2020-1
2020-1
    TECHSPRAY
    刷子,单头 马鬃 尖头 1 PC
2020-1 数据手册
Maintenance Avionic Repair www.techspray.com MAINTENANCE MAINTENANCE Techspray aviation maintenance cleaners improve performance, efficiency and safety for degreasing, contact cleaning, and aircraft surface cleaning. Degreasers and contact cleaners remove a wide variety of soil, oil, grease, oxides, and baked-on lubricants. Formulas available to maximize cleaning power and comply with stringent environmental regulations. Clean and maintain corrosionprone areas like exhaust trail areas, battery compartments and vents, bilge areas, landing gear, cooling vents, wing flap and more. Specialized Degreasers for Aviation and Aircraft Parts I want to switch to something safer, but need help…I’ve heard These specially engineered aviation degreasers quickly remove hydraulic fluid, fuel oils, lubricating oils and greases, and other organic residues. They are fast evaporating, quick penetrating, and ideal for cleaning aviation parts. Both are free of hazardous air pollutants (HAPs), and CARB compliant. that nPB, TCE and some of these other cleaners are not good for us, but everything else is such a price jump! Why can’t I find a strong, safe cleaner at a price we can afford? DUCING PWR-4 ™ RFUL NEW LAMMABLE ING SOLVENTS nt cleaners are ideal where a safer, and cost effective aerosol cleaner is novative cleaner is much safer than mmon industrial solvents: TCE, nPB, ene Chloride and quickly blasts off xes, silicones, dirt and grime. The performance you need at the price you want! ble han most common industrial TCE, nPB, Perc & Methylene Chloride aner — Ideal for degreasing and ning aerosol or bulk for vapor-degreasing, nd bucket cleaning ration POWER UP…POWER FORWARD e on request. Contact us and start GET THE JOB DONE Aviation Degreaser SPECS: www.pwr-4.com SAMPLES: 800-858-4043 Exceptional nonflammable cleaner for aircraft parts degreasing SCAN FOR MOBILE SITE 2851-20S 20 oz (567g) aerosol Aviation Degreasers Specifications: Meets Airbus UK ABR9-0140 General Purpose Cleaning Solvent, FedEx CPN 0311737, Boeing D6 17487, Rev T 2 Aviation Degreaser II NESHAP compliant cleaner for removing hydraulic and lubricating fluids 1647-16S 16 oz. (454g) aerosol Specifications: Boeing D6 17487, Rev T, NESHAP 63.741-753 • Nonflammable • Fast evaporation • Zero residue • Non-ozone depleting • Does not contain n-propyl bromide • Dielectric breakdown of 13.7 kV • CARB compliant • Nonflammable • Low VOC / NESHAP compliant • Fast evaporation • Zero residue • Non-ozone depleting • Does not contain n-propyl bromide • Dielectric breakdown of 11.9 kV • CARB compliant rs are ideal where a safer, effective aerosol cleaner is leaner is much safer than ustrial solvents: TCE, nPB, de and quickly blasts off nes, dirt and grime. that nPB, TCE and some of these other cleaners are not good for us, but everything else is such a price jump! Why can’t I find a strong, safe cleaner at a price we can afford? MAINTENANCE ING PWR-4 ™ L NEW MABLE SOLVENTS I want to switch to something safer, but need help…I’ve heard Degreasers The performance you need at the price you want! common industrial Perc & Methylene Chloride deal for degreasing and bulk for vapor-degreasing, t cleaning est. Contact us and start POWER UP…POWER FORWARD Maintenance Cleaner GET THE JOB DONE SPECS: www.pwr-4.com