TL-TI-4USB
TL-TI-4USB
    TECHLOGIX
    USB TABLE INSERT
TL-TI-4USB 数据手册
181005 TL-TI-4USB Technical Specifications Technical Specifications TL-TI-4USB 4-Port USB 2.0 Hub Insert 56 mm (2.20 in) 44.5 mm (1.75 in) 31.9 mm (1.26 in) 44.5 mm (1.75 in) 75 mm (2.95 in) 36 mm (1.42 in) 75 mm (2.95 in) General Specifications Surface Connection Four (4) USB A receptacles Under Table Connection One (1) full size USB B receptacle Bridging Connectivity Powered from host device connected to under table connection Maximum Cable Length (surface device to under table device) 5m (16.4 ft) Surface Dimensions 75mm (2.95 in) diameter; 2.8mm (0.11 in) tall Hole Insert Dimensions 56mm (2.20 in) diameter; 34.5mm (1.36 in) deep Warranty 3 years
TL-TI-4USB 价格&库存
很抱歉,暂时无法提供与“TL-TI-4USB”相匹配的价格&库存,您可以联系我们找货
