal Tool ø11.6 Gasket Locking Ring HW9Z-RL Anti-Rotation Ring ø29 3 ø25.8 OB-31 Rubber Mounting Hole Plug ø14 LW9Z-BM Metallic Mounting Hole Plug 12 Switches & Pilot Devices ø22mm - HW Series 20 HWLS-TK1971 Safety Lever Lock Safety Lever Lock Panel Thickness 0.8 to 3.2 82.5 Screwdriver Remove Operator 6.5 ø2 2.2 29.5 30 Key Hole ø8 Waterproof Rubber Gasket 0.5t HW9Z-KG1 Contact Block Mounting Adapter Panel HW9Z-KG2 38 22 36.5 2.2 ø2 80 32 64 48 ø76.1 Timers Safety Lever Lock CK LO 26.5 70 30 93 Lock Lever 24 0 ø5 .4) 44 :ø (ID Contactors 1.5 Install HW9Z-KL1 Padlock Cover 1.5 R6 Relays & Sockets 20 ø22 ø90 Gasket TOP Marking TOP Marking Locking Ring TOP Marking TOP Marking Locking Ring Operator Panel Thickness: 1.2 to 4 Panel Thickness: 1.2 to 4 HW9Z-KG3 HW9Z-KG4 LSTD 35 25 ø2 35 25 2 ø9.5 50 692 www.IDEC.com 20.4 Circuit Breakers 42 ø10.6 ø90 67 ø75 ø74 52 ø22 ø66 Terminal Blocks Operator 1904032200 Switches & Pilot Devices ø22mm - HW Series INDUCTIVE INDUCTIVE RESISTIVE RESISTIVE DC Voltages DC Voltages AC Voltages AC Voltages 0.5 0.2 0.1 1 0.5 0.2 600V AC 0.1 12 600V AC 3 24 5 36 4 510 6 HW-U10-F (NO) HW1S-2T HW1K-2* HW1F-2 HW-U01-F (NC) HW-U10R-F (NO-EM) HW-U10-F (NO) HW-U10R-F (NO-EM) HW-U01R-F (NC-LB) 0.2 0.1 12 Right L O X R O X L X O R X O L O X R O X L X O R X O 42 5 36 4 510 6 10 in A Current inCurrent A Contact Position Left 3 Mounting Position HW-U10-F (NO) HW1S-3JT HW1K-3J* HW-U01-F (NC) HW-U10R-F (NO-EM) HW-U01R-F (NC-LB) Operator Position Left Center Right O L X O R O O X L O X O R O X O L X O X R X O X L O X X R X X O 4 Position Selector Switches Contact Operator Position Mounting Position Left L X O O R O O X L O X X R X X O L X O O R O O X L O X X R X X O Center Right HW-U10-F (NO) HW1S-4T HW-U01-F (NC) HW-U10R-F (NO-EM) HW-U01R-F (NC-LB) Operator Position Mounting Position 1 2 3 4 L X O O O R O O O X L O O X O R O X O O L X X O X R X O X X L O X X X R X X X O Contactors HW1S-3T HW1K-3* HW1F-3 HW-U01-F (NC) 0.5 Conforming to IEC 947-5-1 Appendix C. Utilization categories AC-15 and DC-13. Operation rate: 1,800 op. hour Load factor: Inductive 0.4 ± 0.05 Resistive 0.9 ± 0.05 Conforming IEC 947-5-1 Appendix C. Conforming toTruth IECto947-5-1 Appendix C. Operator Tables Utilization categories AC-15AC-15 and DC-13. Utilization categories and DC-13. 3 Position Selector Operation rate: 1,800 op. hour Operation rate: 1,800 op. hour Switches con’t Load factor: 0.9 ± 0.05 Load factor: 0.9 ± 0.05 3 Position Selector Switches Contact 1 600V AC 120V AC 120V AC 500V AC 500V AC 480V AC 480V AC 400V AC 400V AC 380V AC 380V AC 240V AC 240V AC Timers HW-U01R-F (NC-LB) 0.2 1.0 Relays & Sockets Mounting Position 0.5 0.1 10 in A Current inCurrent A Conforming IEC 947-5-1 Appendix C. Conforming to IECto947-5-1 Appendix C. Utilization categories AC-15AC-15 and DC-13. Utilization categories and DC-13. 2 Operation Position Selector Switches Operation rate: 1,800 op. hour rate: 1,800 op. hour Load factor: 0.4 ± 0.05 Load factor: 0.4 ± 0.05 Operator Contact 600V AC 1.0 110 2.2 Signaling Lights Millions of Operating Cycles 120V AC 120V AC 1.0 500V AC 1.0 500V AC 480V AC 480V AC 400V AC 400V AC 380V AC 380V AC 240V AC 240V AC VoltageVoltage V 24 V 4824 11048 CurrentCurrent A 8 A 4 8 2.24 Millions of Operating Cycles 110 1.1 Millions of Operating Cycles 48 VoltageVoltage V 24 V 4824 110 CurrentCurrent A 4 A 2 4 1.12 Millions of Operating Cycles DC Voltages DC Voltages AC Voltages AC Voltages Switches & Pilot Devices Specification Charts 5 Position Selector Switches HW-U10-F (NO) HW1S-3ST HW1K-3S* HW-U01-F (NC) HW-U01R-F (NC-LB) Left Center Right L X O O R O O X L O O X R X O O L X X O R O X X L O X X R X X O 1. Mounting position indicates which side of operator each contact should be mounted (as viewed from the front of the panel). 