SAMPLES: 800-858-4043 SCAN FOR MOBILE SITE Blasts away oil and contaminants off of contacts, printed circuit boards, barcode instruments, switch boxes, gear boxes, and electronic motor controllers. Grease and oil flow right off, reducing the time and materials needed to scrub off stubborn soils. • Nonflammable • Much safer than most common industrial solvents — TCE, nPB, Perc & Methylene Chloride • Powerful cleaner — Ideal for degreasing and contact cleaning • Available in aerosol or bulk for vapor degreasing, ultrasonic and immersion cleaning • Rapid evaporation • Non-ozone depleting • Cleaning applications: electronics, relays, switches & breakers, transformers, and electric motors and generators 3400-5G 3400-20S 20 oz. (567g) aerosol 3400-G 1 gal. (3.8L) pail 3400-5G 5 gal. (18.9L) pail 3400-G 3400-20S Blue Shower Maintenance Cleaner • Nonflammable • Powerful cleaner • Rapid evaporation • Non-ozone depleting • Dielectric strength – 27.3 kv Nonflammable, powerful cleaner Clean oil and contaminants off of metal parts, printed circuit boards, barcode instruments, switch boxes, gear relays, and electronic motor controllers. 1630-16S 16 oz. (454g) aerosol Specification: Boeing D6 17487, Rev T Nonflammable, powerful liquid cleaner Engineered to remove oils, fluxes and other contamination using a manual soak cleaning process or ultrasonic equipment. 1638-G 1638-5G 1 gal. (3.8L) pail 5 gal (19L) pail 1638-G 1638-5G • Nonflammable • Powerful cleaner • Effective as maintenance cleaner and flux remover • Rapid evaporation • Non-ozone depleting • Dielectric strength – 27.3 kv Degreasers Universal Cleaner 3 MAINTENANCE Degreasers Plastic-Safe Universal Cleaner Plastic-safe, nonflammable cleaner for sensitive electronics Plastic-safe formula is engineered for use on sensitive plastic components, packaging and casements. Ideal for optics cleaning, critical electronics and other sensitive surfaces. Qualifies under the aerospace NESHAP VOC guidelines. 1652-10S 10 oz. (283g) aerosol Specifications: NESHAP 63.741-753 Blue Shower Maintenance Cleaner • Powerful cleaner • Ideal for sensitive plastics • Low toxicity • Non-ozone depleting Powerful and economical aerosol cleaner Clean oil and contaminants off of metal parts, printed circuit boards, barcode instruments, switch boxes, gear boxes, and engines. 1620-10S • Nonflammable • Low VOC • Safe on sensitive plastics • High precision – residue-free • Rapid evaporation • Non-ozone depleting 10 oz. (284g) aerosol Contact Cleaners Contact Cleaner • Nonflammable • Powerful cleaner • Rapid evaporation • Non-ozone depleting • Dielectric strength – 36.2 kv Degreasers / Contact Cleaners Nonflammable, powerful contact cleaner 4 Clean oxidation, oil, and other contaminants from contacts, metal switches, relays, edge connectors, buss bars, and circuit breakers. 1632-16S 16 oz. (454g) aerosol Specifications: Boeing D6 17487, Rev T Boeing Aircraft 127713 Contact Cleaner • Powerful cleaner • Ideal for sensitive plastics • Low toxicity • Non-ozone depleting Powerful and economical electronic contact cleaner Clean oxidation, oil, and other contaminants from contacts, metal switches, relays, edge connectors, buss bars, and circuit breakers. 