MOFO-HD20-50
MOFO-HD20-50
    TECHLOGIX
    CABLE M-M HDMI-A 50M
MOFO-HD20-50 数据手册
Introducing the Media over Fiber Optic™ Series from TechLogix. TechLogix MOFO™ HDMI, DisplayPort and USB cables leverage a true fiber core to deliver unparalleled speed, bandwidth and reliability. Pre-terminated connectors accommodate installations in seconds and the optical construction provides complete immunity to RF, EM and electrical interference. Plus, MOFO™ cables are built with four strands of re-terminable multimode fiber allowing cable runs to be upgraded and re-purposed in the future. Discover more online at www.tlnetworx.com. HDMI PART NUMBER MOFO-HD20-10 MOFO-HD20-15 MOFO-HD20-23 MOFO-HD20-30 MOFO-HD20-50 MOFO-HD21-10 MOFO-HD21-15 MOFO-HD21-23 MOFO-HD21-30 LENGTH 10m / 33ft. 15m / 50ft. 23m / 75ft. 30m / 100ft. 50m / 165ft. 10m / 33ft. 15m / 50ft. 23m / 75ft. 30m / 100ft. CONNECTOR A Male HDMI Male HDMI Male HDMI Male HDMI Male HDMI Male HDMI Male HDMI Male HDMI Male HDMI CONNECTOR B Male HDMI Male HDMI Male HDMI Male HDMI Male HDMI Male HDMI Male HDMI Male HDMI Male HDMI BANDWIDTH / FORMAT 18G / HDMI 2.0 18G / HDMI 2.0 18G / HDMI 2.0 18G / HDMI 2.0 18G / HDMI 2.0 48G / HDMI 2.1 48G / HDMI 2.1 48G / HDMI 2.1 48G / HDMI 2.1 MAX RESOLUTION 4K60 4:4:4 HDR 4K60 4:4:4 HDR 4K60 4:4:4 HDR 4K60 4:4:4 HDR 4K60 4:4:4 HDR 8K60 8K60 8K60 8K60 JACKET 4.5mm Plenum 4.5mm Plenum 4.5mm Plenum 4.5mm Plenum 4.5mm Plenum 4.5mm Plenum 4.5mm Plenum 4.5mm Plenum 4.5mm Plenum LENGTH 10m / 33ft. 15m / 50ft. 23m / 75ft. 30m / 100ft. 50m / 165ft. CONNECTOR A Male DisplayPort Male DisplayPort Male DisplayPort Male DisplayPort Male DisplayPort CONNECTOR B Male DisplayPort Male DisplayPort Male DisplayPort Male DisplayPort Male DisplayPort BANDWIDTH / FORMAT 32.4G / DP 1.4 32.4G / DP 1.4 32.4G / DP 1.4 32.4G / DP 1.4 32.4G / DP 1.4 MAX RESOLUTION 8K60 8K60 8K60 8K60 8K60 JACKET 4.8mm Plenum 4.8mm Plenum 4.8mm Plenum 4.8mm Plenum 4.8mm Plenum LENGTH 10m / 33ft. 15m / 50ft. 23m / 75ft. 30m / 100ft. CONNECTOR A Male USB A Male USB A Male USB A Male USB A CONNECTOR B Female USB A Female USB A Female USB A Female USB A BANDWIDTH / FORMAT 5G / USB 3.0 5G / USB 3.0 5G / USB 3.0 5G / USB 3.0 COMPATIBLE SPEED SuperSpeed SuperSpeed SuperSpeed SuperSpeed JACKET 4.3mm Plenum 4.3mm Plenum 4.3mm Plenum 4.3mm Plenum DisplayPort PART NUMBER MOFO-DP14-10 MOFO-DP14-15 MOFO-DP14-23 MOFO-DP14-30 MOFO-DP14-50 USB PART NUMBER MOFO-USB3-10 MOFO-USB3-15 MOFO-USB3-23 MOFO-USB3-30 Media over Fiber Optic™ Cables | Features & Specifications HDMI 2.0 SPECIFICATIONS HDMI / HDCP Version Max Bandwidth / Resolution Construction Power Min Bend Rating Max Pull-Strength Environmental HDMI 2.0 / HDCP 2.0 18G / 4K60 4:4:4 HDR 4 strand multimode OM3 + 8 conductor copper Plenum rated jacket / black color 4.5mm jacket diameter Kevlar strength member 250mW max draw / powered by HDMI bus 48mm / 1.8 inches 70 lbs. 0° C to 50° C / 85% humidity (non-condensing) FEATURES • • • • • • • • Fiber-based HDMI cable No power required (completely powered by HDMI bus) Supports 18G 4K60 4:4:4 HDR / HDCP 2.0 / 3D / Deep Color Supports multi-channel audio / Dolby TrueHD / DTS-HD Master Audio / ARC Supports EDID / CEC / HEC Directional operation – clearly marked source & display headshells Interference-free performance Four strand multimode OM3 construction – supports