EDM2WIZARDSTART
EDM2WIZARDSTART
    TECHNEXION
    BOARD EVAL EDM TYPE2 CBL/ADAPTER
EDM2WIZARDSTART 数据手册
EDM2-WIZARD Main Features The official EDM type 2 Evaluation Carrier Board brings you a rich variety of interfaces and options at your fingertips. Wide range of jumper selectable audio, video and touch interfaces. Optional smart battery pack implementation. 2 LVDS Power 5 VDC HDMI PCIe x1 x4 SATA st 21nd LPC OTG HDA PCIe x2 SATA 1st USB OTG USB Host SPDIF LAN LVDS HDMI I2S 1st CANBus x2 SD SPI x2 UART x2 RSVD Buttons + GPIO I2C x2 RTC Specifications Core System Video System on Module EDM Type 2 compliant Connector Expansion Expansion Slots 2x mini-PCIe + SIM cardslot (for 3G communication) 1x PCIe x1 expansion slot (shared with mini-PCIe) 1x PCIe x4 expansion slot Audio Codec Connector I/O Interfaces Connector Header 2x SATA 1x SD cardslot (SDIO) 1x Gigabit LAN 2x USB 3.0 Host 1x micro USB 3.0 / 2.0 OTG 1x UART (RS-232/422/485) 2x CAN Bus 1x UART (RS-232/422/485) 2x SPI 8x GPIO (shared with buttons) 2x I2C Manufacturing pins Speaker Jumper selectable: Freescale SGTL5000 (I2S), TI TLV320AIC23B (I2S) Realtek ALC892-CG (HDA) 5x 3.5 mm jack Surround audio S/PDIF 2W amplified speaker connectors Touch Controller Connector Jumper selectable: TSC2046 (4 wire by SPI) TSC2004 (4 wire by I2C) ADS7845 (5 wire by SPI) USB 4/5 wire touch controller 4 wire touchpanel (USB/I2C/SPI) 5 wire touchpanel (USB/SPI) Power Specifications Input Power Battery EDM Standard SOM’s and Carrier Boards 2x HDMI 2 channel LVDS 18/24 bit 10~30 VDC Smart battery connector EDM2-WIZARD Block Diagram HDMI HDMI USB HDMI OTG 3.0/2.0 HDMI Connector LVDS LVDS RJ45 USB HUB 2.0 USB HUB 3.0 USB LVDS Connector LVDS LAN PCle mPCle + SIM PCle mPCle + SIM PCI PCI x4 SD PCIe I2 C SDIO SPDIF Connector Header 314 pin EDM Connector EEPROM RTC Audio HDA Mic Touch Audio Line out I2S SPI EEPROM 2W amplifier Line in Speaker Header SATA Smart battery module SATA 12V 5V Button 12 VDC Input SATA UART UART GPIO Commercial : 0° to 60° C 10 to 90% 314 pins MXM3 MicroATX Form Factor 244 x 244 mm 9⅝ x 9⅝ inch >100,000 hours 380 grams 50G / 25ms 20G / 0-600 Hz Header Header CAN Header Dimensions (units in mm) 244 244 MTBF Weight Shock Vibration 2 CAN Header Environmental and Mechanical Temperature Humidity Module Connector Form Factor Dimensions Connector RS-232 RS-422 RS-485 SATA EDM2-WIZARD MicroATX Form Factor Wizard Carrier Board for EDM Type 2 System on Modules EDM2-WIZARD-START MicroATX Form Factor Wizard Carrier Board for EDM Type 2 System on Modules including cablekit and adaptor WIZARD REV Ordering Information * Feel free to contact us for custom tailored Carrier Board request for your projects. 2015-05. All specifications are subject to change without notice. EDM Standard SOM’s and Carrier Boards
EDM2WIZARDSTART 价格&库存
很抱歉,暂时无法提供与“EDM2WIZARDSTART”相匹配的价格&库存,您可以联系我们找货