2. *For key removable code see page 663. 1904032200 Contact HW-U10-F (NO) HW1S-5T HW-U01-F (NC) HW-U10R-F (NO-EM) HW-U01R-F (NC-LB) Operator Position Mounting Position 1 2 3 4 5 L X O O O O R O O O O X L O O O X O R O X O O O L X X X O X R X O X X X L O X X X X R X X X X O Circuit Breakers HW-U10R-F (NO-EM) Mounting Position Terminal Blocks Contact Operator Position 3. HW1S-3T is identified by white plungers on the operator. 4. HW1S-3ST is identified by red plungers on the operator. 5. HW1S-3JT is identified by black plungers on the operator. 800-262-IDEC (4332) • USA & Canada 693 Switches & Pilot Devices HW Safety Precautions Turn off power to HW series control units before starting installation, removal, wiring, maintenance, and inspection of the products. Failure to turn power off may cause electrical shocks or fire hazard. Signaling Lights For wiring, use wires of a proper size to meet voltage and current requirements. HW General Instructions Panel Mounting Remove the contact block assembly from the operator (for transformer type pilot lights, remove the transformer from the illumination unit). Remove the locking ring from the operator. Insert the operator into the panel cut-out from the front, tighten the locking ring from the back, then install the contact block assembly to the operator. Removing and Installing the Contact Block Assembly 1. To remove the operator from the contact block, turn the locking lever in the direction of the arrow shown below. The operator can now be removed. Relays & Sockets To avoid the possibility of burning yourself, use the lamp holder tool when replacing lamps. 2. To reinstall, place the TOP markings on the operator and the contact block mounting adapter in the same direction, and insert the operator into the contact block mounting adapter. Then turn the locking lever in the opposite direction. Safety Lever Lock IDEC strongly recommends using the safety lever lock (HW9Z-LS, yellow) to prevent heavy vibration or maintenance personnel from unlocking the contact assembly. 1. HW series can be mounted vertically with a minimum spacing of 55 mm but spacing should be determined to ensure easy operation (recommended minimum spacing: 100 mm). 2. Mount the control unit onto the panel, lock the lever, and push in the safety lever lock to install. 3. When the spacing is narrower than the recommended value, with the lever unlocked, mount the safety lever lock and insert the contact unit to the operator. Then, lock the lever and strongly push in the safety lever lock to install. 4. To remove the safety lever lock, insert a flat screwdriver into the safety lever and push upwards. Safety Lever Lock Screwdriver Remove Lock Lever Safety Lever Lock CK LO Timers 26.5 Operator Install Switches & Pilot Devices ø22mm - HW Series Contact Block Mounting Adapter Panel Contactors Notes for Panel Mounting 1. When mounting the operator onto a panel, use the optional locking ring wrench (MW9Z-T1) to tighten the locking ring. Tightening torque must not exceed 2.0 N·m. Do not use pliers. Excessive tightening will damage the locking ring. 2. For the contact blocks and transformers housing LED lamps, make sure not to press the lamps too hard, otherwise the lamp socket may be damaged. Terminal Blocks Dual Pushbutton Instructions Replacement of Lens Removing Remove the lens by inserting a screwdriver into the recess of the lens through the bezel. Installing Circuit Breakers Install the lens in the recess between the buttons by pressing against the bezel. 