TL-DA14-F2
TL-DA14-F2
    TECHLOGIX
    1X4 HDMI SPLITTER
TL-DA14-F2 数据手册
TL-DA14-F2 Technical Specifications v191025 Technical Specifications TL-DA14-F2 Features at a Glance • Advanced EDID management • Automatic downscaling per output • Supports HDMI 2.0, 4Kx2K@60Hz 4:4:4 • HDCP 2.2 compliant • 18Gbps video bandwidth The TL-DA14-F2 is an 18Gbps HDMI splitter with four simultaneous outputs. Compatible with HDMI 2.0a & HDCP 2.2/1.4 sources and devices, the TL-DA14-HD2 supports video resolutions up to 8k30 (4:2:0 8bit). The TL-DA14-F2 will support 4k video with HDR1, xvYCC, x.v.Color, and Deep Color. The TL-DA14-F2 can downscale video2 on each output individually to match the connected display’s highest compatible resolution. This feature is required when mixing 4k and 1080p displays in the same installation. Advanced EDID management puts you in control of what resolution the source will output. Notes: 1. HDR content can pass through the TL-DA14-F2 but cannot be processed to properly for 1080p displays. 2. Certain video conversions are not supported: a. 4k60 4:2:2 to 1080p b. Frame rate conversion c. 4k60 4:2:2 to 4k60 4:2:0 www.tlnetworx.com | +1-608-960-7242 TL-DA14-F2 Technical Specifications v191025 Specifications I/O Connections HDMI Input HDMI Outputs DC 5V Power One HDMI type A receptacle Four HDMI type A receptacle One micro USB Type B port Supported Video and Audio Resolutions Video Compliance Bandwidth Embedded Audio Compatibility Maximum Passive HDMI Distance Input DDC Signal Input Video Signal 480i, 480p, 576i, 576p, 720p, 1080i, 1080p, 1080p, 4Kx2K (60Hz 4:2:0 10bit, 60Hz 4:4:4 8bit), 8kx4k (30Hz 4:2:0 8bit) HDMI 2.0a, HDCP 2.2 Single-link 600MHz (18 Gbps) DTS-HD Master Audio, Dolby TrueHD, Dolby Digital, DTS, DVD-Audio, LPCM, SACD, MPCM 10 m (33 ft) 5.0 volts p-p (TTL) 0.5 ~ 1.0 volts p-p Chassis and Environmental Enclosure Dimensions (W x H x D) Dimensions (W x H x D) (Package) Weight Weight (Shipping) Operating Temperature (Environment) Operating Humidity (Environment) Storage Temperature (Environment) Painted steel 136mm x 62mm x 20 mm (5.3 in x 2.4 in x 0.8 in) 264mm x 170mm x 77mm (10.4 in x 6.7 in x 3 in) Storage Humidity (Environment) 20% ~ 90% Non-condensing 0.23 Kg (8.1 oz) 0.77 Kg (1.7 lbs) 0° ~ 40° C (+32° ~ +104° F) 20% ~ 90% Non-condensing -20° ~ 60° C (-4° ~ +140° F) Power, ESD, Regulatory Maximum Power Consumption Power Supply Regulatory 10W 5V at 2A DC CE, FCC Other Standard Warranty Indicators Firmware Update Included Items 3 Year 1 Power, 1 Input status , 4 Output connection status Via Mini-USB (Front Panel) User Manual Card, Power adaptor www.tlnetworx.com | +1-608-960-7242 TL-DA14-F2 Technical Specifications v191025 Dimensional Drawings www.tlnetworx.com | +1-608-960-7242
TL-DA14-F2 价格&库存
很抱歉,暂时无法提供与“TL-DA14-F2”相匹配的价格&库存,您可以联系我们找货
