T0005247
T0005247
    TEKTELIC
    DHCP,GPS,LoRa,LoRaWAN 网关 以太网,RJ-45
T0005247 数据手册
KONA Macro IoT Gateway Scalable LoRaWAN® Gateway for Outdoor Deployments The KONA Macro IoT Gateway is an ideal solution for operators and enterprises that require a very scalable low cost LoRaWAN® gateway that minimizes network TCO while improving coverage and capacity. In order to facilitate rapid deployment, the gateway is designed to be extremely compact and light weight. With both the cellular modem and GPS antennas embedded internally the KONA Macro is targeted at network sites that dictate a small form factor and low power consumption. Rated IP67 it is designed for the most demanding outdoor installations. The KONA Macro can be installed in various locations reducing site and deployment costs while addressing different vertical IoT applications. Key Product Differentiators Key Features Optimize coverage and capacity with a cost-effective and extremely compact LoRaWAN® gateway. Quick and easy deployment made possible with custom mounting options, including utility pole, lamp post, tower, roof or wall mounts. Reduce set-up costs with plug-and-play installation utilizing the custom provisioned factory image. Lower site operational costs due to low power consumptions and passive cooling. High availability carrier grade design with support for in-service configuration and software updates. Excellent out of band rejection of Interference from other networks such as Cellular and Paging. Fully integrated with the broad eco-system of LoRa™ network servers and sensors. INFO@TEKTELIC.COM +1.403.338.6900 NA915, EU868, AU915, AS923 ISM Bands Frequency Duplex 16 Rx / 2 Tx (NA) Time Duplex 16 Rx / 2 Tx (Int.) Integrated Bandpass Filter Integrated GPS and 3G/4G Antenna Precise Network Synchronization (GPS) 27 dBm Tx Power Hardended Carrier Grade Enclosure Backhaul Connectivity (ETH / 3G / 4G) Geolocation (optional) Versatile Mounting Options WWW.TEKTELIC.COM KONA Macro IoT Gateway Scalable LoRaWAN® Gateway for Outdoor Deployments Technical and Functional System Specifications Mechanical Parameters LoRa Radio Parameters MTBF 850,000 hours ISM Bands (FDD) NA902-928, CN470-510 DC Power Consumption < 20 W ISM Bands (TDD) EU868, AU915, AS923, JP920, CH779 Operational Temperature -40°C to +60°C Tx Power 27 dBm Operational Humidity 10% to 100% Condensing Rx Sensitivity -142 dBm (SF12, 293 bits/sec) Ingress Protection IP67 Rx Noise Figure 3.5 dB Size 144 x 282 x 92 mm Rx Linearity -10 dBm Weight 2.6 kg Rx Dynamic Range 70 dB Analog, 100+ dB Digital Volume 3.7 L Interfaces Software and Management Tools Access Control List managment 3G/4G Parameter Configuration System Health Monitor Radio Configuration and Control Remote Software Upgrade Active and Passive image management Factory image provisioning Field Configuration Tool Networking Ethernet Backhaul RJ-45 GPS (internal antenna) Cellular Backhaul (3G/4G) (internal antenna) LoRa Antenna N-Type Power -48VDC or PoE (802.3at) Regulatory Compliance Safety UL60950-1(US/C) IEC 60950-1 (CE) Environmental ETSI EN 300 019-2 Regulatory FCC Part 15.247, 109, 209 ETSI EN 55022 Class B DHCPv4 client ETSI EN 55024 TFTP server ETSI EN 300 489-1/-3 HTTP server Available SKU’s (Digi-Key) Firewall and Access Lists 144 mm 92 mm T-Code Region Backhaul T0004937 North America LTE + Ethernet T0005247 North America Ethernet T0005130 Europe LTE + Ethernet T0005249 Europe Ethernet 282 mm TEKTELIC Communications is a premier supplier of best-in-class LoRaWAN® IoT Gateways, Sensors, and custom applications. These elements combined provide a powerful end-to-end solution that can be easily, quickly, and cost effectively deployed to address the most demanding IoT challenges. For more information please visit www.tektelic.com
T0005247 价格&库存
很抱歉,暂时无法提供与“T0005247”相匹配的价格&库存,您可以联系我们找货
