TL-TP40-HDC2
TL-TP40-HDC2
    TECHLOGIX
    HDMI TWISTED PAIR EXTENDER SET
TL-TP40-HDC2 数据手册
TL-TP40-HDC2 Technical Specifications v180619 Technical Specifications TL-TP40-HDC2 Features at a Glance • EDID pass through • HDCP2.2 compliant • 4K/60 at 4:4:4 over Cat 6 up to 40m • 1080p over Cat 5e/6 up to 70m • Bi-directional IR, RS232 The TL-TP40-HDC2 is an ultra-thin extender set consisting of a transmitter (TL-TP40-HDC2-T) and a receiver (TL-TP40-HDC2-R). The set transmits an HDMI signal to the receiver up to 70m distance via a Cat5e/Cat6A cable. The embedded VLC compression chipset allows 4K/60 at 4:4:4 video to reach distances up to 40m over a single Category 6 cable with no visual artifacts. Featuring bi-directional IR and RS232, you can control your display or source using included accessories. With bi-directional PoE power, you only need to connect the power supply on one end. Specifications I/O Connections HDMI Twisted Pair IR Input IR Output RS232 24V DC Power HDMI Type A Receptacle 8P8C port (Shielded RJ45) 3.5mm TRS Jack 3.5mm TS Jack 3pin phoenix socket 5.5 mm Outside Diameter, 2.1 mm Inside Diameter Barrel (Locking) Supported Video and Audio Maximum Video Compatibility Video Compliance Embedded Audio Input DDC Signal Input Video Signal IR Carrier Frequency Range 70 m: Deep Color 36/30/24 Bit at 1080p 40 m: Deep Color 48 Bit at 1080p, 3D, and 4k x 2k (UHD) up to 30 Hz: RGB, YCbCr 4:4:4, YCbCr 4:2:2; up to 60 Hz: YCbCr 4:2:0 HDMI, HDCP 2.2, and CEC (Consumer Electronics Control) Up to PCM 8 channel, Dolby Digital TrueHD, and DTS-HD Master Audio 5.0 volts p-p (TTL) 0.5 to 1.0 volts p-p 33-55kHz at 5 volts www.tlnetworx.com | +1-608-960-7242 TL-TP40-HDC2 Technical Specifications v180619 Extender Signal Characteristics Maximum Distance Bandwidth 70 m: Deep Color 36/30/24 Bit at 1080p 40 m: Deep Color 48 Bit at 1080p, 3D, and 4k x 2k (UHD) up to 60 Hz: RGB, YCbCr 4:4:4, YCbCr 4:2:2, YCbCr 4:2:0 Solid core shielded Category 5e, Category 6 or greater with TIA/EIA-568B crimp pattern 10.2 Gbps Signal Compression 1.8:1 Maximum; Compression starts when video signal >9 Gbps Cable Requirements Chassis and Environmental Enclosure Dimensions Shipping Weight Operating Temperature (Environment) Operating Temperature (Chassis) Operating Humidity (Environment) Storage Temperature (Environment) Storage Humidity (Environment) Painted aluminum 115mm x 84mm x 16mm 0.71Kg (1.55 lbs) (Tx+Rx) -10° to +40° C 45° C 10% ~ 90% -15° to +70° C 0%~55% Power, ESD, Regulatory Maximum Power Consumption Power Supply ESD Protection Regulatory 4.4W(TX), 6.7W(RX) 24V DC 15KV CE, FCC Other Standard Warranty Diagnostic Indicators RS232/Firmware Switch Included Items 3 Year Power LEDs 3-position Slider Installation Guide, power supply, US power cord, mounting “L” brackets (4 ea), mounting screws (4 ea), IR Transmitter, IR Receiver www.tlnetworx.com | +1-608-960-7242 TL-TP40-HDC2 Technical Specifications v180619 Dimensional Drawings www.tlnetworx.com | +1-608-960-7242
TL-TP40-HDC2 价格&库存
很抱歉,暂时无法提供与“TL-TP40-HDC2”相匹配的价格&库存,您可以联系我们找货
