PICOHOBBITGL
PICOHOBBITGL
    TECHNEXION
    PICO HOBBIT CARRIER BRD GIGA ETH
PICOHOBBITGL 数据手册
PICO-HOBBIT Main Features The PICO-HOBBIT reference design is compatible with Intel Edison and TechNexion Pico CoM modules and add a variety connectivity to the Pico CoM making it the ideal candidate for IoT (Internet of Things) applications such as drones, wearables, appliances and robotics. The complete schematics, design files, board files and BOM lists of PICO-HOBBIT are available and can be downloaded from the TechNexion homepage. EDISON EXP-A SDIO I2S SPI PWM USB OTG UART I2C GPIO LVDS EXP-B RGMII CAN PCIe I2 C USB HOST HDMI SATA Power 3.3~4.5V TTL MIPI Specifications Core System System-on-Module Video Compatible with Intel Edison Connector (1x 70-pin Hirose Connector) Compatible with TechNexion Pico Connectors (3x 70-pin Hirose Connector) Micrel KSZ8084RNB Fast Ethernet LAN Atheros AR8035 Gigabit LAN RJ-45 LAN Connector Connector Expansion Storage USB Expansion Pin Headers Camera 1x micro SD cardslot 1x USB 2.0 Host Connector 1x USB 2.0 OTG Connector CAN GPIO PWM I2 C SPI UART Single Channel LVDS 24bit TTL RGB PICO System-on-Modules and DWARF Platform Single Channel LVDS (expansion header) MIPI DSI Display on 33-pin FPC Connector MIPI CSI signals on 33-pin FPC Connector Audio Audio Codec Audio Connectors Connectivity Network Internal Display NXP SGTL5000 1x 3.5 mm jack Stereo Audio in / out Power Specifications Input Power Power Connector 5 VDC +/- 5% 5.5 / 2.1mm barrel jack PICO-HOBBIT Block Diagram Debug Console 10/100 Fast Ethernet LAN RJ-45 Connector OR USB OTG USB NXP Audio Codec SGTL5000 Pico-COM Line in / out Gigabit LAN Power Expansion header Environmental and Mechanical Temperature Humidity Dimensions MTBF Weight Shock Vibration Commercial : 0° to 60° C 10 to 90% 100 x 45 mm 315⁄16in x 149⁄64in >100,000 hours 30 grams 50G / 25ms 20G / 0-600 Hz MIPI Camera display Ordering Information PICOHOBBITFL PICO-HOBBIT Baseboard for PICO-COM 10/100 Megabit LAN PICOHOBBITGL PICO-HOBBIT Baseboard for PICO-COM Gigabit LAN * Feel free to contact us for custom tailored Carrier Board request for your projects. Dimensions (units in mm) 45 100 2015-05. All specifications are subject to change without notice. PICO System-on-Modules and DWARF Platform
PICOHOBBITGL 价格&库存
很抱歉,暂时无法提供与“PICOHOBBITGL”相匹配的价格&库存,您可以联系我们找货