1622-10S 1622-13S 10 oz. (284g) aerosol 13 oz. (369g) aerosol 1622-10S 1622-13S MAINTENANCE Isopropyl Alcohol (IPA) Techspray has the broadest line of isopropyl alcohol (IPA) in the industry, ranging from aerosol, pre-saturated wipes, and bulk packaging. Two grades of IPA are available: 99.8% anhydrous (containing as little water as possible) for fast-drying cleaning and 70% IPA / 30% DI for stencil and other cleaning when slower evaporation is desired. 99.8% Bulk – Technical Grade IPA 1610-P 1610-G4 1610-5G 1610-54G 1 pt. (473mL) bottle 1 gal. (3.8L) bottle sold only 4/cs 5 gal. (19L) container 54 gal. (205L) drum Specifications: ACS reagent grade, fed spec TT-1-735A (amend 3, notice 2) grades A&B ASTM D770-05 1610-5G 1610-P Pop-up Tubs 70% IPA Wipes 1608-100DSP 1608-100FL 1608-100R Sealed top reduces waste from dry-out Springloaded lid automatically closes • 5”x8” (127mm x 203mm) wipes • 100 wipes/tub • Lint-free , tear resistant polyester 100 wipes in Disposable Tub 100 wipes in Flip-Top Tub 100 wipes refill roll 1610-100FL 99.8% IPA Wipes 1610-100DSP 100 wipes in Disposable Tub 1610-100FL 100 wipes in Flip-Top Tub 1610-100R 100 wipes refill roll 1610-100DSP 1608-100DSP 1608-100FL Refill Roll Isopropyl Alcohol Individually Wrapped Wipes • 99.8% pure IPA • 5.5”x5.5” (140mm x 140mm) wipes • 50 wipes/box • Lint-free , tear resistant poly-cellulose 1610-50PK 5 MAINTENANCE Dusters Nonflammable Duster • Nonflammable • Safest choice for energized equipment • Velocity – 11.3 M/s Nonflammable, 100% HFC-134a duster 1671-10S 10 oz. (283g) aerosol 1671-15S 15 oz. (425g) aerosol NSN 6830-01-335-9925 1671-10S 1671-15S Specifications: Fed Spec A-A-58060 ARI Standard 700, App. C Vortex™ High Velocity Duster Economy Duster High velocity, 100% HFC-134a duster Economical HFC-152a duster • Most powerful blast • Nonflammable • Safest choice for energized equipment • Vortex 360° sprays upside-down • Velocity –14.6 m/s • Best value – 30% more volume • Lower global warming potential – 10% of HFC-134a • Velocity – 11.4 m/s 1697-8S Vortex 360° 8 oz. (227g) aerosol 1673-10S 10 oz. (283g) aerosol Note: not for use on powered electrical equipment, on hot surfaces, and around open flames or sparks. Specifications: Fed Spec A-A-58060 ARI Standard 700, App. C General Purpose Cleaners Zero-VOC General Purpose Cleaner Dusters / General Purpose Cleaners General purpose remover of adhesives and coatings Ideal for heavy-duty degreasing and for removing paint, coatings and sticky adhesive residues. Because it is VOC-free, there are no VOC restrictions – even in southern California! 1611-P Note: test first on plastics and painted surfaces to check for compatibility. Glass Cleaner Foaming aerosol glass and surface cleaner 1625-18S 18 oz. (510g) aerosol • Foaming action • Streak-free • Safe on glass & plastics • Nonflammable Label & Adhesive Remover Fast acting, citrus-based label and adhesive remover Citrus-based solvent safely and effectively removes labels and adhesive gums off equipment and products. Penetrates quickly and allows label to be peeled off without gummy residue. 