TL-FO-DVI
TL-FO-DVI
    TECHLOGIX
    DVI OVER FIBER EXTENDER
TL-FO-DVI 数据手册
TL-FO-DVI Technical Specifications v161102 Technical Specifications TL-FO-DVI Features at a Glance  Compliant with HDMI video  Resolution is up to 4kx2K/30Hz  300m transmission for multi-mode fiber  EDID management  Mini design The TL-FO-DVI is a mini DVI optical fiber extender, including a transmitter and a receiver. It is compatible with HDMI video up to 4Kx2K/30Hz, and extends HDMI/DVI video up to 300m via single optical fiber cable with EDID management. The TL-FO-DVI provides a perfect solution for DVI/HDMI video transmission. Specifications I/O Connections DVI Optical fiber 5V DC Power One DVI connector One LC connector One 3.0 mm outside Diameter, 1.0 mm inside Diameter Supported Audio and Video Maximum Video Compatibility Video Compliance Input DDC Signal Input Video Signal 300m: 4kx2K@30Hz 4:4:4 8bit; 1080p@60Hz 4:4:4 16bit HDMI1.4 without HDCP, DVI1.0 5.0 Volts p-p(TTL) 0.5-1.0 Volts p-p Optical Fiber Maximum Distance Cable 300m Multi-mode fiber Chassis and Environmental Enclosure Dimensions(WxHxD) Shipping Weight Operating Temperature (Environment) Operating Humidity(Chassis) Storage Temperature(Environment) Storage Humidity(Environment) Painted aluminum 69.5mm x 10.2mm x 40mm 0.52kg (Tx + Rx) 0° C - +50° C 10% - 90% -10° C - +50° C 10% - 90% www.tlnetworx.com | +1-608-960-7242 TL-FO-DVI Technical Specifications v161102 Power,ESD,and Regulatory Maximum Power Consumption Power Supply ESD Protection Regulatory 4.35 watts (Tx + Rx) 5V DC 8kV CE,FCC Other Standard Warranty Indicators Included Items 1 Year Power User Manual, Power adapter Dimensional Drawings www.tlnetworx.com | +1-608-960-7242
TL-FO-DVI 价格&库存
很抱歉,暂时无法提供与“TL-FO-DVI”相匹配的价格&库存,您可以联系我们找货
