TL-TP50-HDIR
TL-TP50-HDIR
    TECHLOGIX
    HDMI TWISTED PAIR EXTENDER SET
TL-TP50-HDIR 数据手册
TL-TP50-HDIR Technical Specifications v161102 Technical Specifications TL-TP50-HDIR Features at a Glance  1080p, 3D compatible  Deep color, DTS-HD, Dolby TrueHD compatible  50m max distance for 1080p  Single twisted pair transmission (shielded required)  HDMI loop output on the transmitter  HDMI 1.4 / HDCP 1.4  IR transmission from the display to the source  Diagnostic LEDs  Built-in mounting ears  Two power supplies required  Built-in EDID copying The TL-TP50-HDIR is a cost-effective twisted pair extender set designed for extending HDMI and IR up to 50 meters (164 ft.) over shielded twisted pair cabling (shielded connectors are also required). The system transmits IR from the destination (receiver end) to the source (transmitter end), and requires power on both ends. The transmitter features a built-in loop out, allowing a local display to be connected to the system. Specifications I/O Connections (Transmitter) HDMI In HDMI Out TP Out IR out Power EDID 1 HDMI type A connector 1 HDMI type A connector 1 RJ45 connector 1 3.5mm mono jack 1 DC 5V connector 1 Two position sliding switch I/O Connections (Receiver) HDMI Out TP In IR In 1 HDMI type A connector 1 RJ45 connector 1 3.5mm stereo jack www.tlnetworx.com | +1-608-960-7242 TL-TP50-HDIR Technical Specifications v161102 Power EQ 1 DC 5V connector 3 Two position sliding switch Supported Audio and Video Maximum Video Compatibility Video Compliance 3D Support IR Carrier Frequency Range Input Video Signal Impedance Signal to Noise Ratio THD Input DDC Signal 1080p60 HDMI 1.4, HDCP 1.4 Yes Wideband 33-60kHz at 5 volts 0.5-1.0 Vpp 75 ohms >70dB @ 100MHz
TL-TP50-HDIR 价格&库存
很抱歉,暂时无法提供与“TL-TP50-HDIR”相匹配的价格&库存,您可以联系我们找货