1613-6S 6 1 pt. (473mL) can • Pure acetone • Ideal for removing inks & adhesives • VOC exempt • Low toxicity • Fast evaporation • Non-ozone depleting 4.5 oz. (128g) aerosol • Removes labels and adhesive without scraping • Penetrates rapidly • Citrus-based solvent • Safe on most plastics Note: Not available in California AVIONIC REPAIR AVIONIC REPAIR Techspray products clean and maintain sensitive avionics to prevent corrosion, and ensure reliability of controls, sensors, displays, touch panels, communication and other critical systems. Flux removers quickly and safely blast off corrosive flux residues. Freeze spray helps diagnose faulty components and solder joint. Techspray desoldering braid and TraceTech™ PCB repair products give you the capability to easily remove faulty components and perform trace repair without unsightly and unreliable jumpers. With Techspray, you can repair circuit boards and replace faulty components instead of replacing whole modules. Solvent Defluxers Flux Remover Strong and fast-acting flux remover Remove flux residues and other contaminants left by manufacture, rework, or repair of printed circuit boards. 1631-16S 16 oz. (454g) aerosol 1631-16SB 16 oz. (454g) aerosol w/brush attachment 1631-16SB • Nonflammable • Powerful cleaner • Proven effective for leadfree processes • All-in-one cleaner and defluxer • Rapid evaporation • Non-ozone depleting 1631-16S • 99.8% pure IPA • Compliant with SCAQMD rule 1171 • Plastic safe • Low toxicity • Non-ozone depleting IPA Electronics Cleaner 99.8% IPA in convenient aerosol package Ideal for defluxing, stencil cleaning and fiber optic connector cleaning. 1610-12S Specifications: Fed spec TT-1-735A (amend 3, notice 2) grades A&B ASTM D770-05 12 oz. (340g) aerosol Flux Remover & Maintenance Cleaner Hydrocarbon-based defluxer formulated to be powerful, yet very economical. Eliminates brushing and scrubbing, saving time and materials. 1621-10S 1621-G 10 oz. (283g) aerosol 1 gal. (3.8L) can Solvent Defluxers • Powerful cleaner • Proven effective for leadfree processes • Ideal for sensitive plastics Powerful and economical flux remover 1621-G 1621-10S Flux Remover & Maintenance Cleaner Nonflammable and powerful precision cleaner Clean off flux residues, oil, and other contamination from electronics and other sensitive surfaces. 1651-16S 1651-G 1651-5G 16 oz. (454g) aerosol 1 gal. (3.8L) pail 5 gal. (19L) pail • Nonflammable • Low VOC • Safe on most plastics • High precision – residue-free • Rapid evaporation • Non-ozone depleting 7 AVIONIC REPAIR Freeze Sprays Freeze Spray Pure HFC-134a freeze Spray • Chills down to -60°F (-51°C) • Nonflammable • Safe for energized equipment 1672-10S 1672-15S 10 oz. (283g) aerosol 15 oz. (425g) aerosol NSN 6850-01-406-1356 Specifications: McDonnell Douglas 558 1672-10S 1672-15S Anti-Static Freeze Spray ESD-Safe Diagnostic Freeze Spray 1747-10S 10 oz. (283g) aerosol • Avoids static build-up • Prevents latent failures • Chills down to -60°F (-51°C) • Nonflammable • No frost buildup ESD Products Freeze Sprays / ESD Products Zero Charge Mat & Tabletop Cleaner Permanent ESD Coating • Rugged static dissipative coating • Surface resistivity of 106 To 109 ohms • Operating temperature range – up to 302°F (155°C) • Humidity independent • Superior adhesion to variety of surfaces: glass, plastic, etc. • Non-ozone depleting 1756-8S Zero Charge Anti-Stat Coating Anti-static coating for fabrics & flexible surfaces • All-purpose static control • For plastics, fabrics, and carpet • Fast drying • Nonflammable 1726-QT 8 8 oz. (226g) aerosol (coats up to 200ft2) Specifications: MIL-B-81705B 1 qt. (.95L) bottle with trigger sprayer NSN 6850-01-324-4682 Safe, effective cleaner for ESD mats • Rejuvenates ESD-safe mats • Will not dry out surfaces • Leaves no insulative film • Nonflammable • No ammonia • Non-corrosive 1733-QT 1 qt. (.95L) bottle with trigger sprayer 1733-G 1 gal. (3.8L) bottle Zero Charge Hand Lotion Non-contaminating hand lotion for ESD sensitive environments • Improves wrist and heel strap contact • Does not contain silicone or lanolin • Non-contaminating — does not interfere with soldering • Non-greasy 1702-8FP 8 fl. oz. (237ml) bottle with finger pump 1733-QT Flux Remover Pen Spot cleaning for PCB rework and repair 2506-N Single-pack of 11.5 ml pen No-Clean Flux Dispensing Pen No-clean flux applicator pen for PCB rework and repair 2507-N Single-pack of 11.5 ml pen 2507-N100 144 pack of 11.5 ml pens, 12 boxes of 12 Conductive Pen • Safe on plastics • Rapid evaporation • Pen tip allows controlled application AVIONIC REPAIR Rework & Repair Pens • Excellent wetting • Works with lead and lead-free solders • Boost wetting for lead-free wire solder • No cleaning necessary • Repairs traces • Makes smooth jumpers Silver ink pen for repairing electronic traces 2505-N Single-pack of 4.9 ml pen Overcoat Pen • Repairs solder resist • Green to match resist • Prevents shorting and arcing Resist repair pen for PCB rework and repair 2509-GN Single-pack of 5 ml pen Conformal Coating Remover Pen Spot coating remover in applicator pen for PCB rework and repair 2510-N • Fast stripping action • Non-corrosive • Rapid evaporation 10 ml pen Silicone Heat Sink Compound Heat sink compound for electrical applications 1977-DP 4 oz. (118ml) squeeze tube Silicone-Free Heat Sink Compound Heat-sink for electronics, avoid silicone contamination 1978-DP 4 oz. (118ml) squeeze tube Rework & Repair Pens Heat Sink / Transister Grease • Thermal conductivity – 0.70 W/m-K • Functional temperature Range -67°F to 401°F (-55°C to 205°C) • Easy application • Will not harden and crack • Thermal conductivity – 0.92 W/m-K • Functional temperature range -40°F to 392°F (-40°C to 200°C) • Avoid solder defects due to silicone contamination • Easy application • Will not separate • Will not harden and crack 9 AVIONIC REPAIR Desoldering Braid Techspray wick is available in static dissipative bobbins for static sensitive environments. Techspray No-Clean wick is coated with proprietary flux that only leaves a slight clear residue, which does not cause service issues. Cleaning after using Techspray No-Clean wick is strictly optional. Specifications: Meets or Exceeds MIL-F-14256; NASA NHB 5300, 4 (34-1); NASA NPC 200-4; NASA SP5002; 1821:HP 8690-0588; 1823: HP 8690-0577; IPC Standard-J-STD-004 Pro-Wick® Rosin — ESD-Safe Bobbin For the fastest wicking action, rosin flux coated braid is ideal for high volume PCB production/repair environments. Size/Color 5’ 10’ 1808 #1 White 1808-5F 1808-10F 1809 #2 Yellow 1809-5F 1809-10F 1810 #3 Green 1810-5F 1810-10F 1811 #4 Blue 1811-5F 1811-10F 1812 #5 Brown 1812-5F — 1813 #6 Red 1813-5F — No-Clean Wick — ESD-Safe Bobbin The cleanest No-Clean braid in the industry. The proprietary flux formula is specially designed to avoid catastrophic and latent PCB failures caused by ionic flux residue. Desoldering Braid 10’ 1820 #1 White 1820-5F 1820-10F 1821 #2 Yellow 1821-5F 1821-10F 1822 #3 Green 1822-5F 1822-10F 1823 #4 Blue 1823-5F 1823-10F 1824 #5 Brown 1824-5F — 1825 #6 Red 1825-5F — 10 