TL-FO-HD
TL-FO-HD
    TECHLOGIX
    HDMI OVER FIBER EXTENDER
TL-FO-HD 数据手册
Technical Specifications v161102 Technical Specifications TL-FO-HD Features at a Glance  Supports 4K HDMI video  Compliant with HDCP 1.4  Compliant with single-mode or multi-mode optical fiber  400m transmission for single-mode fiber  300m transmission for multi-mode fiber  EDID/HDCP/CEC pass through  Micro USB connector for power supply The TL-FO-HD is a mini 4K HDMI optical fiber extender, including a transmitter and a receiver. It supports HDMI1.4 & HDCP1.4, extends 4K HDMI video up to 400m via single optical fiber cable, with EDID/HDCP/CEC pass through. The TL-FO-HD provides a perfect solution for 4K HDMI video transmission. Specifications I/O Connections HDMI Optical 5V DC Power One HDMI Type A connector One LC connector One Micro USB connector Supported Audio and Video Maximum Video Compatibility Video Compliance Embedded Audio Input DDC Signal Input Video Signal Optical Fiber Maximum Distance Cable 400m: 4kx2K@30Hz 4:4:4 8bit; 1080p@60Hz 4:4:4 16bit HDMI1.4, HDCP1.4,CEC pass through Up to PCM 8 channel, Dolby Digital TrueHD and DTS-HD Master Audio 5.0 Volts p-p(TTL) 0.5-1.0 Volts p-p 400m/300m Single-mode fiber/Multi-mode fiber Chassis and Environmental Enclosure Dimensions(WxHxD) Shipping Weight Operating Temperature (Environment) Operating Humidity(Chassis) Painted aluminum 69mm x 10mm x 20mm 0.52kg (Tx + Rx) 0° C - +50° C 10% - 90% www.tlnetworx.com | +1-608-960-7242 Technical Specifications v161102 Storage Temperature(Environment) Storage Humidity(Environment) -10° C - +50° C 10% - 90% www.tlnetworx.com | +1-608-960-7242 Technical Specifications v161102 Power, ESD, and Regulatory Maximum Power Consumption Power Supply ESD Protection Regulatory Other Standard Warranty Indicators Included Items 2.5 Watts (Tx), 2.3 Watts (Rx) 5V DC 8kV CE, FCC 1 Year Power, Link User Manual, Power adapter, Optical fiber cable (0.5m) Dimensional Drawings www.tlnetworx.com | +1-608-960-7242
TL-FO-HD
1. 物料型号:TL-FO-HD 2. 器件简介:TL-FO-HD是一款迷你4K HDMI光纤延长器,包括一个发射器和一个接收器。支持HDMI 1.4和HDCP 1.4,通过单根光纤电缆延长4K HDMI视频传输距离可达400米(单模光纤)或300米(多模光纤),具备EDID/HDCP/CEC直通功能。 3. 引脚分配:包含一个HDMI Type A接口、一个LC连接器和一个Micro USB电源接口。 4. 参数特性: - 支持的音视频:最大视频兼容性为400米传输4Kx2K@30Hz 4:4:4 8bit或1080p@60Hz 4:4:4 16bit。 - 视频符合标准:HDMI 1.4、HDCP 1.4、CEC直通。 - 嵌入式音频:支持多达8声道的PCM、Dolby Digital TrueHD和DTS-HD Master Audio。 5. 功能详解:提供了完美的4K HDMI视频传输解决方案。 6. 应用信息:适用于需要长距离传输4K HDMI视频的应用场景。 7. 封装信息:外壳为喷涂铝材质,尺寸为69mm x 10mm x 20mm,运输重量为0.52kg(发射器+接收器)。
TL-FO-HD 价格&库存
很抱歉,暂时无法提供与“TL-FO-HD”相匹配的价格&库存,您可以联系我们找货