694 www.IDEC.com 1904032200 Switches & Pilot Devices ø22mm - HW Series Replacement of Lamps Installation of LED Illuminated Units LED lamps can be replaced by using the lamp holder tool (OR-55) from the front of the panel, or by removing the contact block assembly from the operator unit. When using full voltage type LED illuminated units, provide protection against electrical noise, if necessary. Removing the Lamps from the Front of the Panel Applicable Wiring The applicable wire size is 2 mm2 maximum. (solid wire ø1.6mm2 maximum) One or two wires can be connected. Removal 7.9 max. ø3.6 min. 4 max. 5.5 min. Be sure to use an insulation tube or cover on the crimping part of the crimping terminal to prevent electrical shocks. Installation Solid Wire Lamp Holder Tool ø1.6 max. Lamp Relays & Sockets 1. To install, insert the lamp head into the lamp holder tool, and hold the lamp as shown in the figure below. Signaling Lights Applicable Crimping Terminal 1. To remove, slip the lamp holder tool onto the lamp head lightly. Then push slightly, and turn the lamp holder tool counterclockwise. 8 max. 2. Place the pins on the lamp base to the grooves in the lamp socket. Insert the lamp and turn it clockwise. Lamp Base Note: When connecting wires to contact blocks or transformers in the direction shown below, keep the insulation stripping length 6.6 mm at the maximum. X1 Do not attempt to remove the pushbuttons! The dual pushbuttons cannot be removed or replaced! X2 Inside Pushbuttons X1 Timers About Dual Pushbutton Switches Do not attempt to remove using a flat screwdriver or pincers, otherwise the dual pushbuttons may be damaged. X2 Inside Installing the Rubber Boot When mounting the units closely in a horizontal row on 30mm centers, use optional barriers to prevent interconnection between adjoining terminals. The barriers can be attached simply by pressing them onto the sides of contact blocks. 30 30 Notes for Installing the Rubber Boot Remove the gasket from the operator, and install the rubber boot on the operator. Pull out the seals of the rubber boot and place them around the operator sleeve as shown. Make sure that the seals are not twisted or tucked inside and that the gasket does not remain, otherwise the normal waterproof and dustproof characteristics are not ensured. 2. Install the rubber boot on the pushbuttons. 3. Rubber boot is installed. Terminal Blocks 1. Remove the gasket. Seals Install Barrier X1 X2 Inside Remove X1 X2 Gasket Seals Circuit Breakers When mounting transformer type illuminated units closely in a horizontal row on 30-mm centers, insert solid wires or stranded wires into inside of the terminal screw on the transformer (see figure on the right) to prevent short circuit between adjoining terminals. Inside 800-262-IDEC (4332) • USA & Canada Contactors When using the HW7D pushbuttons in places where the pushbuttons are subjected to water splash or an excessive amount of dust, make sure to use the HW9Z-D7D rubber boot (IP65) which is ordered separately. Narrow Mounting 1904032200 Switches & Pilot Devices Dual Pushbuttons Instructions continued 695
HWAVF-27 价格&库存
很抱歉,暂时无法提供与“HWAVF-27”相匹配的价格&库存,您可以联系我们找货
HWAVF-27
    • 1+57.932851+7.53287
    HWAVF-27
      • 1+22.62600
      • 200+9.02880
      • 500+8.72640