Size/Color 5’ Unfluxed Wick — ESD-Safe Bobbin For customers who use water-soluble flux, or their own flux for aqueous processes. Size/Color 5’ 10’ 1830 #1 White — 1830-10F 1831 #2 Yellow — 1831-10F 1832 #3 Green 1832-5F — 1833 #4 Blue — 1833-10F DESOLDERING BRAID SELECTION CHART #2 #1 #3 Yellow White Green .035” (0.9mm) .055” (1.4mm) .075” (1.9mm) #4 Blue #5 Brown #6 Red .098” .130” .193” (2.5mm) (3.3mm) (4.9mm) Wick in selection chart shown actual size. Specifications: MIL-F-14256 NASA NHB 5300, 4 (34-1) NASA NPC 200-4 NASA SP5002 IPC Standard-J-STD-004 Match braid width to contact area L Bristle Product Length SIDE VIEW FRONT VIEW W Bristle Width T Bristle Trim Bristle Handle Handle Material Material Length 2020-1 1.375” 0.25” (35mm) (6.4mm) 0.44” (11mm) Horse Wood 7.75” Hair (19.7cm) 2021-1 1.375” 0.25” (35mm) (6.4mm) 0.44” (11mm) Hog Wood 7.75” Bristle (19.7cm) AVIONIC REPAIR Brushes 2022 2.125” 0.875” 0.75” Hog Wood 8.375” (54mm) (22mm) (19mm) Bristle (21.3cm) 2030-1 0.125” 0.0625” 0.125” Goat Stainless 3.5” (3.2mm) (1.6mm) (3.2mm) Hair Steel (8.9cm) Top View A B Side View Top View Side View A B 2031-1 0.25” 0.19” A - 0.25” Horse Stainless 4.5” (6.4mm) (4.8mm) (6.4mm) Hair Steel (11.4cm) B - 0.5” (13mm) 2032-1 0.5” 0.375” A - 0.19” (13mm) (9.5mm) (4.8mm) B - 0.25” (6.4mm) Horse Hair Zinc Plated 4.5” Steel (11.4cm) 2033-1 0.44” 0.375” 0.75” Horse Zinc Plated 4.5” (11.2mm) (9.5mm) (19mm) Hair Steel (11.4cm) TechSwabs All swabs shown actual size – 1:1 scale Cotton TechSwabs Product Tip Width 2300 0.1875" Wrapped 6" (4.8mm) (15cm) Handle Length Product Tip Width 2302 0.44" Heat Sealed 6" (11.2mm) (15cm) 30 Pack Bag Wood Attachment Handle of Tip Length 100 Pack Bag 1000 Pack Bag — 2300-100 2300-1000 Handle Material 50 Pack Bag 1000 Pack Bag Polypropylene 2302-50 2302-1000 Polypropylene 2306-50 2306-1000 Cotton Bud Wrapped in Foam, Rigid Head 2306 Handle Material 0.5" Heat Sealed (13mm) 5" (13cm) Brushes / Swabs Foam TechSwabs Attachment of Tip Rigid Head For full selection of swabs and wipes, go to www.techspray.com or full line Techspray product catalog. 11 • Soldering tips, shear cutters & other soldering accessories FOR MORE INFORMATION Advanced Chemistries To Improve Your Products & Processes For more information and the full product line for electronics and general industry cleaning and coating, including: www.techspray.com • Aerosol, ultrasonic & vapor degreaser solvent cleaners • PCB assembly cleaners, temporary solder masks & conformal coatings • PCB rework & repair products • Full line of wipes, swabs & brushes ® Quality Tools for Electronic Assembly & Repair • Soldering & desoldering tips • Shear cutters • Tip cleaners & other soldering accessories www.platoproducts.com Techspray - US Office 8125 Cobb Center Drive Kennesaw, GA 30152 678-819-1408 800-858-4043 tsales@techspray.com Techspray - European Office ITW Contamination Control BV Saffierlaan 5, 2132 VZ Hoofddorp The Netherlands +31 88 1307 400 info@itw-cc.com Techspray - China Office ITW Specialty Materials (Suzhou) Co., Ltd Hengqiao Road, Wujiang Economic Development Zone, Suzhou, Jiangsu Province, China 215200 (86)512-82060808 Ext 508 MP: (86) 13777018750 LT-TSAVIATION 17166
2020-1 价格&库存
很抱歉,暂时无法提供与“2020-1”相匹配的价格&库存,您可以联系我们找货
    库存:117
    2020-1
      库存:15
      2020-1
        • 12+108.1376612+14.03430
        库存:12
