EDM1CFIMX6U10R1GBNI4GBWL2C
    TECHNEXION
    MOD EDM TYPE1 I.MX6 DUAL BTOOTH
EDM1CFIMX6U10R1GBNI4GBWL2C 数据手册
EDM1-CF-IMX6 Main Features ARM Cortex-A9 NXP i.MX6 scalable single/dual/ quad core EDM type 1 compact System-on-Module Gigabit LAN, WiFi 802.11 b/g/n and Bluetooth v. 4.0 communication interface Targeting multimedia applications with LVDS, TTL, HDMI, S/PDIF, I2S, MIPI camera and display 1 TTL Power I2S 2nd GPMC SPDIF CANBus x2 LAN LVDS HDMI PCIe x1 SATA 1st USB OTG USB Host SD I2S 1st SPI x2 UART x2 RSVD Buttons + GPIO I2C x2 RTC Specifications Core System Signalling CPU System Memory Storage Debug Interface FPC Connector Video EDM Type 1 compliant NXP i.MX6Solo @ 1GHz NXP i.MX6Duallite @ 1GHz NXP i.MX6Dual @ 1GHz NXP i.MX6Quad @ 1GHz up to 2GB DDR3 eMMC (default 4GB) optional NAND Flash (MOQ apply) JTAG Interface by Through-hole MIPI Interface Camera MIPI Interface Display Connectivity Network WiFi Bluetooth Atheros AR8031 Gigabit LAN Broadcom BCM4330 802.11bgn Broadcom BCM4330 BT 4.0 I/O Interfaces Storage Expansion Display USB CAN Bus Serial Port Other 1x SATA 2.0 (Dual/Quad only) 1x SDIO/MMC 1x PCIe 2.0 HDMI v1.4 1 channel LVDS 18/24 bit 24 bit RGB TTL USB Host 2.0 USB OTG 2.0 2x Flex CAN version 2.0B compliant 2x UART SPI, I2C, I2S, GPIO, Local Bus (GPMC) Solo/Duallite Vivante GC880 35Mtri/s 266Mpxl/s Open GL ES 2.0 Dual/Quad Vivante GC2000 200Mtri/s 1000Mpxl/s OpenGL ES 2.0 & Halti, CL EP GPU 2D (Vector Graphics) emulated on GPU 3D Vivante GC355 300Mpxl/s OpenVG 1.1 GPU 2D (Composition) Vivante GC320 600Mpxl/s, BLIT Vivante GC320 600Mpxl/s, BLIT Video Decode Video Encode 1080p30 + D1 1080p30 H.264 BP/Dual 720p 1080p60 H.264 1080p30 H.264 BP/Dual 720p GPU 3D Audio Interface Audio Codec I2S (2 channel), S/PDIF on EDM Carrier Board Power Specifications Input power 5V DC +/- 5% Operation Systems Standard Support Extended Support Linux Yocto Android Commercial Linux Windows Embedded Compact Real Time OS EDM1-CF-IMX6 Block Diagram Up to 2GB DDR3 NAND Flash MIPI Camera & Display eMMC OR u.FL NXP i.MX6 Cortex A9 Power SDIO WiFi Bluetooth UART LAN PHY 1 314 Pin EDM Connector Environmental and Mechanical Ordering Information Temperature EDM1-CF-IMX6x-10-Rxxx-NIxG-xx-x-x-xx-xxx-xxxx Humidity Module Connector Form Factor Dimensions MTBF Weight Shock Vibration Commercial : 0° to 60° C Extended : -20° to 70° C Industrial : -40° to 85° C (no WiFi ) 10 to 90% 314 pins MXM3 EDM Compact Form Factor 82 x 60 mm (3⅝x 2⅜ inch) >100,000 hours 20 grams 50G/25ms 20G/0-600 Hz Dimensions M3 45 82 11.5 60 (units in mm) Description i.MX6 Solo i.MX6 Duallite i.MX6 Dual i.MX6 Quad Processor speed 1 GHz (Default) 512 MB DDR3 Memory 1GB DDR3 2GB DDR3 Storage eMMC capacity in Gigabyte NI4G = 4GB : NI8G = 8GB : NI16G = 16GB NI32G = 32GB : NI64G = 64GB Wireless Networking No BW 802.11bgn + Bluetooth 4.0 No Network L Gigabit LAN(Default) No SATA S SATA(Dual/Quad) No CAN Bus 2C 2 CAN(Default) Temperature Range Commercial Temperature range (0~60° C)(Default) Extended Temperature range TE (-20~70° C) Industrial Temperature range TI (-40~85° C) TEC Certified Extended Temperature range (-20~70° C) Certified Industrial Temperature range TIC (-40~85° C) Custom ID XXXX Custom Part number ID for customized software loader and special component (BOM) Processor Code IMX6S IMX6U IMX6D IMX6Q 10 R512 R1GB R2GB NI4G 75 * Feel free to contact us for custom tailored Carrier Board request for your projects. 2016-09. All specifications are subject to change without notice.
EDM1CFIMX6U10R1GBNI4GBWL2C 价格&库存
很抱歉,暂时无法提供与“EDM1CFIMX6U10R1GBNI4GBWL2C”相匹配的价格&库存,您可以联系我们找货
