TL-FO2-HDC2
TL-FO2-HDC2
    TECHLOGIX
    HDMI+CONTROL OVER FIBER EXTENDER
TL-FO2-HDC2 数据手册
TL-FO2-HDC2 Technical Specifications v180501 Technical Specifications TL-FO2-HDC2 Features at a Glance • Transmit HDMI, IR & RS232 over two fiber optic conductors • LC connectors for fiber connection • Single & multimode fiber compatible • Audio Return Channel (ARC) • Extend 18G HDMI up to 300m (984 ft.) • HDMI 2.0 & HDCP 2.2 compliant • 4K@60 compliant • Immune to RF & EM interference The TL-FO2-HDC2 is an HDMI 2.0 (18G signal) with HDCP 2.2 support fiber optic extender that can reach up to 300 meters (984 ft) over a duplex OM3 or OS2 cable with common LC terminations. The unit supports HDMI video resolutions up to 4K@60, HDR video, IR or RS232 pass-through controls, multichannel audio, as well as ARC with optional optical audio embedding and/or de-embedding. The TL-FO2-HDC2 is also compatible with HDMI 1.3/1.4 content with HDCP 1.3/1.4 content protection. The TL-FO2-HDC2 supports two ARC connection modes: HDMI and S/PDIF, which results in four options to pass audio from the display to the head end. When the receiver is set to HDMI, audio from the display will pass to the transmitter via the HDMI output port. When the receiver is set to S/PDIF, audio from the display will pass to the transmitter via the S/PDIF optical audio port. When the transmitter is set to HDMI, audio from the receiver will be provided on the HDMI input port. When the transmitter is set to S/PDIF, audio from the receiver will be provided on the S/PDIF optical audio port. www.tlnetworx.com | +1-608-960-7242 TL-FO2-HDC2 Technical Specifications v180501 Specifications Transmitter Input/Output HDMI Input Optical Output ARC Output IR Input/Output RS232 12V DC ARC Audio Selector 1 HDMI Receptacle 2 LC Ports 1 Optical Audio Port 2 3.5mm TRS Ports 1 3-pin Removable Terminal Block 1 5.5mm OD/2.5mm ID Threaded Barrel Connector 1 2-position Switch Receiver Input/Output HDMI Output Optical Input ARC Input IR Input/Output RS232 12V DC ARC Audio Selector 1 HDMI Receptacle 2 LC Ports 1 Optical Audio Port 2 3.5mm TRS Ports 1 3-pin Removable Terminal Block 1 5.5mm OD/2.5mm ID Threaded Barrel Connector 1 2-position Switch Supported Audio, Video, and Control Compatible Video Signals All SD, HD, and other resolutions up to - 4K/60 Hz / RGB and 4:4:4 8 bit (HDR) - 4K/60 Hz / 4:2:2 10 bit (HDR) - 4K/60 Hz / 4:2:0 10 bit (HDR) HDMI 2.0, HDMI 1.4, DVI 2.0 (Pixel clock up to 594 MHz) HDCP 1.2 / HDCP 2.2 Compatible LPCM, Dolby Digital/Plus/EX, Dolby True HD, DTS, DTS-EX, DTS-96/24, DTS High Res, DTS-HD Master Audio, DSD Up to 6-channel audio 2400, 4800, 9600, 19200, 38400, 57600, 115200 33 to 55 kHz Video Compliance Digital Content Protection Embedded Audio ARC (Audio Return Channel) Supported RS232 Baud Rates Supported IR Carrier Fiber Optic Transmission Characteristics Required Cable Type Maximum Bandwidth Maximum Distance Signal Compression Duplex OM3 or OS2 35 Gbps 300m (984 ft) None Chassis and Environmental Product Construction Product Dimensions (W*H*D) Product Operational Chassis Temperature Environmental Operating Temperature Environmental Operating Humidity Environmental Storage Temperature Environmental Storage Humidity Painted aluminum 125 mm (4.92 in) x 19 mm (0.75 in) x 86 mm (3.17 in) 35 to + 44°C (95 to + 111 °F) 0 to + 45°C (32 to + 113 °F) 10% to 90%, non-condensing -20 to +70°C (-4 to + 158 °F) 10% to 90%, non-condensing Power and Regulatory Power Input Power Supply Input Power Supply Output Maximum Power Consumption ESD Protection Regulatory Compliance 12V DC 100-240V AC at 50/60 Hz; 0.5A Max 12V DC at 1 A 6 watts Human-body Model: ±8kV Air-gap discharge and ±4kV Contact discharge FCC, CE, RoHS, WEEE Other Warranty Diagnostic LEDs Included Accessories Three years Link, Status, and Power IR Receiver (2 ea), IR Transmitter (2 ea), Mounting Ears (4 ea), Rubber Feet (8 ea), 12V 1A DC Power Supply (2 ea), 3-pin 3.5mm Terminal Block (2 ea), DE-9 to 3-pin RS232 Cable (2 ea) www.tlnetworx.com | +1-608-960-7242 TL-FO2-HDC2 Technical Specifications v180501 Transmitter Dimensional Drawings www.tlnetworx.com | +1-608-960-7242 TL-FO2-HDC2 Technical Specifications v180501 Receiver Dimensional Drawings www.tlnetworx.com | +1-608-960-7242
TL-FO2-HDC2 价格&库存
很抱歉,暂时无法提供与“TL-FO2-HDC2”相匹配的价格&库存,您可以联系我们找货
