LS1021A-IOT
LS1021A-IOT
    TECHNEXION
    LS1021A EVAL BRD
LS1021A-IOT 数据手册
Page 1 of 2 LS1021A-IoT Gateway Reference Design Key Features The LS1021A-IoT gateway reference design based on the Freescale Layerscape LS1021A processor is a purpose-built, small footprint hardware platform equipped with a wide array of high-speed connectivity and low-speed serial interfaces engineered to support the secure delivery of IoT services to end users in a home, business or other commercial location. The affordable reference design combines standards-based, open source software together with a feature-rich IoT gateway design, to establish a common, open framework for secure IoT service delivery and management. This reference design provides a wide assortment of high speed and serial based connectivity in a compact, highly secure design, delivering an impressive level of versatility. High efficiency is achieved through the use of the ARM-based Layerscape LS1021A embedded processor, which delivers over 5,000 Coremarks of performance at a typical power of under 3 Watts. In addition to its outstanding performance efficiency and high level of integration, the LS1021A-IoT gateway design offers HDMI, SATA3 and USB3 connectors as well as a complete Linux software developers package. LS1021A-IOT Gateway Block Diagram Specifications Processor Technology Power Management IC Memory Storage Removable Storage Operation System Freescale LS1021A ARM Cortex-A7 Dual core Freescale VR500 PMIC 1GB ECC protected DDR3 1 Gb QSPI NOR Flash SHDC upto 32GB (4GB SD card included) Linux 3.x, Yocto Connectors Debug Interface JTAG Interface by thruhole Page 2 of 2 I/O Interface Signalling Storage Expansion Display USB CAN Bus Serial Port Other 1x SATA III 1x SDIO / MMC 2x PCIe 2.0 24 bit LVDS USB OTG 3.0 USB Host 2.0 2x Flex CAN version 2.0B Compliant 2x UART SPI, I²C, GPIO Network Gigabit Network RGMII Gigabit Network SGMII Gigabit Network Switch Atheros AR8033 Gigabit LAN PHY Atheros AR8033 Gigabit LAN PHY 4 port gigabit switch Video Display chipset Dispaly interface Silicon Image SII9022 HDMI connector Audio Audio Codec Audio connectors Freescale SGTL5000 Audio In / Out Power Input Power Requirements 12VDC +/- 5% Environmental and Mechanical Temperature Humidity Dimensions Weight Certification 0° to 40° C 10 - 90% 200 x 170 x 58 mm 7⅞ x 6⅝ x 2¼ inch 1200 grams Compliant with CE, FCC, RoHS, REACh directives Ordering Information LS1021A-IOT LS1021A-IOT Gateway Reference design. Including power adaptor, HDMI and USB debug cable and 8GB SDHC card http://www.technexion.com/products/evm/ls1021a-iot 5/13/2015
LS1021A-IOT 价格&库存
很抱歉,暂时无法提供与“LS1021A-IOT”相匹配的价格&库存,您可以联系我们找货
