TL-RKPS-01
TL-RKPS-01
    TECHLOGIX
    AC/DC CONVERTER 5V 12V 24V 45W
TL-RKPS-01 数据手册
Technical Specifications v170810 Technical Specifications TL-RKPS-01 Features at a Glance • Supports 12 DC-powered devices • 5, 12 or 24VDC selectable power per channel • Dual AC inputs • Input channel rating for 100~240VAC • Maximum output consumption of 15W per channel • 100ms sequencing per channel on startup • Remote channel on/off control via RS232, Ethernet or built-in webserver The TechLogix TL-RKPS-01 is a rack-mountable integrated switching power supply designed for converting AC into DC power. It provides two input channels (100-240VAC at 50/60 Hz) and 12 output channels (5, 12, or 24V DC) that provide up to 15W per channel. • Front panel control & keylock With sequential control technology, when powered on, the 12 output • Firmware upgradeable channels will turn on in order every 100ms. Each output channel can be switched on/off via the corresponding front panel button, RS232 commands or web-based GUI. The output voltage on each output channel can be selected as 5/12/24V DC via the tactile switch on the rear panel, RS232 command, or web-based GUI. • 1RU size Specifications I/O Connections Input channels Input voltage Output channels Output voltage (selectable) Output power rating Total output power consumption Voltage selection Control Sequencing startup time Control formats Default IP address Supported baud rates (2) AC 100~240VAC 50~60HZ (12) DC 2-pin phoenix 5V (4.75~5.25V) 12V (11.4~12.6V) 24V (22.8~25.2V) 15W per channel (5V 3A, 12V 1.25A, 24V 0.625A) 180W Rear Panel: Total 12 TACT Switches, named SELECT; RS232; TCP/IP, Web GUI 100ms RS232 (3-pin phoenix) Front panel (12 buttons – one per channel) TCP/IP (RJ45) Web-based GUI 192.168.0.178 Port: 4001 1200, 2400, 4800, 9600 (default), 19200, 38400, 57600, 115200 www.tlnetworx.com | +1-608-960-7242 Technical Specifications v170810 General Included Items Enclosure Regulatory Standard warranty Operating temperature range Operating humidity range Dimensions WxHxD Weight (1) power cable (12) 2-pin phoenix connectors (1) 3-pin phoenix connector (1) RS232 cable (DB9 to 3-pin phoenix connector) (2) DC cables Painted aluminum UL, FCC, CE 3 years 0~50 degrees C 32~122 degrees F 10~90% non-condensing 437mm x 44mm x 357mm 17.2” x 1.7” x 14.1” 4.2Kg 9.2lbs www.tlnetworx.com | +1-608-960-7242
TL-RKPS-01 价格&库存
很抱歉,暂时无法提供与“TL-RKPS-01”相匹配的价格&库存,您可以联系我们找货
