TL-3STRIP
TL-3STRIP
    TECHLOGIX
    FIBER STRIPPER
TL-3STRIP 数据手册
TL-3STRIP Technical Specifications v191101 Technical Specifications Fiber Optic Jacket Stripper Features at a Glance • Ideal for preparing fiber optic cabling for termination • For use with both multimode and single mode fiber • High-quality steel construction • Comfortable yellow plastic grips • Serrated blade • Safety lock • Spring design • Three-hole construction The Fiber Optic Jacket Stripper is a professional-grade tool for preparing fiber optic cable for connector termination. It features three precise holes for use with various types of fiber optic cable, including both multimode and single mode, from virtually any manufacturer. The largest hole is ideal for stripping the 1.6 - 3mm fiber jacket down to the 600-900 micron buffer. The middle hole is ideal for stripping the 600 -900 micron buffer down to the 250 micron coating. The smallest hole is ideal for stripping the 250 micron coating dow n to the 125 micron glass and/or polymer fiber. The Fiber Optic Jacket Stripper is an essential tool for any fiber installer. Specifications Overall Construction Blade Construction Handle Construction Dimensions Weight S50C steel HRC 48+/-2 Yellow plastic 148mm (5.9 inch) length 0.13kg (0.28 lbs.) www.tlnetworx.com | +1-608-960-7242
TL-3STRIP 价格&库存
很抱歉,暂时无法提供与“TL-3STRIP”相匹配的价格&库存,您可以联系我们找货
