PICOPIFL
PICOPIFL
    TECHNEXION
    PICO PI CARRIER BRD FAST ETH
PICOPIFL 数据手册
      PICO‐PI‐FL  QUICK OVERVIEW PICO PI CARRIER BOARD WITH FAST ETHERNET LAN   GENERAL INFO HTSN 8473.30.1180 ECCN EAR99 REACH RoHS YES Single Unit Packing Quantity 1 Pcs. SPECIFICATION Core System Edison compatibile connector Board-to-Board Connector PICO 70-pin Hirose connectors System on Module PICO SOM Debug Interface UART Interface by Through-hole Connectivity Network LAN 1x Atheros AR8035 Gigabit LAN (optional) 1x Micrel KSZ8084RNB Fast Ethernet LAN (optional) Internal Headers Internal Display 1x 24-bit TTL RGB signals (expansion header) MIPI DSI signals on 33-pin FPC connector GPIO I²C I²S Expansion Headers PWM RS232 SPI USB MikroBUS ADC, GPIO, I²C, PWM, SPI, UART External Connectors Audio Connectors CTIA compliant 3.5mm audio jack Network 1x RJ45 1x USB 2.0 Host USB 1x USB 2.0 OTG (C-Type) Buttons 1x Reset Audio Audio Codec NXP SGTL5000 Power Specifications Power Input 5V DC +/-5% Power Consumption Depending on Configuration Environmental and Mechanical Dimensions 85.6 x 56.5 mm Weight 35 grams Temperature Commercial: 0° to +60° C Relative Humidity 10 to 90 % MTBF >100 000 Hours Shock 50G/25ms Vibration 20G/0-600Hz Certification Compliant with CE / FCC / RoHS / REACH directives        http://shop.technexion.com/picopifl.html 5‐26‐17
PICOPIFL 价格&库存
很抱歉,暂时无法提供与“PICOPIFL”相匹配的价格&库存,您可以联系我们找货