re-termination in the field • • • • • • • • • • Fiber-based HDMI cable No power required (completely powered by HDMI bus) Backwards compatible with HDMI 2.0 & HDMI 1.4 devices Supports 48G 8K60 HDR / HDCP 2.2 / 3D / Deep Color Supports VRR / QMS / QFT / ALLM / DSC Supports multi-channel audio / Dolby TrueHD / DTS-HD Master Audio / ARC / eARC Supports EDID / CEC / HEC Directional operation – clearly marked source & display headshells Interference-free performance Four strand multimode OM3 construction – supports re-termination in the field • • • • • • • Fiber-based DisplayPort cable No power required (completely powered by DisplayPort bus) Supports 32.4G 8K60 / HBR3 / HDCP 1.4 / HDCP 2.2 Supports EDID / Link Training Directional operation – clearly marked source & display headshells Interference-free performance Four strand multimode OM3 construction – supports re-termination in the field • • • • • • • • • Fiber-based USB cable Male Type A USB connector to Female Type A USB connector Compatible with USB 3.0 (SuperSpeed) devices Not compatible with USB 1.1 (full-speed) or USB 2.0 (high-speed) devices No power required (completely powered by USB bus) Plug-and-play – no drivers required Directional operation – clearly marked source & display headshells Interference-free performance Four strand multimode OM3 construction – supports re-termination in the field HDMI 2.1 SPECIFICATIONS HDMI / HDCP Version Max Bandwidth / Resolution Construction Power Min Bend Rating Max Pull-Strength Environmental HDMI 2.1 / HDCP 2.2 48G / 8K60 4 strand multimode OM3 + 8 conductor copper Plenum rated jacket / black color 4.5mm jacket diameter Kevlar strength member 250mW max draw / powered by HDMI bus 48mm / 1.8 inches 70 lbs. 0° C to 50° C / 85% humidity (non-condensing) FEATURES DisplayPort 1.4 SPECIFICATIONS DisplayPort Version Max Bandwidth / Resolution Video Performance Construction Power Min Bend Rating Max Pull-Strength Environmental DP 1.4 32.4G 8K60 810MHz pixel clock / 48bit color depth 4 strand multimode OM3 + 8 conductor copper Plenum rated jacket / black color 4.8mm jacket diameter Kevlar strength member 250mW max draw / powered by source device 48mm / 1.8 inches 70 lbs. 0° C to 50° C / 85% humidity (non-condensing) FEATURES USB 3.0 SPECIFICATIONS USB Version Max Bandwidth Construction Power Min Bend Rating Max Pull-Strength Environmental USB 3.0 / SuperSpeed 5G 4 strand multimode OM3 + 8 conductor copper Plenum rated jacket / black color 4.3mm jacket diameter Kevlar strength member 5V (4.75 min – 5.25 max) 48mm / 1.8 inches 70 lbs. 0° C to 50° C / 85% humidity (non-condensing) FEATURES
MOFO-HD20-50
物料型号: - HDMI系列:MOFO-HD20-10至MOFO-HD21-30,长度从10米到50米不等。 - DisplayPort系列:MOFO-DP14-10至MOFO-DP14-50,长度从10米到50米。 - USB系列:MOFO-USB3-10至MOFO-USB3-30,长度从10米到30米。
器件简介: - MOFO™系列电缆利用真正的光纤核心,提供无与伦比的速度、带宽和可靠性。 - 预装连接器可在几秒钟内完成安装。 - 光纤结构提供对射频、电磁和电气干扰的完全免疫。
引脚分配: - 所有电缆均为直通型,一端为公头,另一端为母头。
参数特性: - HDMI 2.0系列支持18Gbps带宽,最高4K60 4:4:4 HDR分辨率。 - HDMI 2.1系列支持48Gbps带宽,最高8K60分辨率。 - DisplayPort 1.4系列支持32.4Gbps带宽,最高8K60分辨率。 - USB 3.0系列支持5Gbps带宽,兼容SuperSpeed设备。
功能详解: - 所有电缆无需外部电源,完全由相应的总线供电。 - 支持现场重新端接,具有四根可重新端接的多模光纤。 - 环境适应性:0°C至50°C,85%湿度(非凝结)。
应用信息: - 适用于需要长距离传输高质量视频和数据的应用场景。
封装信息: - 所有电缆都有阻燃外皮,外径分别为4.5mm(HDMI)、4.8mm(DisplayPort)和4.3mm(USB)。
MOFO-HD20-50 价格&库存
很抱歉,暂时无法提供与“MOFO-HD20-50”相匹配的价格&库存,您可以联系我们找货
MOFO-HD20-50
    库存:23
