TL-10GSFPP-MM300
TL-10GSFPP-MM300
    TECHLOGIX
    10G MM SFP+ TRANSCIEVER
TL-10GSFPP-MM300 数据手册
TL-10GSFP-MM300 Technical Specifications v170918 Technical Specifications TL-10GSFPP-MM300 Features at a Glance • Hot-pluggable SFP+ footprint • Supports 9.95 to 10.5 Gb/s bit rates • Power dissipation < 1W • RoHS-6 compliant (lead-free) • Commercial temperature range 0 to 70°C • Single 3.3V power supply • Maximum link length of 300m on 2000 MHZ-km OM3 MMF • Heated 850nm VCSEL laser • Receiver limiting electrical interface • Duplex LC connector • Built-in digital diagnostic functions The 10GSFPP-MM300 transceivers are designed for use in 10-Gigabit Ethernet links over multimode fiber. They are compliant with SFF-8431, SFF-8432, IEEE 802.3ae 10GBASE-SR/SW and 10G Fibre Channel 1200Mx-SN-I. Digital diagnostics functions are available via a 2-wire serial interface, as specified in SFF-8472. The transceiver is a “limiting module”, i.e., it employs a limiting receiver. Host board designers using an EDC PHY IC should follow the IC manufacturer's recommended settings for interoperating the host-board EDC PHY with a limiting receiver SFP+ module. The optical transceivers are compliant per the RoHS Directive 2011/65/EU. Basic Specifications Form Type Max Data Rate Wavelength Max Cable Distance Interface Optical Components Cable Type DOM Support TX Power Receiver Sensitivity Commercial Temperature Range SFP+ 10.3125 Gbps 850nm 300m over OM3 MMF LC duplex VCSEL 850nm MMF Yes -7.3~-1dBm < -11.1dBm 0 to 70°C (32 to 158°F) www.tlnetworx.com | +1-608-960-7242 TL-10GSFP-MM300 Technical Specifications v170918 Specifications General Product Characteristics Parameter Bit Rate Bit Error Ratio Max. Supported Link Length on 50μm Fiber OM2 Max. Supported Link Length on 50μm Fiber OM3 Max. Supported Link Length on 50μm Fiber OM4 Absolute Maximum Ratings Parameter Storage Temperature Case Operating Temperature Supply Voltage Operating Relative Humidity Symbol BR BER LMAX LMAX LMAX Min 9.95 Symbol TS TA VCC RH Min -40 -40 -0.5 0 Typ. Max 10.5 -12 10 82 300 400 Unit Gbps Typ. Max +85 +85 4.0 85 Unit °C °C V % m m m Electrical Characteristics (TOP = 0 to 70°C, VCC = 3.14 to 3.46 V) Parameter Power Supply Voltage Power Supply Current Symbol VCC ICC Min 3.15 Typ. 3.3 Max 3.45 300 Unit V Ma Symbol Rin Vin,pp VD VEN Min Typ. 100 Max Unit Ω mV V V Symbol Vout,pp tr VLOS norm VLOS fault VccT/VccR Min 300 28 Vee 2 Symbol POMA PAVE λ Δλrms ER TDP POFF Txj
TL-10GSFPP-MM300 价格&库存
很抱歉,暂时无法提供与“TL-10GSFPP-MM300”相匹配的价格&库存,您可以联系我们找货
