TL-FO2-VLC-MM
TL-FO2-VLC-MM
    TECHLOGIX
    HDMI+CONTROL OVER FIBER EXTENDER
TL-FO2-VLC-MM 数据手册
TL-FO2-HDC Technical Specifications v181029 Technical Specifications TL-FO2-HDC Features at a Glance • Transmit HDMI and IR or RS232 over two fiber optic conductors • LC connectors for fiber connection • Single & multimode fiber compatible • Extend 18G HDMI up to 300m (984 ft.) • HDMI 2.0 & HDCP 2.2 compliant • 4K@60 compliant • Immune to RF & EM interference The TL-FO2-HDC is an HDMI 2.0 (18G signal) with HDCP 2.2 support fiber optic extender set that can reach up to 300 meters (984 ft) over a duplex OM3 cable with common LC terminations. The unit supports HDMI video resolutions up to 4K@60, HDR video, IR or RS232 pass-through controls and multichannel audio. The TL-FO2-HDC is also compatible with HDMI 1.3/1.4 content with HDCP 1.3/1.4 content protection. www.tlnetworx.com | +1-608-960-7242 TL-FO2-HDC Technical Specifications v181029 Specifications Transmitter Input/Output HDMI Input Optical Output IR Input/Output RS232 12V DC Control Selector 1 HDMI Receptacle 2 LC Ports via SFP+ Module 2 3.5mm TRS Ports 1 3-pin Removable Terminal Block 1 5.5mm OD/2.5mm ID Threaded Barrel Connector 1 2-position Switch Receiver Input/Output HDMI Output Optical Input IR Input/Output RS232 12V DC Control Selector 1 HDMI Receptacle 2 LC Ports via SFP+ Module 2 3.5mm TRS Ports 1 3-pin Removable Terminal Block 1 5.5mm OD/2.5mm ID Threaded Barrel Connector 1 2-position Switch Supported Audio, Video, and Control Compatible Video Signals All SD, HD, and other resolutions up to - 4K/60 Hz / RGB and 4:4:4 8 bit (HDR) - 4K/60 Hz / 4:2:2 10 bit (HDR) - 4K/60 Hz / 4:2:0 10 bit (HDR) HDMI 2.0, HDMI 1.4, DVI 2.0 (Pixel clock up to 594 MHz) HDCP 1.2 / HDCP 2.2 Compatible LPCM, Dolby Digital/Plus/EX, Dolby True HD, DTS, DTS-EX, DTS-96/24, DTS High Res, DTS-HD Master Audio, DSD 2400, 4800, 9600, 19200, 38400, 57600, 115200 33 to 55 kHz Video Compliance Digital Content Protection Embedded Audio Supported RS232 Baud Rates Supported IR Carrier Fiber Optic Transmission Characteristics Required Cable Type Maximum Bandwidth Maximum Distance with Stock SFP+ Modules Signal Compression Duplex OM3 10 Gbps 300m (984 ft) 1.8:1 Maximum; Compression starts when video signal >9 Gbps Chassis and Environmental Product Construction Product Dimensions (W*H*D) Product Operational Chassis Temperature Environmental Operating Temperature Environmental Operating Humidity Environmental Storage Temperature Environmental Storage Humidity Painted aluminum 150 mm (5.91 in) x 20 mm (0.79 in) x 74.4 mm (2.93 in) 35 to + 44°C (95 to + 111 °F) 0 to + 45°C (32 to + 113 °F) 10% to 90%, non-condensing -20 to +70°C (-4 to + 158 °F) 10% to 90%, non-condensing Power and Regulatory Power Input Power Supply Input Power Supply Output Maximum Power Consumption ESD Protection Regulatory Compliance 12V DC 100-240V AC at 50/60 Hz; 0.5A Max 12V DC at 1 A 6 watts Human-body Model: ±8kV Air-gap discharge and ±4kV Contact discharge FCC, CE, RoHS, WEEE Other Warranty Diagnostic LEDs Included Accessories Three years Link, Status, HDCP and Power IR Receiver (2 ea), IR Transmitter (2 ea), Mounting Ears (4 ea), Rubber Feet (8 ea), 12V 1A DC Power Supply (2 ea), 3-pin 3.5mm Terminal Block (2 ea) www.tlnetworx.com | +1-608-960-7242 TL-FO2-HDC Technical Specifications v181029 Transmitter Dimensional Drawings www.tlnetworx.com | +1-608-960-7242 TL-FO2-HDC Technical Specifications v181029 Receiver Dimensional Drawings www.tlnetworx.com | +1-608-960-7242
TL-FO2-VLC-MM 价格&库存
很抱歉,暂时无法提供与“TL-FO2-VLC-MM”相匹配的价格&库存,您可以联系我们找货
