TL-TP70-HDARC
TL-TP70-HDARC
    TECHLOGIX
    HDMI TWISTED PAIR EXTENDER SET
TL-TP70-HDARC 数据手册
TL-TP70-HDARC Technical Specifications v190927 Technical Specifications TL-TP70-HDARC Features at a Glance • HDMI 1.4 supported • 4K 40m, 1080p 70m transmission • HDCP 2.2 compliant • Bidirectional PoE (power from either the TX or the RX) • ARC supported The TL-TP70-HDARC is an ultra thin design extender set consisting of a transmitter and a receiver. The set transmits a 1080p signal to the receiver up to 70m via a shielded Cat5e/Cat6 cable. Bi-directional IR communication is included to allow control of an IR source or display. Bidirectional PoE power allows you to connect the power supply at either the transmitter or the receiver to power both units. The set also supports ARC, which enables audio up streaming from display to an audio system using either HDMI or the coax digital output. Specifications I/O Connections HDMI TP IR in IR out ARC audio Power 1 HDMI type A connector 1 RJ45 connector 1 3.5mm stereo jack 1 3.5mm mono jack 1 coaxial RCA connector in transmitter 1 DC 24V connector with locking screw Supported Audio and Video Maximum Video Compatibility Video Compliance ARC audio IR Carrier Frequency Range Input Video Signal 70 m: Deep Color 36/30/24 Bit at 1080p 40 m: Deep Color 48 Bit at 1080p, 3D, 4k x 2k (UHD) 30 Hz: RGB, YCbCr 4:4:4, YCbCr 4:2:2, 60 Hz: YCbCr 4:2:0 HDMI 1.4, HDCP 2.2 PCM on HDMI (input) or Coax digital output 33-55kHz at 5 volts 0.5-1.0 Vpp Twisted Pair Signal Characteristics Maximum Distance Cable Requirements Bandwidth 70m Solid core shielded Category 5e, Category 6 or greater with TIA/EIA568B crimp pattern 10.2 Gbps www.tlnetworx.com | +1-608-960-7242 TL-TP70-HDARC Technical Specifications v190927 Gain 0 dB – 10 dB at 100 MHz www.tlnetworx.com | +1-608-960-7242 TL-TP70-HDARC Technical Specifications v190927 Chassis and Environmental Enclosure Dimensions Shipping Weight Operating Temperature (Environment) Operating Humidity (Environment) Painted aluminum 115*16.2*114 mm 280g (Tx+Rx) 0~50℃ 10%-90% Power, ESD, and Regulatory Maximum Power Consumption Power Supply ESD Protection Regulatory 0.5W DC 24V 15kV CE, FCC Other Standard Warranty Diagnostic Indicators Included Items 3 Years Power, link, HDCP Mounting ears, Screws, Plastic cushions, Power Adapter, IR receiver, IR emitter Dimensional Drawings www.tlnetworx.com | +1-608-960-7242 TL-TP70-HDARC Technical Specifications v190927 Receiver Transmitter www.tlnetworx.com | +1-608-960-7242 TL-TP70-HDARC Technical Specifications v190927 www.tlnetworx.com | +1-608-960-7242
TL-TP70-HDARC 价格&库存
很抱歉,暂时无法提供与“TL-TP70-HDARC”相匹配的价格&库存,您可以联系我们找货
