Industrial GPS Asset Tracker
LoRaWAN® connected GPS Tracker for Industrial Asset Management
The Industrial GPS Asset Tracker is an ideal solution for geolocalizing your assets in the field. This device provides
GPS enabled near real-time satellite location tracking with LoRaWAN®. The rugged IP67 design allows for operation
in diverse deployment environments, with an operable temperature range of -40°C to +85°C and an optional BLE
integration. The device contains 2x D Cell batteries for optimal battery life of up to 8-10 years. The unit is equipped
with an accelerometer to accommodate event-based start-up, minimizing unnecessary battery usage.
The Industrial GPS Asset Tracker is seamlessly integrated with TEKTELIC’s End-to-End IoT solution.
Technical and Functional System Specifications
General System Parameters
Operational Temperature -40°C to +85°C
Protection Rating
IP67
Size
195 x 101 x 50 mm
Battery
1x or 2x D-Cell
LoRa Parameters
Key Features
RF Power
23 dBm
RF Sensitivity
-137dBm (SF12, 125kHz)
ISM Band
All Global ISM Bands
Precise GPS
Antenna
Internal
Data Transmission via LoRaWAN®
8-10 Year Battery Life
LoRa Device Class Class A and C
BLE (Optional)
Regulatory Compliance
All Global ISM bands
Safety
IEC 60950-1 (CE)
Regulatory
ETSI EN 300 220
Rugged IP67 Design
ETSI EN 301-489-1/-3
Accelerometer
FCC 15.247
Internal Antenna
RSS-247
FCC 15.209
RSS-GEN
195 mm
GNSS Features
Position Accuracy
2.5m
TTFF
(Time to First Fix)
Cold Start - 26 Seconds
Sensitivity
-164 dBm tracking and navigation
101 mm
Hot Start - 1 Second
-148 dBm cold start
-157 dBm hot start
INFO@TEKTELIC.COM
+1.403.338.6900
WWW.TEKTELIC.COM
TEKTELIC Communications is a premier supplier of best-in-class LoRaWAN® IoT Gateways, Sensors, and Custom Applications. These elements combined
provide a powerful end-to-end solution that can be easily, quickly, and cost effectively deployed to address the most demanding IoT challenges.
For more information please visit www.tektelic.com
很抱歉,暂时无法提供与“T0006129-EU”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 10+2040.6743710+263.99239
