TL-SMKIT-04
TL-SMKIT-04
    TECHLOGIX
    3 USER CONFERENCE ROOM KIT
TL-SMKIT-04 数据手册
TL-SM3X1-HDV Technical Specifications v181025 Technical Specifications TL-SM3X1-HDV Features at a Glance • Two HDMI inputs, one VGA input & one HDMI output • HDMI video resolution up to 4K@30 4:4:4 • VGA video resolution up to 1920x1200@60Hz • HDMI 1.4 & HDCP 1.4 compliant • MHL support on HDMI input channel 1 • IR remote control & front panel control • Integration with TechLogix table inserts for signal pass-through & remote control • Micro USB firmware port • EDID pass-through • CEC pass-through with display control • Hot-plug support The TL-SM3X1-HDV is a 3x1 video switcher with two HDMI inputs, one VGA input and one HDMI output. The unit supports HDMI video resolutions up to 4K@30, as well as multichannel audio. The unit supports VGA video resolutions up to 1920x1200@60Hz. The TL-SM3X1-HDV supports two operating modes: auto-switch mode and manual switch mode. When in auto-switch mode, the unit will automatically switch to a signal input as soon as a new source is connected. When the active source is removed, the unit will select the first source on the lowest numbered input. In manual switch mode, the TL-SM3X1-HDV will switch between connected inputs when a control command is sent to the unit via IR or through a command sent by compatible table inserts, or by using buttons on the front panel of the unit. In addition to controlling the switching of the source inputs, the TL-SM3X1-HDV also controls a display connected via an HDMI cable via CEC commands. This allows for automatic power on/off commands to be transmitted from the unit (as well as connected table inserts) to the display, thereby providing a complete room connectivity and control solution. www.tlnetworx.com | +1-608-960-7242 TL-SM3X1-HDV Technical Specifications v181025 Specifications Input/output Video Input Video Input Connector Input Video Signal Video Output Video Output Connector Output Video Signal Output Resolution 1 HDMI/MHL 1 HDMI 1 VGA 2 female HDMI 1 female VGA (15-pin) HDMI, YPbPr, C-video, VGA 1 HDMI 1 female HDMI HDMI HDMI output video support HDMI 1.4 & HDCP 1.4; maximum resolution of 4K@30 4:4:4 VGA output video support HDMI 1.4 & HDCP 1.4; maximum resolution of 1920x1200. Other supported resolutions include: 1920x1080, 1600x1200, 1600x900, 1360x768, 1280x800, 1280x720, or 1024x768. Audio Audio Input Audio Input Connector Audio Input Impedance Frequency Response Stereo Channel Separation 1 stereo audio input for VGA video 1 3.5mm stereo jack >10kΩ 20Hz~20K Hz >80dB @1KHz Control Part Control Port Control Connector Control Buttons 3 Dry Contact (C1~C3) 1 FIRMWARE 3 3.5mm mini jack 1 Micro-USB Front Panel: HDMI 1, HDMI 2, VGA, AUTO Rear Panel: RES RESET General Temperature Humidity Power Supply Max Power Consumption Dimension (W*H*D) Weight Compatible TechLogix Table Inserts Warranty 0 ~ +50°C 10% ~ 90% DC12V 1A 2W 201.5mm x 22.0mm x 84.0mm 246g TL-SMG-HD (HDMI) TL-SMG-VGA (VGA) TL-SMG-DP (DisplayPort) 3 years www.tlnetworx.com | +1-608-960-7242 TL-SM3X1-HDV Technical Specifications v181025 HDMI IN 2 VGA IN AUDIO IN HDMI OUT C1 C2 C3 RES RESET DC12V 22.0 mm 84.0 mm HDMI/MHL IN 1 3x1 Video Switcher TL-SM3X1-HDV 201.5 mm IR HDMI 1 HDMI 2 VGA AUTO www.tlnetworx.com | +1-608-960-7242 FIRMWARE
TL-SMKIT-04 价格&库存
很抱歉,暂时无法提供与“TL-SMKIT-04”相匹配的价格&库存,您可以联系我们找货
