KONA Macro IoT Gateway
Scalable LoRaWAN® Gateway for Outdoor Deployments
The KONA Macro IoT Gateway is an ideal solution for
operators and enterprises that require a very scalable
low cost LoRaWAN® gateway that minimizes network
TCO while improving coverage and capacity. In order to
facilitate rapid deployment, the gateway is designed to
be extremely compact and light weight. With both the
cellular modem and GPS antennas embedded internally
the KONA Macro is targeted at network sites that dictate
a small form factor and low power consumption. Rated
IP67 it is designed for the most demanding outdoor
installations. The KONA Macro can be installed in various
locations reducing site and deployment costs while
addressing different vertical IoT applications.
Key Product Differentiators
Key Features
Optimize coverage and capacity with a cost-effective
and extremely compact LoRaWAN® gateway.
Quick and easy deployment made possible with
custom mounting options, including utility pole,
lamp post, tower, roof or wall mounts.
Reduce set-up costs with plug-and-play installation
utilizing the custom provisioned factory image.
Lower site operational costs due to low power
consumptions and passive cooling.
High availability carrier grade design with support for
in-service configuration and software updates.
Excellent out of band rejection of Interference from
other networks such as Cellular and Paging.
Fully integrated with the broad eco-system of
LoRa™ network servers and sensors.
INFO@TEKTELIC.COM
+1.403.338.6900
NA915, EU868, AU915, AS923 ISM Bands
Frequency Duplex 16 Rx / 2 Tx (NA)
Time Duplex 16 Rx / 2 Tx (Int.)
Integrated Bandpass Filter
Integrated GPS and 3G/4G Antenna
Precise Network Synchronization (GPS)
27 dBm Tx Power
Hardended Carrier Grade Enclosure
Backhaul Connectivity (ETH / 3G / 4G)
Geolocation (optional)
Versatile Mounting Options
WWW.TEKTELIC.COM
Technical and Functional System Specifications
Mechanical Parameters
LoRa Radio Parameters
MTBF
850,000 hours
ISM Bands (FDD)
NA902-928, CN470-510
DC Power Consumption
< 20 W
ISM Bands (TDD)
EU868, AU915, AS923, JP920, CH779
Operational Temperature
-40°C to +60°C
Tx Power
27 dBm
Operational Humidity
10% to 100% Condensing
Rx Sensitivity
-142 dBm (SF12, 293 bits/sec)
Ingress Protection
IP67
Rx Noise Figure
3.5 dB
Size
144 x 282 x 92 mm
Rx Linearity
-10 dBm
Weight
2.6 kg
Rx Dynamic Range
70 dB Analog, 100+ dB Digital
Volume
3.7 L
Interfaces
Software and Management
Tools
Access Control List managment
3G/4G Parameter Configuration
System Health Monitor
Radio Configuration and Control
Remote Software Upgrade
Active and Passive image management
Factory image provisioning
Field Configuration Tool
Networking
Ethernet Backhaul
RJ-45
GPS
(internal antenna)
Cellular Backhaul (3G/4G)
(internal antenna)
LoRa Antenna
N-Type
Power
-48VDC or PoE (802.3at)
Regulatory Compliance
Safety
UL60950-1(US/C) IEC 60950-1 (CE)
Environmental
ETSI EN 300 019-2
Regulatory
FCC Part 15.247, 109, 209
ETSI EN 55022 Class B
DHCPv4 client
ETSI EN 55024
TFTP server
ETSI EN 300 489-1/-3
HTTP server
Available SKU’s (Digi-Key)
Firewall and Access Lists
144 mm
92 mm
T-Code
Region
Backhaul
T0004937
North America
LTE + Ethernet
T0005247
North America
Ethernet
T0005130
Europe
LTE + Ethernet
T0005249
Europe
Ethernet
282 mm
TEKTELIC Communications is a premier supplier of best-in-class LoRaWAN® IoT Gateways, Sensors, and custom applications. These
elements combined provide a powerful end-to-end solution that can be easily, quickly, and cost effectively deployed to address the most
demanding IoT challenges.
For more information please visit www.tektelic.com
很抱歉,暂时无法提供与“T0004937”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+19058.207701+2465.47011
